Marantz NR1608 7.2Ch Atmos Network Av Receiver (Sold Out)
Marantz NR1608 7.2Ch Atmos Network Av Receiver Brand New, Now Selling at RM3199.
Free Shipping Within West Malaysia.
A thrilling high-quality AV receiver occupying minimal space: that's the NR1608. High current discrete power amplifiers on all 7 channels deliver astonishing power and clarity, and it delivers immersive 3D surround sound thanks to both Dolby Atmos and DTS:X decoders, yet at just a little more than 3 inches tall it’s slim enough to slip into any TV cabinet. It’s fully compatible with the latest HDMI and HDCP 2.2 specifications on all 8 HDMI inputs, and will pass all the latest video formats – 4K 60Hz video, 4:4:4 Pure Color sub-sampling, BT.2020, HDR and Dolby Vision – from Blu-ray players, set-top boxes, games consoles and streamed/download 4K Ultra HD content to an Ultra HD TV or projector. For future HDR broadcast content, HLG (Hybrid Log Gamma) pass-through will also be supported via a firmware update.
Bluetooth and AirPlay can stream music directly from portable devices, while HEOS wireless multi-room music integration allows the NR1608 to become part of a complete home-wide music system. Explore and play your own music library, online streaming music services and thousands of Internet radio stations, using the free HEOS app.
The "Marantz 2016 AVR Remote" app is also available free from the Apple app store, GooglePlay and the Amazon app store.
佔用空間最小並擁有驚人音質的 AV 擴音機:那就是 NR1608。全部 7 個聲道上的高電流分離式功率放大器帶來令人驚嘆的勁道和清晰度,它利用杜比全景聲和 DTS:X 解碼器呈現沉浸式 3D 環繞聲,其高度僅約 3 英寸,薄得足以塞進任何電視機櫃。
全部 8 個 HDMI 輸入完全兼容最新的 HDMI 規格和 HDCP 2.2 規格,可將所有最新的視頻格式—— 4K 60Hz 視頻、4:4:4 純色子採樣、BT.2020、HDR 和 Dolby Vision ——從藍光播放機、機頂盒、遊戲機和串流/下載的 4K 超高清內容傳送到超高清電視機或投影機。為適應將來的 HDR 廣播內容,還將通過固件更新支持 HLG (Hybrid Log Gamma)直通。
利用藍牙和 AirPlay 可以從便攜式設備直接串流音樂,而 HEOS 無線多房間音樂整合使 NR1608 成為完整家庭音樂系統的一部分。使用免費的 HEOS app 搜索和播放您自己的音樂庫、在線串流音樂服務以及數以千計的互聯網電台。 “Marantz 2016 AVR Remote” app 也可以從 Apple 應用商店、GooglePlay 和 Amazon 應用商店免費獲取。
Key Features
主要特色(•)和用戶益處(o)
Powerful 7 Channel Discrete Amplifier with Eco Mode
The NR1608's power amp section features discrete high-current output devices for superb sound with both music and movies, with, identical power on all 7 channels for precision sound. Rated at 50 watts per channel (8 ohm, 20 Hz – 20 kHz, 0.08% THD), the NR1608 features low-impedance drive capability, for excellent speaker control, and is compatible with 4 ohm speakers too. Meanwhile the Eco mode provides energy savings: it features an on-screen Eco meter, while it’s also possible to use the receiver in power-saving mode, either reducing the maximum output power or adopting low-power strategies at more modest settings – and all without any effect on the superb sound quality.
帶 Eco 節能模式的強大 7 聲道分離式放大器
NR1608 的功率放大部份具備分離式高電流輸出組件,給音樂和電影帶來超凡的音響效果,全部 7 個聲道具有完全相同的功率,聲音非常準確。額定每聲道90 瓦,NR1608 具備低阻抗驅動能力,實現極佳的揚聲器控制,並且還兼容 4 Ω揚聲器。它具備屏幕節能顯示功能,並且還能以節能模式使用擴音機,想要降低最大輸出功率,還是要以最適度的設置採用低功率消耗策略——而所有這兩個選項都對超凡音質毫無影響。
Latest HDMI Connectivity; HDR, Dolby Vision, HLG, and HDCP 2.2 Compatible
Eight HDMI inputs – including one on the front panel for quick connections – feed the NR1608's advanced video section, supporting the latest HDMI specification, including 4K Ultra HD 60Hz video, 4:4:4 Pure Color sub-sampling, BT.2020 and HDR pass-through support on every input. Dolby Vision compatibility is now supported, too, along with pass-through for new HDR broadcast format HLG (Hybrid Log Gamma) to be enabled via a future firmware update.
HDCP 2.2 compatibility on all HDMI inputs, for 4K Ultra HD copy-protected content, ensures the NR1608 is ready for the next generation of Blu-ray disc players, set-top boxes and 4K Ultra HD streams and downloads, while the video processor can also upscale SD and HD video to 4K Ultra HD. Certified by the Imaging Science Foundation, the NR1608 features a full suite of video calibration controls for use by an ISF technician, along with ISF Day/Night video modes.
最新 HDMI 連接能力
;HDR、Dolby Vision、HLG 和 HDCP 2.2 兼容
八個 HDMI 輸入(包括一個位於前面板,便於快速連接)給 NR1608 的高級視頻部分輸送信號,每個輸入都支持最新的 HDMI 規格,包括 4K 超高清60Hz視頻、4:4:4 純色子採樣、 BT.2020 和 HDR 直通。現在支持 Dolby Vision 兼容性,將來通過固件更新可啟用新的 HDR 廣播格式 HLG (Hybrid Log Gamma) 直通。 所有 HDMI 輸入均具有用於 4K 超高清版權保護內容的 HDCP 2.2 兼容性,確保 NR1608 為下一代藍光光盤播放機、機頂盒及 4K 超高清串流和下載做好準備,同時視頻處理器還可以將 SD 和 HD 視頻升頻至 4K 超高清。獲得 ISF 認證,NR1608 具有全套視頻校準控件(供 ISF 工程師使用),配備 ISF 日間/夜間視頻模式。
Dolby Atmos
Feel every dimension in Dolby Atmos. Dolby Atmos transports you into the story with moving audio that flows all around you with breathtaking realism. Enjoy a 5.1 surround sound speaker system and 2 additional overhead speakers or 2 Dolby Atmos elevation speakers for the ultimate home theater experience - including Dolby Surround upmixer for legacy content.
杜比全景聲 (Dolby Atmos) 和 DTS:X
全方位感受杜比環繞聲。杜比全景聲通過具有驚人真實性的環繞移動聲音,讓您隨劇情變化如身臨其境。只需一個 5.1 環繞聲揚聲器系統和2個附加頂置揚聲器或2個杜比全景聲反射揚聲器,即可享受終極家庭影院體驗——同時也包括用於傳統內容的杜比環繞聲上混頻器。
DTS:X
Immersive audio places sound where it would occur naturally in space, creating a lifelike, multi-dimensional audio experience in the home. The improved immersion and heightened realism draw you into the world of your favorite movies. The included spatial remapping engine, DTS Neural:X™, gives your movie, game and music collections a new lease on life! DTS:X brings the theater home.
DTS:X™ 沉浸式音頻將聲音置於它在空中的自然發出位置,在家中創建逼真的多維音頻體驗。改善的包圍感和提高的真實性將您帶入最喜歡電影的世界。附帶的DTS Neural:X™空間重整引擎,給您昔日的電影、遊戲和音樂收藏帶來新生! DTS:X 帶來家庭影院到家中。
Built-in Bluetooth, Wi-Fi, and AirPlay
The NR1608 is equipped with an advanced dual antenna system for Bluetooth and Wi-Fi streaming, for a robust connection even in congested urban environments. Apple's AirPlay lets you listen to your favorite tracks wirelessly from iOS devices such as iPhones and iPads.
內置藍牙、Wi-Fi 和 AirPlay
NR1608 配備適用於藍牙和 Wi-Fi 串流的高級雙天線系統,即使在繁忙的城市環境也有強悍的連接能力。 Apple 的 AirPlay 能讓您從 iPhones 和 iPad 等 iOS 設備無線聆聽您最喜歡的曲目。
Chris 012-2309169
BRANDED led tv
amplifier
speaker
cd player
SPECIFICATIONS
AUDIO
Amplifier Output Details 50 Watt - 8 Ohm - 20 - 20000 Hz - THD 0.08% - 7 channels
AUDIO SYSTEM
Type AV network receiver
Subcategory AV components
Functions AV network receiver, digital player
Media Content Source Bluetooth, Network, USB-host
Supported Digital Audio Standards ALAC, DSD, FLAC, WAV
Sound Output Mode Surround Sound
Audio D/A Converter 24bit / 192kHz
Built-in Decoders DTS-HD Master Audio, DTS:X, Dolby Atmos, Dolby Surround, Dolby TrueHD, Dolby Vision
Surround System Class 7.2 channel
Additional Features Apple AirPlay support, Audio Return Channel (ARC), Audyssey Dynamic EQ, Audyssey Dynamic Volume, Audyssey MultEQ, HEOS wireless multi-room technology, dual-zone capability, smartphone remote controlled
High-Resolution Audio Yes
Digital Content Protection HDCP 2.2
HEADER
Brand Marantz
Product Line Marantz NR
Model 1608
Packaged Quantity 1
MISCELLANEOUS
Color black
Color Category black
AMPLIFIER OUTPUT DETAILS
Output Power / Channel 50 Watt
Output Impedance / Channel 8 Ohm
Frequency Response 20 - 20000 Hz
Total Harmonic Distortion (THD) 0.08 %
Channel Qty 7
RADIO
Tuner Type digital
Tuner Bands AM/FM
NETWORK & INTERNET MULTIMEDIA
Functionality Internet radio playback, digital audio playback
Connectivity Interfaces Bluetooth, IEEE 802.3 (Ethernet), IEEE 802.3u (Fast Ethernet), Wi-Fi
Internet Streaming Services Prime Music, Deezer, Napster, Pandora, SiriusXM internet radio, Spotify, TIDAL
SIGNAL PROCESSING FEATURES
HDMI Pass-Through up to 4K
Video Conversion/Scaling HDMI to HDMI scaling, analog to HDMI up conversion
3D Pass-Through Yes
Upscaling via HDMI up to 4K
CONNECTIONS
Type HDMI input, monitor output, network, remote control input, remote control output, subwoofer output, HDMI output, SPDIF input, USB, audio line-in, audio line-out (multi zone), component video input, composite video input
Qty 1, 2, 3, 7
Connector Type 19 pin HDMI Type A, RCA x 3, RJ-45, TOSLINK, 4 pin USB Type A, RCA, RCA x 2
Connector Location front, rear
Upscaling via HDMI Up to 4K
HDMI Pass-Through Up to 4K
Video Conversion/Scaling Analog to HDMI up conversion, HDMI to HDMI scaling
GENERAL
ManufacturerMarantz America Inc.
Key Features
- 7-channel discrete power amplifier, 50W per channel (8 ohm, 20 Hz – 20 kHz, 0.08% THD).
- 4K/60 Hz full-rate pass-through, 4:4:4 color resolution, HDR and BT.2020, plus Dolby Vision compatibility and Hybrid Log Gamma (HLG; via future firmware update).
- 8 HDMI inputs (incl. 1 front) with full HDCP 2.2 support.
- Dolby Atmos (up to 5.1.2) and DTS:X.
- Built-in Wi-Fi with 2.4GHz/5GHz dual band support.
- HEOS wireless multiroom integration.
- AirPlay, Bluetooth, TuneIn Internet Radio, Pandora, Spotify, Tidal, Deezer, Amazon Prime Music, SiriusXM, Napster, iHeartRadio, Sound Cloud, Network Audio Streaming.
- DSD (2.8/5.6MHz), FLAC, ALAC and WAV support.
- Audyssey MultEQ, Dynamic Volume and Dynamic EQ.
- Audyssey MultEQ Editor app support (available for US $20 in the App store)
- Color-coded speaker terminals, Setup Assistant, Advanced GUI, Marantz 2016 AVR Remote App.
- Intelligent ECO mode with off/on/auto setting.
主要特色(•)和用戶益處(o)
- 7 聲道分離功率放大器,每聲道 90 W
o 功率足以將著名的馬蘭士聲音填滿中等大小的房間 - 4K/60 Hz 全速率直通、4:4:4 彩色分辨率、HDR 和 BT.2020、外加 Dolby Vision 兼容和 Hybrid Log Gamma(HLG;將來通過固件更新)
o 面向未來兼容性的最新 HDMI 標準 - 8 個 HDMI 輸入(包括1個前置),支持全 HDCP 2.2
o 大量輸入端口,足以連接藍光播放機、遊戲機等 - 對傳統視頻源進行模擬至 HDMI 轉換和 SD/HD 至 4K 升頻
o 現有 DVD 或模擬源獲得全高清甚至超高清視頻品質 - 杜比全景聲(高達 5.1.2)和 DTS:X
o 擁有頂置音場的沉浸式 3D 聲音 - 內置 Wi-Fi 並支持 2.4GHz/5GHz 雙寬帶
o 改善了網絡穩定性,特別是在 Wi-Fi 擁擠的家庭 - HEOS 無線多房間整合
o 聯合其他 HEOS 揚聲器/設備組成全住宅音響,均通過 HEOS app 控制 - AirPlay、藍牙、互聯網收音機、Spotify Connect、Tidal、Deezer、網絡音頻串流
o 訪問幾乎不受限制的在線音樂源 - 支持 DSD (2.8/5.6MHz)、FLAC、ALAC 和 WAV 文件
o 為 Hi-Fi 發燒友提供高清音頻串流 - Audyssey MultEQ、Dynamic Volume(動態音量)和 Dynamic EQ(動態均衡器)
o 為您的房間/揚聲器帶來完美的均衡 - 支持 Audyssey MultEQ Editor app(可以在 Appstores 中花 HKD158 購買)
o 均衡參數的專業微調 - 顏色編碼揚聲器端子、設置助手、高級 GUI、Marantz 2016 AVR Remote App
o 安裝、設置和操作都很簡單 - ISF 視頻校準
o 可對家庭影院電視機或投影儀進行專業校準 - 多房間/多源(第二區域;通過放大器或通過前級輸出)
o 在家庭影院中觀看電影而在另一房間收聽音樂 - 帶有關/開/自動設置功能的智能 ECO 節能模式
o 有節能意識而不妥協性能
最新 HDMI 連接能力
Dolby Atmos
DTS:X
Chris 012-2309169
BRANDED led tv
amplifier
speaker
cd player
SPECIFICATIONS
AUDIO
AUDIO SYSTEM
HEADER
Brand Marantz
Model 1608
Packaged Quantity 1
MISCELLANEOUS
Color black
Channel Qty 7
RADIO
Tuner Type digital
Tuner Bands AM/FM
3D Pass-Through Yes
CONNECTIONS
Qty 1, 2, 3, 7
GENERAL
- Number of posts : 1318
» Marantz SR5012 7.2CH Atmos Network AV Receiver (Sold Out)
» Marantz SR6012 9.2CH Atmos Network AV Receiver (Sold Out)
» Marantz SR8012 11.2Ch Atmos Network AV Receiver
» Marantz SR5013 7.2Ch Atmos Network AV Receiver
» Marantz SR6013 9.2Ch Atmos Network Av Receiver
