Mission Speaker
Mission Speaker
Recommended amp power: 15 - 75 watts
Sensitivity: 86 dB
Impedance: 8 ohms
Magnetically shielded? Yes
HxWxD (mm)/Weight: 220 x 145 x 190 / 2.5 kg
Frequency response: 68 - 20,000 Hz
Crossover frequency: 2.5 kHz
Connections: Gold-plated 4mm banana socket/binding posts
Bass port? Yes - twin front firing design
Drivers: LF: 100mm Diadrive
HF: 25mm Viotex fabric dome treble
Colour:Cherry
Extra: 2 way reflex design, curved front baffle, 15 and 12mm MDF cabinet construction.
MISSION M30 SPEAKERS
Sleek and stylish, the Mission M30 is an ideal choice for listeners who have limited space but who appreciate the beauty of sound. Designed for the bookshelf, or to be wall mounted using the Mission wall bracket, the M30 is easy to drive and is appropriate for all types of amplification from separate hi-fi amplifiers through to mini systems or as partners to the Mission M3C1 centre channel and a Mission subwoofer to make up a stylish home theatre system.
The Mission's M30's DiaDrive bass units combine the best attributes of soft fibre and high rigidity cones in one multi-layer diaphragm. Natural mid range quality is produced by a seam-free curvilinear cone formulated from a mixture of soft pulp and acrylic fibre specifically designed for mid-band clarity and lucidity. Backing this is a stiff, conical support cone with increased area of contact with the voice coil for outstanding transient impact.
To match the outstanding performance of the M30's DiaDrive bass driver, high frequencies are handled by an ultra-light, Viotex fabric dome treble unit of wide dynamic range and bandwidth. An extended response to 30 kHz is just one indication of the speed of response of this unit, but the true analysis is in the sweetness, clarity and detailed resolution that only come from a drive unit that pushes distortion products beyond the limits of audibility. Viotex fabric dome high frequency tweeter and DiaDrive mid range and bass driver,
Designed as a bookshelf speaker also suitable for wall mounting
Matching floor stands and wall bracket also available
Available in Black, Beech, Cherry and Satin silver
Last edited by HiFiLab on Mon Jan 14, 2019 9:03 am; edited 1 time in total (Reason for editing : Sold)
- Number of posts : 2967
» Mission MX2 Speaker black bookself speaker (NEW)
» Mission 70 speaker
» Speaker Mission 760
» Mission 731 speaker (used)
» Mission 753 speaker
