Post by raymond88 Tue Oct 25, 2022 9:19 pm
Condition: Item is in very good condition. Comes with power cable and LED light fixture.
Selling this unit for RM8200 or swap/topup
Can Trade-In your Amplifier/
Furutech Daytona 303 Multi-Mode AC Filter/Power Distributor Furute23
Furutech Daytona 303 Multi-Mode AC Filter/Power Distributor Furute24
Furutech Daytona 303 Multi-Mode AC Filter/Power Distributor Furute25
EMI-Absorbing Formula GC-303
•DVD and DVR (Filter 1)
•CD、Cable and SAT(Filter 2)
•TV and Projector (Filter 3)
•Zone 1, 2, 3 • Green
•Breaker indicator • Red
•Digital voltage meter • Red
•Digital amperage meter • Red
•Rear panel
•Input x 1 • Output x 2
•3 Remote control triggers
•Sequence switch
FEATURES
Under the Hood
On the Track
Number of posts : 10072
