Marantz MM7055 5-Channel Power Amplifier in Good Condition
Marantz MM7055 5-Channel AV Power Amplifier in Good Condition
Product Highlights:
5-channel power amplifier
140 watts per channel into 8 ohms (20-20,000 Hz) at 0.08% THD, with 2 channels driven
frequency response: 8-100,000 Hz (±3 dB)
signal-to-noise ratio: 105 dB
one RCA and one XLR input for each channel
Discrete Current Feedback circuit for accurate, natural sound at all volume levels
DC trigger input/output
IR flasher input
massive power supply for high current and low noise
gold-plated binding post speaker terminals
detachable power cord
weight: 34.6 lbs.
17-3/8"W x 7-1/4"H x 16-1/4"D
MM7055 is the five-channel option in the extended line-up of main amplifiers. Based on the technology used in the MM8003 and using the exact same chassis, it delivers a thumping 140W rms into 8 ohm to each of the channels, while the ultra-wide bandwidth current feedback technology easily handles the highest SACD frequencies - this also makes it ideal for the high definition DTS Master Audio and Dolby TrueHD formats too. The result? Totally precise tonal and image balance, speed and dynamics. And on top of all that, you also get XLR audio inputs, DC triggers and a Marantz control bus system for remote on/off. This is power and convenience to take your breath away.
The chassis feels quite solid, as one should expect from an amplifier in this price range. The unit itself weighs in at roughly 35 pounds, so it's quite a bit heftier than your average “100W x 7” A/V receiver, but it's not a back-breaker either. The input jacks feel reasonably secure, so you're unlikely to pull one out with a tight gripping interconnect.
Glancing through the top cover to check out the guts of the MM7055, a few things stick out. First and foremost, the unit boasts a relatively large EI transformer, which undoubtedly contributes a great deal to the unit's weight. The other thing that's immediately eye-catching is the pair of massive capacitors gracing this amplifier. Each capacitor is rated at 33,000uF / 71V, which ensures plenty of reserve capacity for dynamic peaks.
Please google for more details and info on this superb performing Power Amplifier with a very reasonable pricing.
https://www.crutchfield.com/S-F1Aw1yUY069/p_642MM7055/Marantz-MM7055.html
https://www.aperionaudio.com/marantz-mm7055-5-channel-home-theater-amplifier
Still in perfect running condition, buyer can test as long as they want to.
Condition 8/10 only due to no original box.
It's in wonderful cosmetic condition with brand new look due to less usage.
Well maintained in smoke free and pets free environment.
Good for both movies and music listening and easily can drive most high end speakers too.
Can arrange free delivery to any places for serious buyers.
Price: RM3500 (nego)
Please whatsapp or sms 012-5555 770 for further details or more photos.
Thank you hifi4sale team.
Product Highlights:
IR flasher input
weight: 34.6 lbs.
Last edited by john101 on Thu Jun 17, 2021 2:51 pm; edited 1 time in total (Reason for editing : Update photos)
john101- Club Member
- Number of posts : 27
Registration date : 2016-01-17
» Marantz 8 Channel Power Amp (Top Flagship Model)-Used & In Good Condition
» Marantz AV8801 AV Pre Amp/Processor & 8 Channel Power Amp (MM8003)-Used & In Good Condition
» Marantz MM7055 5-channel power amplifier ( SOLD)
» Marantz MM7055 5-channel Power Amplifier (140W x 5-Channels)
