Denon AVR-X2600H 7.2Ch 4K Ultra HD AV Receiver
Denon AVR-X2600H 7.2Ch 4K Ultra HD AV Receiver Brand New. Now Selling At RM4,099. Free Shipping Within West Malaysia.
7.2 channel 4K Ultra HD AV receiver with 95W per channel, HDMI (8in / 2out with eARC). Supports 3D audio formats Dolby Atmos:registered:, Dolby Atmos Height Virtualization Technology, DTS:X:tm: and DTS Virtual:X:registered:. Works with Amazon Alexa, Google Assistant, and Apple Siri for seamless voice control.
7.2声道4K超高清AV接收机,每声道150W,带HDMI接口(8个输入/2个输出,带eARC)。支持3D音频格式Dolby Atmos:registered:、Dolby 扬声器模拟器、DTS:X:tm:和DTS Virtual:X:registered:。
With eARC support pass-through, 8 HDMI inputs and 2 outputs with full HDCP 2.3 support on all ports, enjoy seamless compatibility with the latest HD and Ultra HD TVs, Blu-ray players and game consoles. The front-panel USB offers convenient audio playback of MP3 and Hi-Res audio formats (WAV, FLAC, ALAC and DSD 2.8/5.6 MHz files). Stream popular music services like Spotify:registered:, Pandora:registered:, Tidal and more wirelessly via Bluetooth, Apple AirPlay 2 and Wi-Fi with HEOS Built-in. The Denon AVR-X2600H also works with Amazon Alexa, Google Assistant and Apple Siri for effortless voice control.
By visually guiding you through each step in the setup process, the award-winning Denon Setup Assistant ensures you get setup right the first time. Every home theater is different — that’s why Denon uses premium room calibration technology from Audyssey that automatically measures and optimizes your AV receiver to provide a truly immersive 3D audio experience custom-tailored to your unique listening environment.
用Denon AVR-X2600H来升级您的家庭影院。 这款性能优化的Denon AV接收机每声道150W(6 Ω、1 kHz、1% 单声道驱动),提供真正沉浸式3D音频体验。支持Dolby Atmos:registered:、Dolby扬声器模拟器、DTS:X:tm:和DTS Virtual:X。Dolby Vision:tm:、HDR10和HLG等最新4K视频技术的应用,最大限度改善电视机或投影仪的视频画质。
配置支持直通的eARC、8个HDMI输入接口和2个输出接口(全部接口支持全HDCP 2.3),与最新高清和超高清电视机、蓝光播放机和游戏机无缝兼容。前面板USB方便播放MP3和高解析度音频格式(WAV、FLAC、ALAC和DSD 2.8/5.6 MHz文件)。HEOS允许通过蓝牙、Apple AirPlay 2。
获奖的Denon设置助手直观地指导您完成每一步设置,确保您一次搞定设置。每一个家庭影院都与众不同——因此Denon采用Audyssey的高级室内校准技术(它可以自动测量和优化AV接收机),根据您独特的聆听环境量身定制真正沉浸式3D音频体验。
With HEOS Built-in technology play the same song in every room or select a different song for each connected room — the choice is yours. HEOS works with Amazon Alexa and Google Assistant, providing effortless voice control.
HEOS supports free and premium Spotify, Pandora, Amazon Music, TuneIn, iHeart Radio, Sound Cloud, SiriusXM, Tidal and more.
采用HEOS Built-in技术后,可在每个房间播放同一首歌,或为每个连通的房间选择不同的歌——选择权在您手里。HEOS与Amazon Alexa和Google Assistant配套使用,轻松实现语音控制。
HEOS支持优质的免费资源TuneIn等。
Use Amazon Alexa, Siri, or Google Assistant to control your music.
Stream audio from your favorite music services like Apple Music and Spotify or watch videos from services like YouTube and Netflix from any iPhone, iPad, Mac or Apple TV and hear the audio perfectly synced to your speakers AirPlay 2 sources.
用iPhone、iPad、Mac串流传输Apple Music等您喜爱的音乐服务的音频,从而聆听完美同步到您的音箱AirPlay 2音源的音频。
AirPlay 2也支持多房间音频——以改进的音频缓冲技术将内容同时无线串流传输到多个AirPlay 2兼容设备,确保音频播放流畅性。AirPlay 2在Apple Music或Home应用程序中提供兼容音频设备的控制和分组。通过应用程序或经由Siri通过语音使用AirPlay 2。
AirPlay 2 also supports multi-room audio – wirelessly stream content to multiple AirPlay 2 compatible devices simultaneously with improved audio buffering to ensure smooth audio playback. AirPlay 2 provides control and grouping of compatible audio devices within the Apple Music or Home app. Use AirPlay 2 in-app or with your voice via Siri.
SPECIFICATION
Channels 7.2
Object-Based Configuration:: 5.2.2
Power Output per Channel 2-Channel Driven:
95 W at 8 Ohms / 20 Hz to 20 kHz / 0.08% THD
125 W at 6 Ohms / 1 kHz / 0.7% THD
1-Channel Driven:
150 W at 6 Ohms / 1 kHz / 1% THD
Frequency Response 10 Hz to 100 kHz +1/-3 dB (Direct Mode)
Speaker Impedance 4 to 16 Ohms
Audio Processing
DTS Compatibility DTS:X
Dolby Compatibility Dolby Atmos
Auro 3D Support No
Upmixing Technology DTS Virtual:X
Video
HDR Compatibility HDR10, Dolby Vision, Hybrid Log Gamma
Pass-Through Support 4K60p 4:4:4 (BT.2020)
Connectivity
Rear A/V Inputs 7 x HDMI
2 x Optical TOSLINK
1 x Digital Coaxial
2 x 3RCA Component
2 x RCA Composite
4 x Stereo RCA
1 x Stereo RCA (Phono) with Ground Screw
Rear A/V Outputs 2 x HDMI
1 x 3RCA Component
1 x RCA Composite
2 x RCA Subwoofer Pre-Out
1 x Stereo RCA Zone 2 Pre-Out
Front I/O 1 x 1/4" / 6.35 mm Headphone Output
1 x USB Type-A
1 x 1/8" / 3.5 mm Setup Mic Input
1 x HDMI
Other Rear I/O 1 x FM Antenna Terminal
1 x AM Antenna Terminal
1 x RJ45 (Ethernet)
1 x 1/8" / 3.5 mm (IR) Input
1 x 1/8" / 3.5 mm (IR) Output
1 x DE-9 (RS-232C) Input
2 x Bluetooth/Wi-Fi Antenna Terminal
Speaker Connectors 7 x Binding Post Pairs
HDCP Support Version 2.2
Input Impedance 47 kOhms
Input Sensitivity 200 mV
Signal to Noise Ratio 100 dB (Direct Mode)
Wireless Connectivity
Wi-Fi Yes
Bluetooth Yes
Wireless Audio Protocols AirPlay 2
Tuner Section
Tuner Type AM, FM
Radio Frequencies AM: 520 to 1611 kHz
FM: 87.5 to 108 MHz
Power
AC Input Power 120 VAC, 60 Hz
Power Consumption Active: 500 W
No Sound (ECO On): 35 W
No Sound: 75 W
Physical
Dimensions (W x H x D) 17.1 x 6.6 x 13.4" / 434.3 x 167.6 x 340.4 mm
Weight 20.7 lb / 9.39 kg
AVR-X2600H
Overview
Upgrade your home theater with the Denon AVR-X2600H. With 95W per channel (8 ohms, 20Hz-20kHz, THD .08%, 2 ch driven), this performance-tuned Denon AV receiver provides a truly immersive 3D audio experience. Supports Dolby Atmos:registered:, Dolby Atmos Height Virtualization Technology, DTS:X:tm:, DTS Virtual:X. Watch your TV or projector video content with the best possible picture thanks to the latest 4K video technologies like Dolby Vision:tm:, HDR10, and HLG.With eARC support pass-through, 8 HDMI inputs and 2 outputs with full HDCP 2.3 support on all ports, enjoy seamless compatibility with the latest HD and Ultra HD TVs, Blu-ray players and game consoles. The front-panel USB offers convenient audio playback of MP3 and Hi-Res audio formats (WAV, FLAC, ALAC and DSD 2.8/5.6 MHz files). Stream popular music services like Spotify:registered:, Pandora:registered:, Tidal and more wirelessly via Bluetooth, Apple AirPlay 2 and Wi-Fi with HEOS Built-in. The Denon AVR-X2600H also works with Amazon Alexa, Google Assistant and Apple Siri for effortless voice control.
POWERFUL 7-CHANNEL AMPLIFIER WITH THE LATEST HOME CINEMA SPECS
Featuring discrete high-current amplifiers on all channels, the AVR-X2600H delivers high-power performance at 95W per channel (8 ohms, 20Hz-20kHz, THD .08%, 2 ch driven). Low impedance drivers provide operational stability for a wide range of speakers for balanced, tonal sound. The AVR-X2600H supports three-dimensional sound formats Dolby Atmos, Dolby Atmos Height Virtualization Technology, DTS:X and DTS Virtual:X, plus an HDMI section with HDCP 2.3 support and advanced video processing with 4K upscaling for HDMI sources.符合最新家庭影院规格的7声道放大器
符合最新家庭影院规格的7声道放大器AVR-X2600H的所有声道都配备分离式高电流放大器,每声道具有150瓦的高功率性能(6 Ω,1 kHz,1%单声道驱动)。(6 Ω,1 kHz,1%单声道驱动). 低阻抗驱动器为各种扬声器提供工作稳定性,形成平衡、调和的声音。AVR-X2600H支持Dolby Atmos、Dolby Atmos Height Virtualization Technology(杜比全景声高度虚拟技术)、DTS:X和DTS Virtual:X等立体声音频格式,其HDMI部分支持HDCP 2.3,还具有将HDMI源升频至4K的高级视频处理功能。AMAZING 3D-SOUND
Immerse yourself in multi-dimensional audio with Dolby Atmos, DTS:X, Dolby Atmos Height Virtualization and DTS Virtual:X.惊人的3D声音
选用Dolby Atmos、DTS:X、Dolby Atmos Height Virtualization和DTS Virtual:X.等技术,让您沉浸在多维音频中。驱动沉浸式环绕立体声
采用Dolby Atmos让您沉浸在多维音频中。使用杜比全景声高程扬声器或专用置顶扬声器设置具有5.2.2环绕声扬声器系统的杜比全景声,确保终极家庭影院体验。Dolby Atmos Height Virtualization技术提供没有纵向声道的沉浸式音频,在7.2、5.2或2.2扬声器配置中营造虚拟纵向效果。GET CLOSER TO THE ACTION
DTS:X:tm: immersive audio places sound where it would occur naturally in space, creating a lifelike, multi-dimensional audio experience in the home. The improved immersion and heightened realism draw you into the world of your favorite movies. The included DTS Neural:X:tm: gives your movies, games and music a realism unmatched by traditional 5.1 surround sound. DTS Virtual:X provides immersive audio without height channels, creating virtual height effects in a 7.2, 5.2 or 2.2 speaker arrangement.与情景更接近
DTS:X:tm:沉浸式音频将声音置于它在空中的自然发出位置,在家中创建逼真的多维音频体验。改善的沉浸感和提高的真实性将您带入最喜欢电影的世界。附带的DTS Neural:X:tm:让电影、游戏和音乐产生逼真感觉,这是传统的5.1环绕声无法比拟的。DTS Virtual:X提供没有纵向声道的沉浸式音频性能,在7.2、5.2或2.2扬声器布置中营造虚拟纵向效果。GEARED UP FOR 4K ULTRA HD
Enjoy your favorite movies, shows and games with the best picture quality available.预升级4K超高清
以最佳画面质量欣赏您最喜欢的电影、电视节目和游戏。ADVANCED HDMI VIDEO SECTION WITH EARC
The AVR-X2600H features 8 HDMI inputs and 2 outputs that support 4K Ultra HD 60Hz video, 4:4:4 Pure Color sub sampling, Dolby Vision, High Dynamic Range (HDR10), Hybrid Log-Gamma (HLG), eARC, 3D, and BT.2020 passthrough support for exceptional color, clarity and contrast. The eARC – enhanced Audio Return Channel – supports 3D audio transmission directly from the TV to your AV receiver.带EARC的高级HDMI视频段
AVR-X2600H配备8个HDMI输入接口和2个输出接口,均支持4K超高清60Hz视频、4:4:4纯色子采样、Dolby Vision、高动态范围(HDR10)、Hybrid Log-Gamma(HLG)、eARC、3D和BT.2020直通,具有非凡的色彩、清晰度和对比度。增强音频回传通道(eARC)支持3D音频直接从电视机传输到AV接收机。ADVANCED VIDEO CONTROLS
HDCP 2.3 processing is available on all HDMI ports, letting you enjoy copy-protected content uninhibited. Enjoy seamless compatibility with the latest HD and Ultra HD TVs, Blu-ray players and game consoles.高级视频控件
所有HDMI接口均可进行HDCP 2.3处理,让您不受限制地欣赏版权保护内容。与最新高清和超高清电视机、蓝光播放机以及游戏机无缝兼容。NEXT GENERATION VIDEO FORMATS
Watch your TV or projector video content with the best possible picture thanks to the latest 4K video technologies like Dolby Vision:tm:, HDR10, and HLG. 4K/60 Hz, Dolby Vision, HDR10, HLG, 4:4:4 color resolution and BT.2020 provides the greatest video quality with exceptional brightness, contrast and color.下一代视频格式
Dolby Vision:tm:、HDR10和HLG等最新4K视频技术的应用,最大限度改善电视机或投影仪的视频画质。4K/60 Hz、Dolby Vision、HDR10、HLG、4:4:4彩色分辨率和BT.2020提供最佳视频品质,亮度、对比度和色彩非同凡响。EASY SETUP EXPERIENCE
The included AVR-X2600H Quick Start Guide provides simple, clear instructions for how to get started. Once you connect your TV to the AVR-X2600H via HDMI, the exclusive Denon Setup Assistant appears on your TV screen to walk you through setup, step by step. A row of color-coded speaker connections is laid out horizontally, making organizing and connecting speaker wires simple.简单的设置体验
附带的AVR-X2600H快速入门指南提供如何开始使用的简单、清晰说明。一旦通过HDMI将电视连接到AVR-X2600H,您的电视屏幕上就会出现专属的Denon设置助手,一步一步地指导您完成整个设置。一排带颜色编码的扬声器接口水平排布,便于组织和连接扬声器线路。SMART TV CONNECTIVITY
Control the Denon AVR-X2600H with your TV remote via the HDMI CEC functionality associated with your TV. The Smart Menu home screen provides you quick access to source and surround mode selections, the AV receiver setup menu and four Quick Selects.智能电视连接能力
通过与电视相关联的HDMI CEC功能,使用电视遥控器控制Denon AVR-X2600H。智能菜单主屏幕上提供了音源和环绕模式选择、AV接收机设置菜单以及四个快速选择的快速访问方式。AUDYSSEY ROOM CORRECTION
The AVR-X2600H features the Audyssey MultEQ XT room acoustic measurement system. With the supplied microphone, it precisely analyses the output of each speaker to optimize every channel. Plus, the additional Audyssey MultEQ Editor app (available for purchase) allows advanced users to go “under the hood” for further adjustment and customization of your audio environment.AUDYSSEY室内校正
AVR-X2600H具有Audyssey MultEQ XT室内声音检测系统。通过附带的麦克风,它精确分析每个扬声器的输出,从而优化每个声道。此外,高级用户可通过额外的Audyssey MultEQ Editor应用程序(可供购买)进入后台,进一步调整和定制音频环境。BUILT-IN BLUETOOTH AND WI-FI CONNECTIVITY
The heart of your wireless network. For Bluetooth, Wi-Fi and AirPlay 2 wireless streaming connectivity, the Denon AVR-X2600H is equipped with an advanced dual antenna transceiver system for robust streaming even in congested urban environments. Enjoy listening to your favorite audio content wirelessly from your smart devices.With HEOS Built-in technology play the same song in every room or select a different song for each connected room — the choice is yours. HEOS works with Amazon Alexa and Google Assistant, providing effortless voice control.
内置蓝牙和WI-FI连接功能
成为无线网络的核心。为实现蓝牙、Wi-Fi和AirPlay 2无线流媒体连通性,Denon AVR-X2600H配备高级双天线收发器系统,即使在拥挤的城市环境,也能提供极可靠的流媒体。通过无线方式从智能设备上聆听您最喜欢的音频内容。采用HEOS Built-in技术后,可在每个房间播放同一首歌,或为每个连通的房间选择不同的歌——选择权在您手里。HEOS与Amazon Alexa和Google Assistant配套使用,轻松实现语音控制。
YOU’RE IN CONTROL
Better control in your back pocket. The free Denon AVR Remote app for iOS and Android makes using the AVR-X2600H even easier — adjust volume, turn it on or off, mute the music, select a source or switch to the HEOS app for wireless music streaming. Download the Denon AVR Remote app and the HEOS app to your smartphone today. Available for both iOS and Android.Use Amazon Alexa, Siri, or Google Assistant to control your music.
ALL ZONE TV AUDIO
Play the audio from your TV to all zones. Supports both analog and digital audio connections.所有区域电视音频
在所有区域享受电视播放的音频。 支持模拟和数字音频连接。QUICK SELECTS FOR USER-FRIENDLY AUDIO TUNING
The Denon AVR-X2600H front panel features four Quick Select buttons that store your preferred audio settings for each source. Switch between TV audio, Blu-ray, media players and more, and the AVR-X2600H adjusts the EQ settings to your preferences for that media source. Use the buttons on the front panel or opt for the same Quick Selects on the AV receiver remote for faster control. Now allows for one-push all zone stereo mode via Quick Select.用户友好的音频调试快速选择
Denon AVR-X2600H前面板配备四个快速选择按钮,可储存不同资源的首选音频设置。在电视音频、蓝光、媒体播放器及其他资源之间切换后,AVR-X2600H将按照您对该媒体资源的偏好调节EQ设置。使用前面板按钮或在AV接收机遥控器上选择相同的快速选择键进行快速控制。现在允许通过快速选择实现一键式全区域立体声模式。ADVANCED SOUND PROCESSING
Experience extraordinary sound quality from both music and movies.高级声音处理
体验来自音乐和电影的非凡音质。DSP POWER PROCESSING
Incredible power for your music and movie needs. The AXR-X2600H includes an advanced DSP (Digital Sound Processor) chip for tremendous power processing. With four 300MHz DSP cores that are capable of processing over one billion computations per second, the AVR-X2600H supports the latest video, sound and processing needs.DSP功率处理
满足音乐和电源需求的惊人功率。AXR-X2600H包括一个高级的DSP(数码声音处理器)芯片,具有极强的功率处理能力。AVR-X2600H带有四个300MHz DSP内核,每秒可以处理十亿次以上的运算量,可满足最新的视频、声音和处理需求。MULTI-SOURCE, MULTI-ROOM
With the Denon AVR-X2600H, it’s possible to enjoy 7.2 channel surround sound in one room and a separate source or music stream in another. Watch a movie in one room while another family member listens to music in a different zone without interruption. Make use of the internal amps to power the speaker or use the zone pre-outs.多源、多房间
拥有Denon AVR-X2600H,可在一个房间欣赏7.2声道环绕声,在另一个房间播放另外的音源或音乐流媒体。在一个房间观赏电影,而其他家庭成员在别的区域聆听音乐,互不干扰。利用内置放大器强化扬声器,或使用区域前级输出。FRONT USB PORT FOR HIGH-RESOLUTION AUDIO
Enjoy superb audio fidelity with your favorite high-resolution audio tracks. The AVR-X2600H with AKM 32-bit D/A converters features high-resolution audio decoding with multiple lossless file types, including ALAC, FLAC and WAV at up to 24-bit/196-kHz. It is also compatible with 2.8/5.6-MHz DSD files (DSD is the audio coding format of SACD). Play them from memory devices via the front panel USB, or over network sources. The AVR-X2600H also supports other file types such as MP3 and WMA.前面板USB接口用于高解析度音频
欣赏您最喜欢的高解析度音频磁迹带来的超凡音频保真度。AVR-X2600H带有AKM 32位D/A转换器,具备多种无损文件类型(包括高达24位/196-kHz的ALAC、FLAC和WAV)的高解析度音频解码能力。还兼容2.8/5.6-MHz DSD文件(DSD是SACD的音频编码格式)。通过前面板USB从存储设备或通过网络源进行播放。AVR-X2600H还支持其他文件类型,如MP3和WMA。HONO INPUT FOR TURNTABLE/VINYL SUPPORT
For nearly 50 years, Denon has been developing turntables and phono pre-amps. With the included phono input, the AVR-X2600H lets you connect your turntable and play vinyl records. Enjoy your collection with exceptional quality and sound.唱头输入支持唱盘/黑胶唱片
近50年来,Denon一直致力于唱盘和唱机前置放大器的开发。利用附带的唱头输入,AVR-X2600H可连接唱盘播放黑胶唱片。欣赏收藏品的卓越品质和声音。DUAL SUBWOOFER OUTPUTS
Immerse yourself in evenly distributed, accurate bass. The AVR-X2600H features two subwoofer outputs to smooth out low frequencies and provide better dispersion. No audible peaks or dips — just powerful, room-filling bass.双超低音扬声器输出
让自己沉浸在均匀分布的准确低音中。AVR-X2600H配置两个低音炮输出,可抚平低频辐射并提供更好的扩散性。没有声音波峰和波谷——只有弥漫整个房间的强劲低音。WORKS WITH LATEST VOICE ASSISTANTS
Enjoy effortless voice control and total flexibility from the leading voice services. Using a smart speaker or your phone, speak commands with Amazon Alexa, Google Assistant, Apple Siri and high-end smart home automation, Josh.ai. Ask to play your favorite music, turn the volume up, skip to the next track, switch inputs and more. Switch between voice services or pick a favorite to use — the choice is yours. Functionality varies by voice agent.支持最新的语音助手
通过先进的语音服务享受语音控制乐趣和全然灵活性。使用智能扬声器或手机,通过 Apple Siri和高端智能家庭自动化 请求播放您最喜欢的音乐、调整音量、跳到下一曲目、切换输入源等等。在各语音服务之间相互切换,或选用一个最喜欢的——都在您的控制中。功能会因语音助手不同而异。WORKS WITH AMAZON ALEXA
Control the AVR-X2600H hands-free with Amazon Alexa and your voice. Adjust the volume, skip to the next track, switch inputs for your different media players and more — “Just Ask.” Download the free HEOS Home Entertainment Skill to enable Amazon Alexa voice commands for your AVR-X2600H, HEOS devices and other select Denon products. Requires Alexa app and Amazon Echo, Dot or equivalent.WORKS WITH GOOGLE ASSISTANT
Start music in the HEOS app, then ask your Google Assistant to control volume, play, pause, skip tracks and more.AIRPLAY 2 + APPLE SIRI VOICE CONTROL
Use AirPlay 2 to stream music wirelessly to the AV receiver, or group with other AirPlay compatible speakers to fill your home with music.Stream audio from your favorite music services like Apple Music and Spotify or watch videos from services like YouTube and Netflix from any iPhone, iPad, Mac or Apple TV and hear the audio perfectly synced to your speakers AirPlay 2 sources.
AIRPLAY 2 + APPLE SIRI语音控制
使用AirPlay 2以无线方式将音乐信号串流传输到AV接收机,或与其他AirPlay兼容扬声器组合,让家里荡漾着音乐。用iPhone、iPad、Mac串流传输Apple Music等您喜爱的音乐服务的音频,从而聆听完美同步到您的音箱AirPlay 2音源的音频。
JOSH.AI SMART HOME VOICE AUTOMATION
An elevated voice agent for the high-end smart home, Josh.ai offers flexible voice control for nearly any aspect of your day-to-day experience and entertainment environment. Use voice commands to control the thermostat, lights, home appliances, speakers, AVR and more. Josh.ai is installed by custom integrators and accessed through an app on your phone or tablet. Works with iOS and Android devices.HEOS BUILT-IN用于音乐无线串流传输
采用HEOS技术,在家中任何地方串流您喜爱的音乐。欣赏TuneIn等众多串流服务或本地音乐源的高品质音乐。通过免费的HEOS应用程序无缝控制一切。HEOS BUILT-IN FOR WIRELESS MUSIC STREAMING
Stream your favorite music from anywhere and everywhere around your home with HEOS Built-in technology. Enjoy high quality music from a wide range of streaming services including Spotify:registered:, TuneIn, Pandora:registered:, Amazon Prime Music, iHeartRadio, SiriusXM, Soundcloud:registered:, Tidal, Napster, Deezer or local music sources. Control it all seamlessly with the free HEOS app.PLAY YOUR MUSIC ANYWHERE WITH HEOS SPEAKERS
With the HEOS multi-room function, the Denon AVR-X2600H can connect with any other product with HEOS Built-in, like HEOS speakers, to play music throughout your entire home. Play the same song in every room or select a different song for each connected room — the choice is yours.使用HEOS扬声器在任何地方播放音乐
Denon AVR-X2600H具备HEOS多房间功能,可与任何其他采用HEOS Built-in的产品(如HEOS扬声器)连接,在整栋住宅各处播放音乐。在每个房间播放同一首歌,或为每个连通的房间选择不同的歌——选择权在您手里。Custom Install Ready
The Denon AVR-X2600H features external control and IP control capabilities for easy customization and compatibility with third-party integration solutions. It offers IP control capability for major third-party control devices, as well as Control4 SDPP (Simple Device Detection Protocol) certification for seamless integration with Control4 home automation equipment.Remote Monitoring Capability
In today’s custom install environment, it’s critical for integrators to provide quick, reliable assistance and service to their clients, even after the install is complete. To support this effort, the Denon IN-Command series AVR-X2600H AV receiver features “ihiji Invision”, “Domotz Pro” and "OvrC" remote monitoring and management interface and service compatibility. These programs allow custom integrators to monitor the status of connected products and troubleshoot remotely from the office or on the go, radically reducing the time it takes to address the issue.100+ Years of Firsts in Audio Technology
Founded in 1910, Denon has a deep heritage of “firsts” in audio technology — from Japan’s first audio electronics manufacturer, to producing the world’s first commercial CD player and Dolby Atmos-enabled AV receiver. This focused investment in audio R&D ensures you get the latest technology and highest quality with every listening experience.SPECIFICATION
Channels 7.2
1-Channel Driven:
Audio Processing
Auro 3D Support No
Video
Connectivity
2 x Optical TOSLINK
1 x Digital Coaxial
2 x 3RCA Component
2 x RCA Composite
4 x Stereo RCA
1 x 3RCA Component
1 x RCA Composite
1 x USB Type-A
1 x HDMI
1 x RJ45 (Ethernet)
Wi-Fi Yes
Bluetooth Yes
Tuner Section
Tuner Type AM, FM
FM: 87.5 to 108 MHz
Power
No Sound: 75 W
Physical
- Number of posts : 1323
» Denon AVR-X2600H 7.2 channel 4K Ultra HD AV Receiver (Sold)
» Denon AVR-X2600H (no longer available)
» Denon AVC-X3700H 9.2ch 8K Ultra HD AV Receiver
» Denon AVR-X1600H 7.2Ch 4K Ultra HD AV Receiver
» Denon AVR-X3600H 9.2 Ch 4K Ultra HD AV Receiver
