Yamaha AVENTAGE RX-A1070 7.2CH Atmos Network Av Receiver (Sold Out)
Yamaha AVENTAGE RX-A1070 7.2CH Atmos Network Av Receiver.
Free Shipping Within West Malaysia.
Please visit [You must be registered and logged in to see this link.] to find out more products for sale at very special pice..
This 7.2-channel AVENTAGE network AV receiver features Dolby Atmos® and DTS:X™ for surround sound realism. With the latest in HDMI® technologies, experience movies in stunning 4K Ultra HD and high dynamic range (HDR). In addition, Dolby Vision™ and Hybrid Log-Gamma compatibility provide incredible contrast, smooth tone and rich, bright colors. The free MusicCast app makes it easy to access your music library and streaming music services. Add audio in up to 9 additional rooms with MusicCast wireless speakers or other MusicCast devices. Connect wirelessly via Wi-Fi®, Bluetooth® and AirPlay® wireless connectivity. Additionally, a phono input for vinyl playback, advanced HDMI zone switching and Zone 2 control options provide added system versatility.
此 7.2 聲道AVENTAGE AV擴大機使用反共振技術和堅固的底部結構,支援Dolby Atmos® 以及 DTS-X™,並提供MusicCast相容,Zone 2音訊處理以及HDMI 的 HDCP2.2, 4K/60P輸入,包含HDR與BT.2020。
Enjoy fine sound quality. The Total Purity Concept, which Yamaha has been cultivating for many years, encompasses high drive amp technology, high purity preamplification, anti-vibration technology and independent pure power supplies. All models have fully discrete power amplifiers that help minimize distortion. They also adopt pure independent power supplies, allowing dedicated power supplies for the analog and digital circuitry to prevent digital noise from affecting analog circuitry. The anti-vibration heat sinks are designed to suppress vibration from transistors and sound pressure. Independent power supplies for the DACs are designed to further eliminate noise on certain models. Down to every detail, these AV receivers are designed with full emphasis on the highest possible sound quality.
Yamaha 基於多年累積來的全純淨音質設計概念,包括高驅動放大器技術、高純度前置放大器、抗震技術和獨立的電源供應。所有機型皆使用獨立的功率放大器將干擾降到最低。並在類比電路與數位電路裝置獨立純淨的電源供應以避免類比電路造成的數位干擾。大型散熱器可抑制來自於電子元件與聲音造成的振動。單獨的DAC 電源供給可進一部消除噪音。綜觀所有的細節,顯示出Yamaha 多聲道影音綜合擴大機系列的設計,完全以達到最完美音質為目的。
* 有些零件並不含在此機型內
Professional grade DACs. Incorporating the SABRE™ 9006A Premier Audio DAC from ESS Technology to achieve an exceptionally good signal-to-noise ratio and up to 120 dB of dynamic range, this AV receiver produces professional quality digital audio.
SABRE™ 9006A 結合了高性能 DAC帶來無與倫比的音效表現。具備最高120dB動態範圍,超低干擾與噪訊。此款擴大機重現專業數位音訊品質。
Designed to the details. The interior of the unit has been precisely planned, circuit-routed and built so that the left and right channels are physically and electrically isolated. This naturally maximizes channel separation but also greatly improves signal to noise ratio and also helps to achieve a wide open sound stage for a superior receiver.
這僅是創造優異擴大機性能的多種設計細節之一。透過精心規劃與線路安排,內部左右聲道能真正有獨立電源。這自然最大限度地分離各個聲道,也大幅改善訊躁比,且有助於寬廣、開闊的音場。
A firm foundation. The Anti-Resonance Technology Wedge is a fifth foot in the center of the unit. It dampens vibrations from the power transformer, power transistors and heat sinks, as well as vibrations that might be caused by the sound from the speakers.
防共振技術(A.R.T)楔座是位於中心的第五支撐點。它減少可能因電源變壓器、功率晶體管、散熱片、與喇叭,以及由揚聲器聲音所能造成的振動。
Shielded from noise. All of the AVENTAGE components feature the same sleek, clean design, with an elegant aluminum front panel and silky touch volume/selector knobs. The aluminum front panel is used to effectively shield sensitive circuitry from external noise and electronic radiation generated by dimmer switches, fluorescent lighting, video monitors and so on. This ensures optimum sonic performance in the widest range of installation environments.
所有AVENTAGE的組件擁有相同時尚、簡潔的設計,優雅的鋁質面板和柔滑的觸感音量/選擇器旋鈕。鋁質面板用於有效地抵擋來自外部噪音、熒光燈照明、與視頻螢幕的敏感電流與調光開關所產生的電子輻射。這可以確保在最有彈性的安裝環境有最佳的聲音性能。
Reinforced for rigidity. The interior of the receiver is reinforced with cross members in an H shape to provide an extremely rigid and stable frame. This reduces chassis vibration to virtually zero even during high volume output (seemingly minor vibrations can affect the sound), maintaining the highest audio quality.
擴大機內部的H-型交叉鋼性骨架提供極堅韌且穩固的外框。如此的作法把因高度聲音輸出(震動大多數都會影響聲音)時所引起的機殼震動減低至幾乎零, 帶來精湛的音樂表現。
*Dolby Vision and Hybrid Log-Gamma will be available via future firmware update.
* Dolby Vision與 Hybrid Log-Gamma 將透過韌體更新支援。
Learn more about MusicCast wireless multiroom audio
iCompatible. This AV receiver supports AirPlay, which means they can accept wireless music streaming from iPod touch®, iPhone®, iPad®, as well as from iTunes® on a Mac® or PC. This makes it easy to enjoy music from your mobile devices or computer at your home theater system. You can view metadata such as song title, artist name as well as album art inside the receiver's on-screen display.
支援AirPlay的AV綜合擴大機,可接受來自於iPod touch,iPhone或iPad以及Mac/PC iTunes上的音樂。可以很容易地將來自於移動設備或電腦上的音樂,於家庭劇院系統上欣賞。您可以使用文字資訊,如歌名、歌手名和專輯封面*通過AV擴大機於螢幕上顯示。
* 部份機種不支援顯示專輯封面
*音樂串流服務視地區而有不同
Millions of songs. With the Spotify app on your mobile device, you have instant access to millions of songs. Now you can stream those songs to your networked Yamaha AV receiver by using Spotify Connect. Just hit play to start streaming music. When you listen to Spotify outside on your mobile device and come inside, the song immediately streams to your Yamaha AV receiver allowing no interruption to your music playback. You can also personalize playlists and receive phone calls while listening to music on Spotify. The Spotify app and premium account are required. Visit [You must be registered and logged in to see this link.] for more details. Try Spotify Premium for free on your Yamaha home entertainment system for 30 days. Visit [You must be registered and logged in to see this link.] for more details.
隨著智慧型手機上的 Spotify 應用程式,可立即存取上百萬首的歌曲。現在您可利用 Spotify Connect 將這些歌曲串流到 Yamaha 系統。只需點擊播放即可開始串流音樂。更重要的是,當您正使用智慧型手機聆聽音樂且由外面進入時,歌曲將如同魔術般立即串流至您的擴大機,以享無間斷的音樂。聆聽音樂時亦可個人化播放列表和接聽電話
* 需具備 Spotify 應用程式和付費帳號,更多詳細訊息請上 Spotify.com 查詢
* Spotify 提供 30 天免付費使用Spotify Premium服務,可運用在您的Yamaha 家庭娛樂系統上。請參閱: [You must be registered and logged in to see this link.]
* Spotify 服務因地而異.
Easy and convenient operation. This AV receiver lets you use the Yamaha AV Controller App that is downloadable from iTunes®, Google Play or the Amazon Appstore to control the power, volume, input selections, DSP modes and much, much more from an iPhone® or Android™ device. You can also use as many as 23 different languages and customize the interface by hiding unused icons and renaming functions. A tablet version is also available.
此 AV 擴大機讓你能使用由 iTunes App Store 或 Google Play免費下載的 Yamaha AV Controller app 控制開關、音量、選擇輸入源以及 DSP 模式,也可以從 iPhone 與 Android 設備執行其他功能。你可以最多切換23種不同的語言以及長按不使用的圖示、重新命名功能以客製化使用面板。平板也能夠支援。
Find every dimension. Enter a new world of sound with Dolby Atmos and DTS:X. These sound technologies transport you from an ordinary moment into an extraordinary experience with captivating, multidimensional sound that fills your room with amazing richness and depth. Music, people, and objects come alive in breathtaking detail and flow in precise choreography all around you, making you feel like you are truly there. These new sound technologies will fill the room with multidimensional sound that makes you feel as if you are right in the middle of the story unfolding on the screen.
這些環繞音效技術將平凡的每個瞬間轉換至驚奇非凡的音效,以驚人豐富性與聲音深度填滿您家客廳。令人嘆為觀止的音樂、人物及物體都將靈活地呈現在您眼前,有如身臨奇境。
即使您的居家環境難以在視聽室後方架設環繞揚聲器,透過 Virtual CINEMA FRONT 功能,將環繞揚聲器擺放在前方,您將享受到高品質和高解析的虛擬 7 聲道環繞音效。新增兩個額外前置臨場揚聲器,提供3D音場具高度與深度、距儀動感的聲音。您可靈活的配置空間內的揚聲器,更加輕易的享受高品質環繞音效。
Wide, high, and dense sound. CINEMA DSP 3D provides a wide, high and dense sound field. HD Audio format decoding lets you enjoy HD Audio sources. Virtual Presence Speaker delivers three-dimensional sound without the actual use of presence speakers.
虛擬臨場揚聲器功能讓中置及環繞揚聲器創造出虛擬臨場效果。就算在安裝條件有限的情況下,也能體驗CINEMA DSP 3D環繞音效。此擴大機也擁有後方環繞揚聲器功能,讓您可以在無後方環繞揚聲器的情況下,也能體驗來自後方的自然音調。
再者 YPAO R.S.C. 可優化聆聽環境及高品質基本訴求的音響設計,完全能運用杜比全景聲音訊空間定位微細處理能力。將杜比全景聲與 Yamaha AV 接收器結合,可使空間充滿多向性音源,讓您在螢幕前即能聲歷其境於情節之中。
This AV receiver is compatible with many audio formats such as Dolby® True HD and DTS-HD Master Audio™. It is also compatible with high-resolution audio codecs such as DSD/AIFF/FLAC/WAV/Apple® Lossless. You will enjoy the excellent sound quality of these various high-resolution audio codecs from the USB input on the front panel or from network connected devices.
這款影音擴大機與許多音頻格式相容,如Dolby True HD和 DTS-HD Master Audio。它同時也支援 DSD / AIFF / FLAC / WAV / Apple Lossless (Apple無失真) 音頻解碼。有了這些功能,您將可享受USB和網路播出的優異音質。
Chris 012-2309169
BRANDED led tv
amplifier
speaker
cd player
SPECIFICATIONS
RX-A1070
Amplifier Section Channel 7.2
Rated Output Power (1kHz, 2ch driven) 120 W (8 ohms, 0.9% THD)
Rated Output Power (20Hz-20kHz, 2ch driven) 110 W (8 ohms, 0.06% THD)
Maximum Effective Output Power (1kHz, 1ch driven) (JEITA) 165 W (8 ohms, 10% THD)
Dynamic Power per Channel (8/6/4/2 ohms) 135 / 165 / 210 / 280 W
Surround Sound Processing CINEMA DSP Yes (HD3)
DSP Programs 24
Dialog Level Adjustment Yes
Virtual Presence Speaker Yes
Virtual Surround Back Speaker Yes
Dialogue Lift Yes (no presence speakers required)
SILENT CINEMA / Virtual CINEMA DSP Yes (Virtual CINEMA FRONT)
Dolby Atmos Yes
Dolby TrueHD Yes
Dolby Digital Plus Yes
Dolby Surround Yes
DTS:X Yes
DTS-HD Master Audio Yes
Audio Features Pure Direct Yes (with video on mode)
Compressed Music Enhancer Yes
High-resolution Music Enhancer Yes
YPAO multi-point measurement Yes with R.S.C. (Reflected Sound Control) and 64-bit Precision EQ Calculation
YPAO Volume Yes
Adaptive DRC (Dynamic Range Control) Yes
Initial Volume & Maximum Volume Setting Yes
A.R.T. Wedge Yes
Bi-amp capability Yes
Audio Delay Yes (0-500 ms)
192kHz/24-bit DACs for all channels Yes (ESS)
Video Features 4K Ultra HD Pass-through and upscaling Yes (4K / 60p, 4:4:4)
HDMI 3D passthrough Yes
HDMI Audio Return Channel Yes
HDMI upscaling Yes (Analog to HDMI® / HDMI to HDMI)
Deep Color/x.v.Color/24Hz Refresh Rate /Auto Lip-Sync Yes
Connectivity HDMI Input/Output 8 / 2 (HDCP2.2, HDR10 / Dolby Vision / HLG and BT.2020 compatible)
HDMI CEC Yes (SCENE, Device Control)
USB Input USB Memory, Portable Audio Player
Network Port Yes
Wi-Fi Yes (with Wireless Direct)
AirPlay Yes
Bluetooth Yes (SBC / AAC)
Front AV Input HDMI / USB / Analog Audio
Digital Audio Input/Output: Optical 3 / 0
Digital Audio Input/Output: Coaxial 3 / 0
Analog Audio Input/Output 9 (front 1) / 0
Phono Input Yes
Component Video Input/Output 2 / 0
Composite Video Input/Output 4 / 0
Preout 7.2-ch
Headphone Output 1
Tuner Section FM/AM Tuner Yes
User Interface On-screen display Graphical User Interface
SCENE SCENE PLUS (12 sets)
App Control Yes (iPhone / iPad / Android phone / tablet)
Web Browser Control Yes
Remote Control Unit Yes
Zone Control Zone 2 Audio Output Preout / HDMI
Powered Zone Zone 2
Zone Video Output HDMI / Component / Composite
Zone HDMI Yes (HDMI Zone Switching)
Zone B Output HDMI
RS-232C Interface Yes
+12V Trigger Output 2
Remote (IR) Input/Output 1 / 1
Party Mode Yes
General Standby Power Consumption (IR only) ≤0.1W
Auto Power Standby Yes
ECO mode Yes
Dimensions (W x H x D) 17-1/8” x 7-1/8” x 17-1/4” (with antenna up: 17-1/8” x 9-3/4” x 17-1/4”)
Weight 32.8 lbs.
- The AVENTAGE Advantage: Designed to deliver the highest levels of audio performance through engineering
- Aluminum front panel with door, symmetrical amplifier layout, H-shaped cross frame
- 7.2-channel Dolby Atmos and DTS:X (5.1.2-ch)
- 9 speaker terminals with Intelligent Amp Assign for Zone 2
- Add audio in up to 9 additional rooms with MusicCast
- 8-in, 2-out HDMI
- 4K Ultra HD pass-through with HDCP 2.2 support, HDR video including Dolby Vision and Hybrid Log-Gamma, and BT .2020
- Advanced HDMI zone switching (Zone 2)
- High-performance digital-to-analog conversion (ESS SABRE Premier Audio DAC ES9006A)
- Fully loaded with Wi-Fi, Bluetooth, AirPlay, Spotify Connect, TIDAL, and Deezer music streaming service
- Stream Pandora, Spotify, Napster, SiriusXM Internet Radio and thousands of free internet radio stations
- DSD 2.8 MHz / 5.6 MHz, FLAC / WAV / AIFF 192 kHz / 24-bit, Apple Lossless 96 kHz / 24-bit playback
- Phono input to connect to your favorite turntable
- Room acoustics optimization using YPAO - R.S.C., 64-bit precision EQ calculation and angle measurement
- CINEMA DSP HD3 可融合Dolby Atmos 或 DTS:X 進行播放
- 後環繞的 CINEMA DSP HD3 (虛擬臨場揚聲器)
- Enhanced – 全新開發的CINEMA DSP程式
- AVENTAGE AV影音擴大機: 設計於傳達最高質量的音訊表現
- 兼顧視覺及聽覺的鋁質面板
- A.R.T. Wedge 防振技術,有效降低振動不影響聲音品質
- 堅固腳架為機身提供更好的穩定性
- 對稱的功率放大器佈局,H型交叉框架以及高剛性底盤
- 專業高品質的ESS DAC
- MusicCast 讓你於每個空間享受音訊串流的喜悅
- 7 聲道強力環繞音效
- --- 每聲道 110 W (8 ohms, 20 Hz-20 kHz, 0.06% THD, 2-ch driven)
- --- 每聲道 165 W (8 ohms, 1 kHz, 10% THD, 1-ch driven)
- --- 每聲道 170 W (4 ohms, 1 kHz, 0.9% THD, 1-ch driven)
- 內建 Wi-Fi 和 無線直連相容可輕易設定連接
- 藍牙相容支援無線音樂串流功能且配有音樂增強功能優化壓縮音樂
- AirPlay, Spotify* 等音樂串流服務及AV Controller app
- *音樂串流服務視地區而有不同
- 支援 DSD 2.8 MHz / 5.6 MHz, FLAC / WAV / AIFF 192 kHz / 24-bit, Apple Lossless 96 kHz / 24-bit
- 能提升原音質內容的高解析音樂優化功能
- HDMI (8 進 / 2 出) 4K Ultra HD 完整支援 4K / 60p, HDCP2.2, HDR Video (含Dolby Vision與Hybrid Log-Gamma)以及BT.2020 直通
- HDMI 輸入於前面板,前面板USB埠可連接USB隨身碟
- YPAO R.S.C. (反射聲音控制)3D聲音優化,64位元EQ計算與揚聲器角度測量
- YPAO Volume 確保聲音即使在低音量中,也能保持自然的音調
- 先進的HDMI 區域切換功能,帶來獨有的影音切換功能至多區
- 可拆卸電源線便於安裝
Craftsmanship in engineering design. The AVENTAGE line of high-performance AV receivers is based on the audio design concept of providing a massive, full-bodied sound for movie sound effects and the accurate reproduction of music sources. By expertly harmonizing traditional and advanced technologies, every factor that affects sound quality, from materials and parts to construction, layout, vibration damping (unique foot) and “fine-tuning” the sound, is handled with no other thought than to achieve the best possible audio quality. As a result, every AVENTAGE model has the ability to reproduce the most subtle details of high-definition sound, so that listeners can enjoy a truly high-class sound studio experience at home.Total Purity
最佳音質,完全純音概念 (Total Purity Concept)
High Quality Parts for Optimum Performance
The whole is greater than the sum. Every single part in an AV receiver affects the sound quality. For AVENTAGE models, extra time is taken to find (or develop) the exact parts needed to achieve the highest performance possible. Sound technicians go through a testing process to, in effect, “tune” the receiver’s sound.高品質組件帶來卓越的音效表現
每個零件皆會影響AV擴大機的聲音品質。Yamaha針對AVENTAGE 型號花了很多時間尋找(或開發) 高效能表現所須要的組件。調音師透過一連串的測試,有效的調整擴大機的聲音,以達到最佳性能。* 有些零件並不含在此機型內
Professional Quality Digital Audio
超高性能DACs 帶來極佳的音質表現
Symmetrical Power Amplifier
對稱的功率擴大器配置
Anti-Resonance Technology Foundation
Advanced Design Feet
Foot fetish. The feet of the receiver feature a newly designed, high-density structure which utilizes two different kinds of interior ribs — straight and curved — to enhance strength and damping performance. Installation stability is improved and chassis resonance is dispersed, effectively eliminating external vibration. The low-range response is enhanced, while resonance peaks in the mid- and high-range are reduced, providing dynamic sound and accurate reproduction.先進腳架設計提升強度與防震
RX-A1070 的全新、高密度腳架設計使用兩種不同的內部結構 - 直立以及彎曲 - 增強強度以及阻尼的表現。改善安裝的穩定性、底盤共振分散因此有效消除了外部震動。增強了低範圍響應並減緩了中高頻範圍的諧振峰值,提供動態的聲音與準確的聲音重現。Aluminum Front Panel
兼顧視覺及聽覺的鋁質面板
H-shaped Frame
H 型交叉框架
4K Ultra HD Full Support
Darker blacks, whiter whites, and more vivid colors. This AV receiver completely supports with latest HDMI® standards. Thanks to transmission of 4K video at 60 frames per second pass-through, you can fully enjoy the high definition video quality of 4K without degradation. It also adheres to the HDCP 2.2 copyright protection standard for 4K video transmission. It also supports HDR (High Dynamic Range) Video including Dolby Vision and Hybrid Log-Gamma which provides incredible contrast, smooth tone and rich, bright colors. Furthermore it supports the wider color gamut of BT.2020 pass-through. This AV receiver is also compatible with 3D, Audio Return Channel and CEC for easy operation.*Dolby Vision and Hybrid Log-Gamma will be available via future firmware update.
此 AV 擴大機完整支援最新的HDMI®格式。每秒60幀率的4K影像通過(pass-through)效能,讓您能拋開降頻煩惱,盡情享受4K高畫質影像。本產品亦支援4K影像傳輸的高畫質數位內容保護標準(HDCP2.2 )以及HDR (高動態範圍)影片(包含Dolby Vision與Hybrid Log-Gamma,提供完美對比、平滑顏色以及豐富飽滿的顏色)。此外,支援BT.2020直通,提供更廣闊的色域。此 AV 擴大機也搭載 3D, 音訊回傳聲道與 CEC ,提供簡易操作。* Dolby Vision與 Hybrid Log-Gamma 將透過韌體更新支援。
Advanced Graphical User Interface
Multilingual user interface. The latest graphical user interface from Yamaha has a high-resolution display with clear, easy-to-use menus and also includes a selectable status bar that shows input source, volume level, DSP mode and audio format. The GUI provides a choice of eight languages: English, French, German, Spanish, Italian, Russian, Japanese and Chinese and can be displayed over both normal and 3D pictures.先進的多語言GUI螢幕顯示
Yamaha 的最新圖示使用者介面 (GUI) 有高解析度顯示的操作簡易選單,另外還有一個可選狀態功能條,顯示輸入源、音量、DSP模式與音頻格式。GUI 共有8種語言任您選擇:英文、法文、德文、西班牙文、義大利文、俄文、日文和中文,可選擇以正常或 3D 圖片顯示。MusicCast
Access all of your music with a simple app and wirelessly stream it throughout your home using your existing Wi-Fi® network.- Stream it all. Listen to Pandora, Spotify, Napster, SiriusXM Internet Radio, TIDAL, Deezer, thousands of free internet radio stations and the music stored on your smart devices and computers.
- Wireless connectivity. All MusicCast products are fully loaded with Wi-Fi, Bluetooth and AirPlay.
- Expand to a whole home audio experience. When you’re ready, add MusicCast wireless speakers, sound bars or other devices in up to 9 other rooms and listen throughout your home.
- No wires, easy installation. By using MusicCast, you don't need to fuss with placing wires through walls into other rooms.
Bluetooth®
Play your favorite streaming service. This AV receiver is equipped with Bluetooth functionality to let you enjoy easy wireless music playback from mobile devices. The Compressed Music Enhancer from Yamaha is now optimized for Bluetooth audio transmissions to ensure that your music will have vivid, lively sound quality during wireless playback.藍牙相容支援無線音樂串流功能
此 AV擴大機 具備藍牙功能,讓您能以智慧型手機或其他行動裝置與本機配對,輕鬆享受無線音樂播放的便利。Yamaha的壓縮音樂增強技術 (Compressed Music Enhancer) 針對藍牙音訊傳輸,進行最佳化工程。確保無線播放時,您的音樂能有生動活潑的音質表現。Bluetooth Output
In and Out. The RX-A1070 is equipped with the latest Bluetooth technology, making wireless operation more convenient than ever. You can stream music from the RX-A1070 to Bluetoothheadphones for private listening or to Bluetooth speakers.藍牙輸出功能-便利的音樂串流
RX-A1070具備最新的藍牙傳輸技術。使無線傳輸比以往更加方便。您可以透過藍牙由RX-A1070傳輸音樂至藍牙耳機以及藍牙揚聲器。Airplay®
AirPlay 讓 AV擴大機能串流音樂
* 部份機種不支援顯示專輯封面
Network Functions
Access more. This AV receiver provides a variety of network functions that enable you to access more sources and also enhance operation. You can connect the receiver to your home network or internet to enjoy Internet Radio, Spotify®*, Pandora®* or music stored on a NAS and home PC. The AV Controller app (from iTunes App Store or Google play) lets you control various functions from your iPod, iPhone, iPad or Android phones / tablets.網絡功能
這款 AV 綜合擴大機提供多種網絡功能,能讀取更多來源,更加強操作性能。可將綜合擴大機連接至個人電腦,享受網路廣播,以網路瀏覽器控制器來操作系統。影音遙控器app (由iTune App 商店或Google play) 讓你由iPod, iPhone, iPad or Android 手機上控制綜合擴大機的多種功能。*音樂串流服務視地區而有不同
Spotify Connect
Spotify Connect 串流數百萬首歌曲
* Spotify 服務因地而異.
Wi-Fi® and Wireless Direct
Smarter connectivity. Built-in Wi-Fi allows for a wireless connection with your wireless router, greatly simplifying system connections for enjoying networked audio (PC / NAS) and music streaming services. If a Wi-Fi router is not available, the unique Wireless Direct feature not only allows you to stream music directly from your smartphone or tablet via the AV Controller App, AirPlay® etc., but also allows for control of the AV receiver as well.內建 Wi-Fi 和 無線直連相容可輕易設定連接
內建 Wi-Fi 相容可無線連接您的室內無線路由器,大幅簡化系統連接,輕鬆享受網路音頻和音樂串流服務。即使在無 Wi-Fi 路由器可使用的環境下,獨特的無線直連功能(Wireless Direct),不僅可讓您透過 AV 遙控器應用程式(AV Controller app) 的音樂播放功能和 Apple AirPlay等,直接串流智慧型手機或平板電腦裡的音樂,更可透過app 應用程式操控擴大機。AV Controller App
AV Controller App 為您帶來更多操作便利及樂趣
與 Dolby Atmos® / DTS:X™ 一同進入環繞新世界
Enhanced CINEMA DSP HD3
Thrilling realism in surround sound. With this year marking thirty years since the release of the first DSP-1 unit in 1986, Yamaha has continued its history of innovation with the development of the Enhanced next-generation CINEMA DSP. This sound field program is installed in the receiver and features a new sound field processing algorithm that further elevates its ability to process the motion and spatial representation data found in the latest audio-visual media. This includes three-dimensional surround formats like Dolby Atmos and DTS:X. The result is a natural sound field effect that follows every sound source, including objects present in the most modern formats and delivers dynamic sensations of motion and spatiality.CINEMA DSP HD3 結合 Dolby Atmos 或 DTS-X 搭配播放
此AV擴大機支援Dolby Atmos 或 DTS:X等最新的環繞音效格式與CINEMA DSP融合的CINEMA DSP HD3。帶您進一步享受天空聲道環繞音。 改善後的CINEMA DSP HD3提供了新的信號處理計算以及高性能處理器。為了展現最佳的影院效果,精準的重現擬真音場、真實感與無邊界的感覺。你將會感受到真實的影院音場與身歷其境的效果。Virtual CINEMA FRONT
Virtual CINEMA FRONT 提供虛擬 7 聲道高品質、高解析度的環繞音效
Enjoy virtual surround sound. Even when it is impossible to install surround speakers behind the listening position, Virtual CINEMA DSP reproduces virtual 7-channel surround sound filled with realism, from only two front speakers. The Virtual CINEMA FRONT feature lets you place two surround speakers and a center speaker at the front to enjoy virtual 7-channel surround sound with even higher quality and resolution, as well as superior rear virtual sound localization. Adding two additional front presence speakers provides a three-dimensional sound field that gives you a feeling of its height and depth and of the vertical movement of the sound. You get more flexibility to arrange your speakers inside the room, along with easy enjoyment of high quality surround sound.即使您的居家環境難以在視聽室後方架設環繞揚聲器,透過 Virtual CINEMA FRONT 功能,將環繞揚聲器擺放在前方,您將享受到高品質和高解析的虛擬 7 聲道環繞音效。新增兩個額外前置臨場揚聲器,提供3D音場具高度與深度、距儀動感的聲音。您可靈活的配置空間內的揚聲器,更加輕易的享受高品質環繞音效。
Virtual Presence and Surround Back Speakers
虛擬臨場揚聲器及虛擬後方環繞揚聲器
Speaker Layout Patterns
Multiple placement patterns are available for presence speakers that support Dolby Atmos & DTS:X, creating a sound field that’s ideal for your setup. Any layout can be appropriately reproduced, including the three-dimensional space of CINEMA DSP as well as both sound formats.為 Dolby Atmos 杜比全景聲設計的揚聲器配置模式
Yamaha 提供多聲源模式可支援杜比全景聲,適合為您的裝置創造音場。在任何的設置均能夠適宜地重現,包含 CINEMA DSP 與杜比全景聲的 3D 空間。再者 YPAO R.S.C. 可優化聆聽環境及高品質基本訴求的音響設計,完全能運用杜比全景聲音訊空間定位微細處理能力。將杜比全景聲與 Yamaha AV 接收器結合,可使空間充滿多向性音源,讓您在螢幕前即能聲歷其境於情節之中。
Codec Support
大量音頻解碼與格式支援
Chris 012-2309169
BRANDED led tv
amplifier
speaker
cd player
SPECIFICATIONS
RX-A1070
DSP Programs 24
Dolby Atmos Yes
Dolby TrueHD Yes
Dolby Surround Yes
DTS:X Yes
YPAO Volume Yes
A.R.T. Wedge Yes
Network Port Yes
AirPlay Yes
Phono Input Yes
Preout 7.2-ch
Headphone Output 1
Powered Zone Zone 2
Zone B Output HDMI
Party Mode Yes
ECO mode Yes
Weight 32.8 lbs.
- Number of posts : 1323
» Yamaha AVENTAGE RX-A3070 9.2CH Atmos Network AV Receiver (Sold Out)
» Yamaha Aventage RX-A4A 7.2Ch. 8K Atmos Network AV Receiver (PL)(Sold Out)
» Yamaha Aventage RX-A6A 9.2Ch 8K Atmos Network AV Receiver
» Yamaha AVENTAGE RX-A870 7.2Ch Atmos Network AV Receiver (Sold Out)
» Yamaha AVENTAGE RX-A2070 9.2CH Atmos Network AV Receiver (Sold Out)
