KEF LSX Wireless Music System
KEF LSX Wireless Music System Brand New, KEF LSX Wireless Music System are available Red, Black, Blue, White and Green. Now Selling At RM5,699. Free Shipping Within West Malaysia.
Stereo.
With two speakers positioned apart from each other, you’ll experience music as a 3D soundstage, with the pin-point imaging and sense of presence that one-box systems miss. It’s the difference between just hearing music, and really feeling it.
(*available in early 2019)
LSX 配有 Apple AirPlay 2 ,透過你的 iPhone,iPad,或是蘋果的裝置,輕觸螢幕或透過 Siri 操作,便可以敞開多室空間音響的大門,提供無縫接軌的控制功能,讓家中每個角落都能享有無限美好的音樂感動。(*2019年年初啟用)
"A neat, compact and entertaining all-in-one system of rare sonic quality." — 2018
Uni-Q.
LSX comes with KEF’s breakthrough Uni-Q driver array. By placing the tweeter at the centre of the midrange and bass cone, it radically improves stereo imaging. This not only makes music sound clear, detailed and lifelike, it does so across a wider listening area.
Uni-Q
LSX 搭載 KEF 劃時代的 Uni-Q 單體,透過將高音和中低音單元作同軸共點排列的設計,徹底地改善立體聲成像效果。不僅能使音樂清晰透徹,細節豐富而生動,即使在更開闊的聆聽空間也有出色表現。
Contoured baffle.
Optimised using Finite Element Analysis, LSX’s contoured baffle improves sound dispersion, ensuring that sound waves travel outwards and are not reflected around the cabinet surface. The result? A purer sound, with less cabinet colouration.
圓弧造型前擋板:
以Finite Element Analysis 優化的圓弧造型前擋板,可改善聲波頻擴散情形,確保聲波向外傳遞,不會在箱體表面反射。降低箱體音染干擾,提供更純淨的音質。
DSP.
LSX uses KEF’s Music Integrity Engine™ – bespoke Digital Signal Processing that helps the speakers deliver transparent bass with great extension, while reducing distortion. So you can fill your room with rich, full-bodied sound.
DSP
LSX 採用 KEF 的 Music Integrity EngineTM,此特製數位信號處理程序能幫助揚聲器提供清澈渾厚的低音延伸,同時降低失真,讓豐富飽滿的音質填滿您的空間。
Design by
Overseen by renowned product designer Michael Young, LSX’s design achieves a fine balance of form and function. Carefully considered details include port accent colours and a colour changing LED to subtly indicate which source is selected.
DIMENSION (H X W X D)
240 x 155 x 180 mm (9.5 x 6.1 x 7.1in.)
WEIGHT
3.6kg (7.9lbs)
3.5kg (7.7lbs)
WI-FI NETWORK STANDARD & FREQUENCY BAND
Dual-band 2.4GHz/5GHz
IEEE 802.11a/b/g/n
DRIVER UNITS
Uni-Q driver array:
HF: 19mm (0.75in.) aluminium dome
LF/MF: 115mm (4.5in.) magnesium/aluminium alloy cone
INPUTS
2.4GHz/5GHz Dual-band Wi-Fi network
Bluetooth 4.2 with aptX codec
TOSLINK Optical
3.5mm Auxiliary Input
RJ45 Ethernet (For network)
OUTPUT
Subwoofer Output
5V2A DC Output
AMPLIFIER OUTPUT POWER
LF: 70W HF: 30W
BLUETOOTH RANGE & MEMORY
10m
8 devices
BLUETOOTH FREQUENCY
2.402GHz - 2.48GHz
BLUETOOTH POWER
2.5mW (Bluetooth Class 2 Device)
RESOLUTION
Support up to 192kHz/24bit
Depending on source resolution
MASTER AND SLAVE SPEAKER CONNECTION
Wireless: Propriety 2.4GHz
Wired: RJ45 Ethernet
Depending on connection settings
MAXIMUM OUTPUT(SPL)
102dB
POWER INPUT
100 – 240VAC 50/60Hz
WIRELESS CONNECTIVITY
TIDAL
FREQUENCY RANGE
Frequency Range (-6dB)
Measured at 85dB/1m
49Hz - 47kHz (More bass extension)
52Hz - 47kHz (Standard)
55Hz - 47kHz (Less bass extension)
Depending on speaker settings
FREQUENCY RESPONSE
Frequency Response (±3dB)
Measured at 85dB/1m
54Hz - 28kHz (More bass extension)
59Hz - 28kHz (Standard)
69Hz - 28kHz (Less bass extension)
THIRD PARTY SUPPORT
Mounting inserts for supporting wall mount
Supports 3rd party remote programme
Supports IP Control
INPUTS
Bluetooth 4.0 with aptX codec
USB Type B
TOSLINK Optical
RCA Analog Line Level Input
10/100 Mbps RJ45 Ethernet (For network and service)
MASTER SPEAKER
SLAVE SPEAKER
DOWNLOADS
Product Information Sheet
LSX
Give your music the space it deserves.
The convenience and connectivity of wireless. The emotion and detail of true high-resolution stereo. And all from a compact system designed to fit almost anywhere. LSX is the speaker system for the way we listen today.您的音樂,值得更寬廣真切的展演舞台
輕鬆擁有無線功能所帶來配對連結的便利性,無限享受高解析立體聲所傳達出的豐富情感和清澈音線。Play anything. Hear everything.
From streaming to gaming, from TV to multi-room music, LSX is designed for all your home entertainment needs. Play what you like, how you like, where you like – and experience it all in glorious high-resolution stereo.自在聆聽 臻善臻美
從影音串流到電玩遊戲,從電視到多室空間音訊播放,LSX 所具備的智慧功能將大大滿足您所有家庭娛樂需求。就是要您自在享受音樂,隨心所欲、體驗無與倫比的高解析好音質立體聲。Stereo.
Feel the performance.
With two speakers positioned apart from each other, you’ll experience music as a 3D soundstage, with the pin-point imaging and sense of presence that one-box systems miss. It’s the difference between just hearing music, and really feeling it.立體聲如臨其境
將兩個揚聲器放在對等位置,即可體驗 3D 聲場的絕佳音樂,精準的聲音定位與現場感,絕非單音箱系統所能比擬,不僅只是聽見,更彷彿實際親臨現場,切身感受音樂的暢快美妙。Apple AirPlay 2*
LSX comes with Apple AirPlay 2 which, from a simple screen tap or request to Siri, unlocks the world of multi-room audio. You can wirelessly stream all your favourite music apps to your whole home with seamless control from your iPhone, iPad, and Mac.(*available in early 2019)
All the music on earth.
With Spotify Connect and Tidal built in, all the music you love is at your fingertips. Stream from the cloud, or directly from a NAS drive or a computer through DLNA fully wirelessly at 48kHz/24bit resolution (or 96kHz/24bit using optional wired connection). Or simply use Bluetooth.輕鬆聆聽來自世界各地的音樂美好
透過內建的 Spotify Connect 和 Tidal 應用程式,所有喜愛的音樂輕鬆在指尖就能掌握。還能透過DLNA以 48kHz/24bit 解析度(若透過選配的有線連接,可達 96kHz / 24bit 解析度)從雲端、NAS、或是電腦無線擷取音樂檔案,或者直接使用藍芽連接。Easy listening.
With LSX, nothing gets between you and the music. Connecting to Wi-Fi takes moments with the KEF Control app and keeps abreast of the latest firmware, so your speakers are future-proofed and always up to date.輕鬆聆聽
擁有LSX,讓您和音樂之間再沒有隔閡。使用KEF control應用程式,片刻即能連結網路,並隨時檢測最新可用的軟體,讓您的系統與未來即時同步,保持在最新狀態。SOUND
LSX utilises KEF’s advanced acoustic design technology, features that are usually reserved for much larger hi-fi speakers. Get ready for goosebump-inducing levels of sonic realism and accuracy.音質
LSX讓您輕鬆擁有大型Hi-fi才具備的KEF先進技術與設計,超乎想像的聲音真實感和準確性,絕對讓您讚嘆不已。"A neat, compact and entertaining all-in-one system of rare sonic quality." — 2018
WHAT HI-FI? SOUND AND VISION
FULL REVIEW
"Outstanding… The stereo image is perfect" — 2018DIAPASON D'OR
Uni-Q.
The sweet spot just got a lot wider.
LSX comes with KEF’s breakthrough Uni-Q driver array. By placing the tweeter at the centre of the midrange and bass cone, it radically improves stereo imaging. This not only makes music sound clear, detailed and lifelike, it does so across a wider listening area.Uni-Q
讓最佳聆聽位置更寬廣
LSX 搭載 KEF 劃時代的 Uni-Q 單體,透過將高音和中低音單元作同軸共點排列的設計,徹底地改善立體聲成像效果。不僅能使音樂清晰透徹,細節豐富而生動,即使在更開闊的聆聽空間也有出色表現。Contoured baffle.
Hear the music,not the speaker.
Optimised using Finite Element Analysis, LSX’s contoured baffle improves sound dispersion, ensuring that sound waves travel outwards and are not reflected around the cabinet surface. The result? A purer sound, with less cabinet colouration.圓弧造型前擋板:
聽見音樂真實的模樣,給你最純淨音色
以Finite Element Analysis 優化的圓弧造型前擋板,可改善聲波頻擴散情形,確保聲波向外傳遞,不會在箱體表面反射。降低箱體音染干擾,提供更純淨的音質。DSP.
Small speakers,big sound.
LSX uses KEF’s Music Integrity Engine™ – bespoke Digital Signal Processing that helps the speakers deliver transparent bass with great extension, while reducing distortion. So you can fill your room with rich, full-bodied sound.DSP
小音箱大音能
LSX 採用 KEF 的 Music Integrity EngineTM,此特製數位信號處理程序能幫助揚聲器提供清澈渾厚的低音延伸,同時降低失真,讓豐富飽滿的音質填滿您的空間。DESIGN
Compact, elegant and incredibly versatile, LSX looks great and fits comfortably into any setting. And with our intuitive apps, you’ll be up and running in next to no time.設計
精巧優雅的外型,靈活多變的功能,能搭配不同的空間設計,透過操作簡便的應用程式,輕鬆使用、品味絕對。No cables. No compromise.
With no need for a cable to connect the two speakers, and no separate amps or other equipment to worry about, you can position them wherever you like. Wave goodbye to visual clutter, without sacrificing sound quality.無線、無限
兩個揚聲器之間不須透過線材連接,也擺脫其他傳統Hi-fi器材的羈絆,擺放位置不受限,但音質絕不妥協。Design by
Michael Young.
Overseen by renowned product designer Michael Young, LSX’s design achieves a fine balance of form and function. Carefully considered details include port accent colours and a colour changing LED to subtly indicate which source is selected.由著名的產品設計師 Michael Young 監製
由著名的產品設計師 Michael Young 監製,獨具匠心的材質選擇和精心搭配,充分展現form and function的完美平衡。鉅細彌遺地思考所有細節,如低音反射孔的顏色搭配,隨音源訊號而變色的LED顯示等。Colours and fabrics.
Whatever your style, there’s an LSX to match. The system comes with a choice of five colours, and is clad in an industrial fabric by Danish contemporary textile designer, Kvadrat. These fine details make the LSX pleasing to the touch, as well as appealing to the eye.色彩與織品
精挑細選的五款色彩搭配,由丹麥當代紡織品設計師 Kvadrat 採工業面料設計而成,觸感舒適、外型亮眼且質感兼具,展現個人強烈風格。Interested please feel free to contact:
WEIGHT
3.6kg (7.9lbs)
3.5kg (7.7lbs)
IEEE 802.11a/b/g/n
DRIVER UNITS
Uni-Q driver array:
INPUTS
TOSLINK Optical
OUTPUT
Subwoofer Output
5V2A DC Output
LF: 70W HF: 30W
10m
8 devices
BLUETOOTH FREQUENCY
2.402GHz - 2.48GHz
BLUETOOTH POWER
RESOLUTION
MAXIMUM OUTPUT(SPL)
102dB
POWER INPUT
TIDAL
FREQUENCY RANGE
Measured at 85dB/1m
FREQUENCY RESPONSE
Measured at 85dB/1m
THIRD PARTY SUPPORT
Supports IP Control
INPUTS
USB Type B
TOSLINK Optical
MASTER SPEAKER
SLAVE SPEAKER
DOWNLOADS
- Number of posts : 1368
» Naim - Mu-So - Wireless Music System - (NEW)
» Naim - Mu-So QB - Wireless Music System - (NEW)
» Naim Mu-So QB ( Wireless Music System ) NEW
» Naim Muso QB Wireless Music System (SOLD)
» Naim Mu-so All In One Wireless Music system (SOLD)
