Wharfedale Jade 7 for Sales
Item: Wharfedale Jade 7
Condition: 8/10 with box and everything that comes with it. Used in dedicated & closed room. Has very light dents on one of the speaker, other than that, perfect. Very good condition.
Contact: -
Price: sold
Reason of Selling: Upgrading
This is a very nice 4 ways Floorstand Speaker, Tight, solid and clean bass, serious buyer can arrange for audition.
Specifications:
Description: Four-way, floorstanding loudspeaker with aperiodic loading. Drive-units: 1" (25mm) aluminum-dome tweeter, 3" (75mm) aluminum-pulp composite-cone upper-midrange unit, 6.5" (165mm) Acufibre-cone lower-midrange unit, two 8" (200mm) Acufibre-cone woofers. Crossover frequencies: 180Hz, 590Hz, 2.8kHz. Frequency response: 38Hz–24kHz, ±3dB. Nominal impedance: 6 ohms. Sensitivity: 88dB/2.83V/m. Recommended amplification: 50–250W.
Dimensions: 46" (1180mm) H by 10.6" (273mm) W by 17.5" (448mm) D. Weight: 81.4 lbs (37kg).
Read more at http://www.stereophile.com/content/wharfedale-jade-7-loudspeaker-specifications#x5V8ygmRxRgMU5Oc.99
Review From 6moons audio:
http://www.6moons.com/audioreviews/wharfedale2/1.html
Review From Whathifi:
Seriously impressive bass weight and control
superbly detailed
good integration between individual drivers
Read more at http://www.whathifi.com/wharfedale/jade-5/review#Dt4pCus3jgJpLvl1.99
Review From Stereophile:
Conclusions
The word that for me best describes the sound of the Wharfedale Jade 7 is balanced. Not just its tonal balance—which was almost ideally neutral—but a balance of the various sonic attributes most valued by audiophiles. Transparency, detail, soundstaging, and dynamics were all excellent
Read more at http://www.stereophile.com/content/wharfedale-jade-7-loudspeaker-page-2#7zFyRqvcdwyiWwq0.99
Contact: -
Price: sold
Specifications:
- Impresses with cast-in-concrete low bass without boom or control issues.
- Displays proper timing top to bottom despite using four drivers.
- Casts a large very airy stage.
- Handles voices and acoustic instruments very realistic and silken. This does require proper burn-in.
- Is blessed with accurate impulsive mids which inject a certain freshness and presence without feeling artificially emphasized.
- Gets a bit round on top without suggesting loss of anything vital. More treble resolution is possible elsewhere.
- Very easy to place.
- Exemplary fit ‘n’ finish in this price class.
superbly detailed
Conclusions
kong5091- New Member
- Number of posts : 4
Registration date : 2013-05-03
» Wharfedale Jade 3 (Box set)
» Wharfedale jade 3
» Wharfedale Jade 3 Speakers
» wharfedale jade 7 sold
» Wharfedale jade 3
