Marantz 8 Channel Power Amp (Top Flagship Model)-Used & In Good Condition
Marantz 8 Channel Power Amp (MM8003)
High grade top flagship model power amp from Marantz, can say still best performing amp compared with some current power amps with lesser quality build in the market.
In a very good working condition due to less use. This Power Amp was around RM10k++ earlier.
With RCA & also XLR connections for a better clarity and pure signal transmission.
Looking inside MM8003 Power Amp one can see the heavy copper plated steel chassis with an enclosed Toroidal Transformer with all the parts carefully laid out to maximize performance.
Each of the MM8003's 8 channels is rated at 140 watts with less than .08 percent total harmonic distortion with a signal to noise ratio of 105dB. The power supply providing the juice for all of this is includes a multiple-secondary toroidal transformer rated at 600VA and 100,000 microfarads worth of custom-designed capacitors.
The capacitors are mounted on copper-plated, anti-vibration brackets. Many of the key components are from well respected manufacturers of audiophile grade components such as WIMA.
Features:
- 140W x 8ch (8 ohms) Power Amplifiers
- Low Impedance Continuous Drive Capability
- Current Feedback Amplifier Circuit
- Massive Toroidal Power Transformer
- Slow Start to Power On (better protection for the amp and processor unit as well).
- 8ch XLR Input Terminals
- DC Trigger Control Inputs, DC Power Status
- Outputs, IR Flasher Input Terminals
- Output Channel Relay On/Off Control by Remote Signal (to Multi Zone Use)
- Copper Plated Chassis
- Gold Plated Speaker Terminals
- Marantz Designed Storage Capacitors for Quick Response to Rapidly Varying Sources
- New Clean Design Front Panel
Really good for both audio and video use.
Well maintained in smoke free and pet free environment.
Condition: 8/10 due to no original box.
Many award winning model, please check the reviews and more info below:-
http://www.avrev.com/home-theater-power-amplifiers/multi-channel-amplifiers/marantz-mm8003-power-amplifier.html
Amp is in Penang but can arrange delivery to other locations.
Contact: Anand 012-5885270
Please sms or whatsapp for more photos and other info
Price:RM4800(nego)
Accept Swap:
Other AV or Hifi stuffs
anandfm- Frequent Contributor
- Number of posts : 978
» Marantz MM7055 5-Channel Power Amplifier in Good Condition
» Marantz AV8801 AV Pre Amp/Processor & 8 Channel Power Amp (MM8003)-Used & In Good Condition
» Marantz Flagship Model MM8003 Power Amp Made in Japan (used & in great condition)
» Made in USA - Marantz Model 250 (Power Amp) & Marantz Model 3300 (Pre) in VG+ Condition - Priced to Clear!
» Made in USA - Legendary Marantz Model 250M (Power) and Model 3300 (Pre) in Super Pristine Condition - Clearance Price!
