Furutech Daytona 303 Multi Mode Power Filter
Furutech Daytona 303 Multi Mode Power Filter Brand New. Now Selling At RM13,999. Free Shipping Within West Malaysia.
Daytona 303
-Awards-
EMI-Absorbing Formula GC-303
•DVD and DVR (Filter 1)
•CD、Cable and SAT(Filter 2)
•TV and Projector (Filter 3)
•Zone 1, 2, 3 • Green
•Breaker indicator • Red
•Digital voltage meter • Red
•Digital amperage meter • Red
•Rear panel
•Input x 1 • Output x 2
•3 Remote control triggers
•Sequence switch
•Voltage selector switch for 120V AC (60Hz) or 100V AC (50/60Hz)
Under the Hood
On the Track
*整合3区域10组输出电源时序开/关机控制,可将府上所有音响设备依分类接上使用,并支援AC 230V / DC 3~30V触发启动功能,可作多部串联使用(特别适用于多区域控制)。
*4孔/2组/2区域之电源输出插座有经过突波保护线路,也经过FURUTECH被动式电磁波吸收材料“GC-303”来滤波,“GC-303”能去除EMI与RFI噪讯,不使用电子滤波线路,这些插座都能完美呈现大电流后级扩大机电源的纯传输效果,这4孔适合用来连接大电流后级扩大机,前级处理器以及类比的音响器材,可以确保全方位的突波保护,最大保护能量达到5250焦耳。
*6孔/3组/1区域之电源输出插座,采用3组独立滤波输出,并使用FURUTECH被动式电磁波吸收材料“GC-303”来滤波,适合CD、DVD、TV…等数位器材使用。
*具备3组RF滤波及1组电话线路(2出)的防雷击突波保护装置。
*内部主要配线采用Furutech Alpha-10(Alpha-OCC导体),5.5sq.mm(10AWG),搭配使用Formula GC-303特殊电磁杂讯吸收材料。
*所有金属配件皆经过Furutech’s α(Alpha)深层超低温无磁性处理。
*前面板具备数字显示型电压与电流表,方便了解府上电压与系统用电情况。
*输入电压:230V AC 50 Hz 3450W 15A Max
*尺寸:414(W) x 265(D) x 149(H)mm 重量:9.5kgs
随机线:
FP-314Ag-II OFC镀银线+镀铑插头
Sound & Vision Daytona 303E
100V AC 50/60Hz 1500 VA
120V AC 60Hz 1800 VA
15 A Max.
Also available in 230V
Daytona 303
-Awards-RATING
The Daytona 303 Multi-Mode AC Filter/Power DistributorFeaturing Resonance-Damped Receptacles and Locking Plates
•Rear panel
•Sequence switch
FEATURES
The Daytona: 24 Hour Protection for Pro A/V and High Performance EnthusiastsAll enthusiasts are looking for the same qualities: Verisimilitude to the original event, a sense of engagement promoting suspension of disbelief, an immersion in audio and video experience. To engage without effort requires meticulous preparation of the entire playback chain especially including the AC mains supply.
Under the Hood
On the Track
随机线:
15 A Max.
- Number of posts : 1318
» Furutech Daytona 303 Multi-Mode AC Filter/Power Distributor
