Richard Gray's RGPC 400 Pro MK II Power Conditioner - Local 240V
Item: Richard Gray's RGPC 400 Pro MK II Power Conditioner - Local 240V
Condition: 8.5/10. Item is in excellent condition. No scratches or dents. Comes with original 20A power cable.
Price:RM3200 RM2900 or swap/topup
Richard Gray Power Company RGPC Parallel Power Delivery with 4 20AMP Receptacles.
Improves Audio & Video.
Specs below are for the 400 Pro the difference between the Pro and MK II is the following, the Pro has a 20amp power cord IEC receptacle and 20 amp power cord
RGPC 400 MKII:
Fits conveniently behind an equipment rack, either upright or on its side. Contains one 6,000 Watt parallel choke for continuous high performance regardless of power line limitations.
Non-sacrificial dual stage surge protection for long lasting protection that does not wear out Non-current limiting noise removal for uncompromised performance
Eliminate intercomponent �cross talk� 20-amp IEC cord for use with today�s high-powered amplifiers and digital devices
Place an RGPC 400 MKII on each circuit that is serving home entertainment gear to receive the benefits of RGPC�s parallel power delivery.
Dimensions: 8.5 x 9 x 6 inches (WHD)
Net weight: 22 lbs
Outlets: 4 commercial grade Hubbell,
(4 VIMAR Euro Schukos -Export)
Power Cord: Detachable. 6ft 12 AWG cord,
NEMA 5-15 Plug, 15 Amp IEC connector
Input Voltage: 120 VAC 60Hz (240 VAC 50Hz Export)
Output Voltage: 120 VAC 6Hhz (240 VAC 50Hz Export)
MOV: 18,000 Joules, 320V Clamp
Noise Removal: > 45dB
Fuse: 1 - 15 Amp fast blow-replace with Littlefuse 3AB
Draw at Idle: < 5 watts
Maximum Capacity: (components plugged directly in) 20Amps
Rack Mountable: No
Indicator Light: Green Neon top mount
No user serviceable parts inside
Price:
RGPC 400 MKII:
Net weight: 22 lbs
Rack Mountable: No
» Richard Gray's Power Company - RGPC 400 Pro Power Line Conditioner
» Richard gray RGPC 400 power conditioner (used)
» Richard Grey RGPC 400 Pro Power Conditioner
» Richard Grey RGPC Int 400 Power Conditioner
