Marantz NR1508 5.2Ch Network Av Receiver (Sold Out)
Marantz NR1508 5.2Ch Network Av Receiver Brand New, Now Selling at RM2399.
Free Shipping Within West Malaysia.
Designed to deliver a thrilling sonic experience, the NR1508 AV Receiver features expanded connectivity including built-in HEOS wireless multi-room audio technology, to enable you to enjoy your favorite music anywhere and everywhere around your home. You can explore and play music from your own music library, from online streaming music services, and from thousands of Internet radio stations using the free HEOS app for smartphones and tablets, with high resolution audio fully supported for incredible fidelity. The NR1508 also features Bluetooth and AirPlay compatibility to stream music directly from any compatible device. For high resolution surround from your favorite movie soundtracks the NR1508 is equipped with advanced 32-bit DSP processing supporting all the major sound formats, including Dolby TrueHD and DTS-HD Master Audio. Its power amplifier section features high current discrete power transistors and identical circuit topology for all 5 channels, and is compatible with low impedance 4 ohm speakers.
The video section features 6 HDMI inputs (including 1 on the front panel), with full compatibility with the latest 4K Ultra HD video specification, including 60 Hz full rate content, 4:4:4 Pure Color sub-sampling, BT.2020, HDR and Dolby Vision compatibility. It's also HDCP 2.2 compliant, for 4K Ultra HD copy-protected content. HLG (Hybrid Log Gamma) pass-through for future HDR broadcast content will be supported via a firmware update.
The "Marantz 2016 AVR Remote" app is also available free from the Apple app store, GooglePlay and the Amazon app store.
能带来震撼音响体验,NR1508 AV接收机具备扩展的连通性,包括内置HEOS(HEOS为同属集团品牌Denon旗下多房间产品系列,HEOS 1和HEOS 7预计于今年9月在中国大陆上市)无线多房间音频技术,能让您在住宅各处和周围任何地方欣赏最喜欢的音乐。使用适合智能手机和平板电脑的免费HEOS app,可从自己的音乐库、从在线串流音乐服务和从数以千计的互联网电台探索和播放音乐,完全支持高解析度音频,有令人难以置信的保真度。NR1508还支持蓝牙和AirPlay,可直接从任何兼容设备串流音乐。为从您最喜欢的电影原声带获得高解析度环绕声,NR1508配备了高级32位DSP处理能力,支持众多主要声音格式,包括Dolby TrueHD和DTS-HD Master Audio。其功放部分为所有5条声道配备了高电流分离式功率晶体管和完全相同的电路结构,且兼容低阻抗4欧姆扬声器。
视频部分配备6个HDMI输入(包括1个在前面板),完全兼容最新的4K超高清视频规格,包括60 Hz全速率内容、4:4:4纯色子采样、BT.2020、HDR和Dolby Vision兼容性。还兼容HDCP 2.2协议,用于4K超高清版权保护内容。通过固件更新将支持HLG (Hybrid Log Gamma)直通,将来用于HDR节目内容。 与HEOS app一样,Android 和iOS 版的“Marantz 2016 AVR Remote”控制app可分别从Apple应用商店、马兰士官网免费获取。
Powerful 5 Channel Discrete Amplifier with Eco Mode
The NR1508's power amp section features discrete high-current output devices for superb sound with both music and movies, with, identical power on all 5 channels for precision sound. Rated at 50 watts per channel (8 ohm, 20 Hz – 20 kHz, 0.08% THD), the NR1508 features low-impedance drive capability, for excellent speaker control, and is compatible with 4 ohm speakers too. Meanwhile the Eco mode provides energy savings: it features an on-screen Eco meter, while it’s also possible to use the receiver in power-saving mode, either reducing the maximum output power or adopting low-power strategies at more modest settings – and all without any effect on the superb sound quality.
带Eco模式的强大5声道分离式放大器
NR1508的功放部分具备分离式高电流输出的功放部分具备分离式高电流输出器件,给音乐和电影带来超凡的音响,全部5个声道具有完全相同的功率,声音非常准确。额定每声道85瓦,NR1508具备低阻抗驱动能力,实现极佳的扬声器控制,并且还兼容4 Ω扬声器。它具备屏上节能显示功能,并且还能以节能模式使用接收机,要么降低最大输出功率,要么以最适度的设置采用低功耗策略——而所有这一切对超凡音质毫无影响。
Latest HDMI Connectivity
HDR, Dolby Vision, HLG, and HDCP 2.2 Compatible
Six HDMI inputs – including one on the front panel for quick connections – feed the NR1508's advanced video section, supporting the latest HDMI specification, including 4K Ultra HD 60Hz video, 4:4:4 Pure Color sub-sampling, BT.2020 and HDR pass-through support on every input. Dolby Vision compatibility is now supported, too, along with pass-through for new HDR broadcast format HLG (Hybrid Log Gamma) to be enabled via a future firmware update.
HDCP 2.2 compatibility on all HDMI inputs, for 4K Ultra HD copy-protected content, ensures the NR1508 is ready for the next generation of Blu-ray disc players, set-top boxes and 4K Ultra HD streams and downloads. The NR1508 also features Audio Return Channel (ARC), which lets you stream audio from your TV via a single HDMI connection (no need for a separate digital audio cable).
最新HDMI连接能力;HDR、
Dolby Vision、HLG和HDCP 2.2兼容
六个HDMI输入(包括一个位于前面板,便于快速连接)给NR1508的高级视频部分输送信号,每个输入都支持最新的HDMI规格,包括4K超高清60Hz视频、4:4:4纯色子采样、BT.2020和HDR直通。现在支持Dolby Vision兼容性,将来通过固件更新可启用新的HDR广播格式HLG (Hybrid Log Gamma)直通。 所有HDMI输入均具有用于4K超高清版权保护内容的
HDCP 2.2兼容性,确保NR1508为下一代蓝光光盘播放机、机顶盒及4K超高清串流和下载做好准备。NR1508还配备音频返回通道(ARC),能让您通过单个HDMI连接(无需另外的数字音频电缆)从您的电视机串流音频。
Built-in Bluetooth, Wi-Fi, and AirPlay
The NR1508 is equipped with an advanced dual antenna system for Bluetooth and Wi-Fi streaming, for a robust connection even in congested urban environments. Apple's AirPlay lets you listen to your favorite tracks wirelessly from iOS devices such as iPhones and iPads.
内置蓝牙、Wi-Fi和AirPlay
NR1508配备适用于蓝牙和Wi-Fi串流的高级双天线系统,即使在繁忙的城市环境也有强悍的连接能力。Apple的AirPlay能让您从iPhones和iPads等iOS设备无线聆听您最喜欢的曲目。
HEOS: The Perfect Solution for Wireless Multi-Room Music Streaming
With built-in HEOS technology, the NR1508 becomes a key component of the HEOS wireless multi-room system. Add more HEOS speakers, and enjoy your music anywhere and everywhere around your home, all controlled via the free HEOS app. Play the same song in every room, or a different song in every room.
Multiple streaming services can be played on the NR1508 or any other connected HEOS devices, including Pandora, Spotify, TuneIn Internet Radio, Amazon Music, SiriusXM, iHeartRadio, Sound Cloud, Tidal, Napster or Deezer (*). You can also stream music from your phone, USB stick, or local network drives, with favorites and playlist functions supported.
*Availability differs by area, subscription may be required.
HEOS:无线多房间音乐串流的完美解决方案
通过内置HEOS技术,NR1508成为HEOS无线多房间系统的关键组成部分。添加更多HEOS扬声器,在住宅各处和周围任何地方欣赏您的音乐,一切均通过免费的HEOS app控制。在每个房间中播放相同的歌曲,或在每个房间中播放不同的歌曲。
多个串流服务可以在NR1508上播放也可以在任何其他所连接HEOS设备上播放,包括TuneIn互联网收音机等 (*)。您还可以从手机、USB存储棒或本地网络驱动器串流音乐,且支持收藏夹和播放列表功能。
* 可用性因地区而异,可能需要订阅。
The Marantz 2016 AVR Remote app for iOS and Android smartphones and tablets gives you complete control over the latest Marantz network AV Receivers. Along with many new features, the graphics and user interface have been completely overhauled. Control power, volume, input and settings, or switch instantly to the HEOS App to access your music content and streaming services, with full HEOS wireless multi-room control.
适用于iOS和Android智能手机和平板电脑的Marantz 2016 AVR Remote app赋予您对最新马兰士网络AV接收机的全权控制。除了众多新功能之外,图形和用户界面经过了彻底更新。通过完整的HEOS无线多房间控制,控制电源、音量、输入和设置,或即时切换至HEOS App访问您的音乐内容和串流服务。
Hi-Res Audio
The NR1508 lets you discover the incredible fidelity of high resolution audio tracks via the front panel USB port or network sources, with the ability to decode ALAC, FLAC and WAV lossless files up to 24-bit/192-kHz, as well as DSD 2.8MHz and 5.6MHz tracks (the audiophile format of SACD). You can also listen to other popular file types, such as MP3.
Chris 012-2309169
BRANDED led tv
amplifier
speaker
cd player
SPECIFICATIONS
Marantz NR1508 specs
Main Unit
Channels 5.2
Power Output per Channel 50 W @ 8 Ohms, 20 Hz to 20 kHz, 0.08% THD
Signal to Noise Ratio Not specified by manufacturer
Frequency Response Not specified by manufacturer
Audio Formats Supported Dolby TrueHD, DTS-HD Master Audio
Video
Pass-Through 4K/60 Hz, 4:4:4 Pure Color, BT.2020, HDR10, and Dolby Vision
HDCP Compliance 2.2
Connectivity
Wi-Fi Yes, dual-band 2.4 / 5 GHz
Bluetooth Yes
AirPlay Yes
Audio Return Channel (ARC) Yes
Inputs 6 x HDMI (1 front)
3 x composite video
3 x stereo RCA audio
1 x optical TOSLINK
1 x digital coaxial
Outputs 1 x HDMI
1 x composite video
2 x RCA subwoofer pre-out
Other Ports 1 x USB (front)
1 x AM antenna
1 x FM antenna
1 x AC power
General
Power Requirements Not specified by manufacturer
Standby Power Consumption 0.2 W
Dimensions (W x H x D) 17.3 x 4.1 x 14.8" (440 x 105 x 376 mm)
Weight 17.9 lb (8.1 kg)
Packaging Info
Package Weight 23.0 lb
Box Dimensions (LxWxH) 20.4 x 18.5 x 7.6"
Key Features
- 5-channel discrete power amplifier, 50W per channel (8 ohm, 20 Hz – 20 kHz, 0.08% THD).
- 4K/60 Hz full-rate pass-through, 4:4:4 color resolution, HDR and BT.2020, plus Dolby Vision compatibility and Hybrid Log Gamma (HLG; via future firmware update).
- 6 HDMI inputs (incl. 1 front) with full HDCP 2.2 support.
- Dolby TrueHD and DTS-HD Master Audio.
- Built-in Wi-Fi with 2.4GHz/5GHz dual band support.
- HEOS wireless multiroom integration.
- AirPlay, Bluetooth, TuneIn Internet Radio, Pandora, Spotify, Tidal, Deezer, Amazon Prime Music, SiriusXM, Napster, iHeartRadio, Sound Cloud, Network Audio Streaming.
- DSD (2.8/5.6MHz), FLAC, ALAC and WAV support.
- Audyssey MultEQ, Dynamic Volume and Dynamic EQ.
- Color-coded speaker terminals, Setup Assistant, Advanced GUI, Marantz 2016 AVR Remote App.
- Intelligent ECO mode with off/on/auto setting.
- 5声道分离功率放大器,每声道85 W(6 Ω,1 kHz,THD 1%,单声道驱动) 功率足以将著名的马兰士声音充满中等大小的房间
- 4K/60 Hz全速率直通、4:4:4彩色分辨率、HDR和BT.2020、外加Dolby Vision兼容和Hybrid Log Gamma(HLG;将来通过固件更新) 面向未来兼容性的最新HDMI标准
- 6个HDMI输入(包括1个前置),支持全HDCP 2.2 大量输入端口,足以连接蓝光播放机、游戏机等
- Dolby TrueHD和DTS-HD Master Audio 最新家庭影院环绕声格式
- 内置Wi-Fi并支持2.4GHz/5GHz双带宽 改善了网络稳定性,特别是在Wi-Fi拥挤的家庭
- HEOS无线多房间整合 联合其他HEOS扬声器/设备组成全住宅音响,均通过HEOS app控制
- AirPlay、蓝牙、互联网收音机等网络音频串流 访问几乎不受限制的在线音乐源
- 支持DSD (2.8/5.6MHz)、FLAC、ALAC和WAV文件 为Hi-Fi发烧友提供高解析度音频串流
- Audyssey MultEQ、Dynamic Volume(动态音量)和Dynamic EQ(动态均衡器) 为您的房间/扬声器带来完美的均衡 均衡参数的专业微调
- 颜色编码扬声器端子、设置助手、高级GUI、Marantz 2016 AVR Remote App 安装、设置和操作都很简单
- 带有关/开/自动设置功能的智能ECO模式 不妥协性能的节能模式
带Eco模式的强大5声道分离式放大器
最新HDMI连接能力;HDR、
内置蓝牙、Wi-Fi和AirPlay
* 可用性因地区而异,可能需要订阅。
Hi-Res Audio
Chris 012-2309169
BRANDED led tv
amplifier
speaker
cd player
SPECIFICATIONS
Main Unit
Channels 5.2
Video
HDCP Compliance 2.2
Connectivity
Bluetooth Yes
AirPlay Yes
3 x composite video
1 x optical TOSLINK
1 x digital coaxial
Outputs 1 x HDMI
1 x composite video
1 x AM antenna
1 x FM antenna
1 x AC power
General
Packaging Info
- Number of posts : 1318
» Marantz NR1509 Slim 5.2Ch Network Av Receiver (sold out)
» Marantz NR1608 7.2Ch Atmos Network Av Receiver (Sold Out)
» Marantz SR5012 7.2CH Atmos Network AV Receiver (Sold Out)
» Marantz SR6012 9.2CH Atmos Network AV Receiver (Sold Out)
» Marantz SR7015 9.2ch. 8K Atmos Network AV Receiver
