Emotiva UPA-1 mono block (pair)
2 posters
Let go emotiva upa-1 a pair. good condition.
Note: RCA connection modified with high grade terminal.
Power 8 Ohm All Channels Driven: 200W
Power 4 Ohm All Channels Driven: 350W
Power Bandwidth: +/-0.05dB
Frequency Response: 5Hz-150kHz(-3dB)
THD: NA
SN Ratio 1W: >89dB
SN Ratio Full: >117dB
Damping: NA
Crosstalk: NA
TransformerVA: 300
Capacitance: 80,000
Input Sensitivity: NA
Input Impedance Unbal/Bal: 23.5/33
Gain: 32dB
Adjustable Gain: No
Power Requirements: 15A
Connections: XLR/RCA
Trigger: Yes
LED Meters: No
2 Ohm Capable: NA
Output Devices: 6
Fans: No
Weight: 26
Width: 17
Height: 3.87
Depth: 18
Rack Size: 2U
Topology: Fully discrete, dual differential
FEATURES:
Dual output terminals for easy bi-wiring.
Fully protected from all fault conditions.
Advanced microprocessor operating system.
Soft start circuitry.
External trigger turn on.
Soft touch power switch.
2RU chassis w/ solid milled aluminum faceplate.
IEC power inlet, 120/230 VAC auto configurable.
Output design: Triple Darlington with On output stages.
Type of outputs: Audiophile quality 5 way binding post.
Display type: Digital status indicators.
1% resistors, precision film capacitors in all critical signal paths.
Modular channel design for greater channel separation, auto rail detection relays for automatic voltage selection.
On/Off LED Status Switch.
Allow functional test on collection
**Prefer self collect (Price reduce RM150)
Rm 2300 (Sold)
0122265512
THD: NA
SN Ratio 1W: >89dB
Damping: NA
Crosstalk: NA
TransformerVA: 300
Capacitance: 80,000
Gain: 32dB
Adjustable Gain: No
Trigger: Yes
LED Meters: No
2 Ohm Capable: NA
Output Devices: 6
Fans: No
Weight: 26
Width: 17
Height: 3.87
Depth: 18
Rack Size: 2U
FEATURES:
Rm 2300 (Sold)
0122265512
bedrock79- New Member
- Number of posts : 17
Registration date : 2016-02-15
Re: Emotiva UPA-1 mono block (pair)
the price is for 1 pair? do u sell only 1 unit
arremie- Frequent Contributor
- Number of posts : 533
Registration date : 2009-02-09
Source(s): Oppo
Amplification: Parasound
Speakers: Klipsch
one pair.arremie wrote:the price is for 1 pair? do u sell only 1 unit
» McIntosh pre amp & Audio Research mono block 1 pair
» MARANTZ MA500 Power Amplifier Pair Mono Block
» Denon mono-block power amplifier, 1 pair: POA-4400A (Used) - SOLD
» Audionet Pre & Power Mono Blocks (one of the Mono Block not working) SOLD
» Emotiva XPA-1 Mono-Amp & USP-1 Pre-amp
