Denon DP-300F Fully Automatic Analog Turntable
Denon DP-300F Fully Automatic Analog Turntable Brand New. Now Selling At RM1,699. Free Shipping Within West Malaysia.
The DP-300F has been designed with heavier base construction for reduced vibration and improved performance. The all new tonearm has a removable headshell making cartridge replacement simple. The standard mount headshell allows for any standard mount cartridge between 5 ~ 10 grams to be mounted and balanced. The automatic startup feature allows the turntable to begin play with the touch of a button, and once play has been completed, the tonearm will be returned to the armrest gently so that the stylus and record are not damaged or scratched. The turntable is made of rigid diecast aluminum to produce uniform rotation for smooth flutter free operation. There is also a manual lifter mechanism that allows you to place the needle on the record wherever you want, so you can skip to a different song in the middle of a side.
The DP-300F includes a built-in phono equalizer to connect the player to an integrated amp or receiver that does not have its own phono input. This turntable is powered by a DC servo motor and belt drive system and has rotation speeds of 33 1/3 or 45 rpm. It comes with a MM cartridge so that you can begin to enjoy your analog record collection as soon as you connect the DP-300F to your home hi-fi system.
Technical information
Auto/Manual auto
Belt Drive/Direct Drive belt_drive
Built In Phono Stage yes
Cartridge Included? Denon DSN-85 - MM
Dimensions WxDxH 434 x 381 x 122
Dimensions WxHxD (mm) 434 x 38 x 122mm
Phono Input Yes
Power Consumption- Normal Use 2
Replacement Stylus Code DSN-85
Speeds 33 / 45
Unit Dimensions (WxDxH) 434 x 381 x 122
USB Output No
Weight (KG) 6
Brand Denon
Colour Black
BRANDED led tv
amplifier
speaker
cd player
DP-300F
Fully Automatic Analog TurntableThe DP-300F has been designed with heavier base construction for reduced vibration and improved performance. The all new tonearm has a removable headshell making cartridge replacement simple. The standard mount headshell allows for any standard mount cartridge between 5 ~ 10 grams to be mounted and balanced. The automatic startup feature allows the turntable to begin play with the touch of a button, and once play has been completed, the tonearm will be returned to the armrest gently so that the stylus and record are not damaged or scratched. The turntable is made of rigid diecast aluminum to produce uniform rotation for smooth flutter free operation. There is also a manual lifter mechanism that allows you to place the needle on the record wherever you want, so you can skip to a different song in the middle of a side.
Auto/Manual auto
Phono Input Yes
Speeds 33 / 45
USB Output No
Weight (KG) 6
Brand Denon
Colour Black
BRANDED led tv
amplifier
speaker
cd player
- Number of posts : 1323
» Denon DP-300F -Fully Automatic Turntable (new)
» Denon DP-300F Fully Automatic Analog Turntable SOLD
» Denon DP-300F Fully Automatic Analog Turntable- used(sold)
» Thorens TD-158 Fully Automatic Turntable Made In Germany
» Denon DP-200USB Fully Automatic Turntable with USB
