Tannoy Revolution XT8F Floorstanding Speaker
Tannoy Revolution XT8F Floorstanding Speaker  Empty Tannoy Revolution XT8F Floorstanding Speaker
Post by stylelaser.com.my Sat Aug 03, 2019 6:18 pm
Tannoy Revolution XT8F Floorstanding Speaker Brand New. Now Selling At RM9,999. Free Shipping Within West Malaysia.
REVOLUTION XT 8F
          Tannoy Revolution XT8F Floorstanding Speaker  Es_tan10
The new Omnimagnet Dual further refines bass performance with its linear LF response and exceptional timbre accuracy, while its new HF section with Torus-Ogive waveguide delivers smooth HF extension with outstanding imaging. The REVOLUTION XT 8F crossover uses low loss laminated core inductors and audiophile components throughout and further benefits from high purity oxygen free copper (OFC), silver plated wiring. The 49.4 litre REVOLUTION XT 8F cabinet houses the largest iteration of TANNOY new dual-cavity coupled reflex system, featuring separate cavities coupled internally by tuned ports. Bass energy exits from a tuned down-firing port between the angled base of the cabinet and the integrated plinth.
新Omnimagnet双进一步改进其线性低频响应和出色的音色准确性低音性能,同时与环面风帽波导其新的HF部分传送平滑HF扩展以优异的成像。革命XT 8F交叉使用低损耗叠片铁芯的电感器和整个高保真元件和从高纯度无氧铜(OFC)进一步的好处,镀银布线。所述49.4升REVOLUTION XT 8F柜容纳TANNOY新双腔耦合反射系统的最大迭代中,设有由调谐端口内部耦合单独的腔。从机柜的倾斜基地和综合底座之间的调低推端口的低音能量退出。
Tannoy Revolution XT8F Floorstanding Speaker  8796720103454
  • 2½ way floorstanding loudspeaker for medium to large sized rooms
  • Dual Concentric driver technology provides class-leading coherence and point-source imaging
  • 8” Dual Concentric and 8” mid/bass driver deliver unrivalled musical articulation and outstanding dynamics
  • Highly efficient 91 dB/Watt sensitivity and 400 Watt peak power handling deliver breath-taking dynamics and realism
  • Luxury real dark walnut veneer for a high end cabinet finish
  • Magnetic grille mounts provide a smooth and uncluttered front baffle appearance
  • New Dual Omnimagnet motor delivers smoother bass performance with exceptional transient attack
  • HF and LF drivers share single Omnimagnet optimising phase coherence for natural and expansive sound
  • Innovative shallow Torus Ogive waveguide allows rapid wavefront expansion improving high frequency directivity
  • Non-parallel trapezoidal cabinet disperses internal standing waves and reflections for low colouration
  • Internal bracing provides extra cabinet rigidity for exceptionally tight and controlled bass
  • Twin cavity-coupled reflex system delivers tuneful and musically coherent bass
  • Down-firing angled port reduces room boundary effects and facilitates easy loudspeaker placement
  • Top-adjustable floor spikes allow precise levelling of speaker cabinet
  • Integral plinth provides exceptional stability
  • TANNOY
    - 90 years of British sound heritage and innovation
  • Designed and engineered in the U.K.
  • 2.5路落地中等扬声器大大小的房间
  • 双同轴驱动器技术提供类领先的连贯性和点光源成像
  • 8” 双同轴和8” 个中/低音单元,具有无与伦比的音乐清晰度和出色的动力
  • 高效91分贝/瓦特的灵敏度和400瓦特峰值功率处理提供惊人的动力学和现实
  • 豪宅深色胡桃木饰面的高端橱柜饰面
  • 磁性格栅安装架提供光滑,整洁的前挡板外观
  • 新的双Omnimagnet电机提供具有卓越的瞬态进攻更流畅的低音表现
  • 高频和低频驱动器共享自然和广阔的声单Omnimagnet优化相位相干
  • 创新的浅圆环风帽波导允许快速扩张的波前提高高频的方向性
  • 非平行梯形箱体分散内部驻波和反射低着色
  • 内部支撑提供了额外的内阁刚度异常紧张和低音控制
  • 双腔耦合反射系统提供悦耳和音乐相干低音
  • 向下发射角度的端口降低房间边界效应,便于轻松扬声器放置
  • 顶底板可调尖峰让音箱的精密水准测量
  • 整体底座提供卓越的稳定性
  • TANNOY
    - 90年的英国声音传承与创新
  • 设计并在英国工程
          Tannoy Revolution XT8F Floorstanding Speaker  Es_tan12          Tannoy Revolution XT8F Floorstanding Speaker  Es_tan13
Peter  012-2536225
Fong   016-3098668
Tannoy Revolution XT8F Floorstanding Speaker  Trade
     Tannoy Revolution XT8F Floorstanding Speaker  Es_557     Tannoy Revolution XT8F Floorstanding Speaker  Es_480
Performance
Recommended Amplifier Power
(Watts RMS)
25 - 200
Continuous Power Handling
(Watts Peak RMS)
100
Peak Power Handling (Watts)
400
Sensitivity (2.83 Volts @ 1m)
91 dB
Nominal Impedance (Ohms)
8
Frequency Response (-6dB)
34 Hz - 32 kHz
Drive Units
Dual Concentric™ High Frequency
25 mm (1”) Linear PEI dome with Torus Ogive WaveGuide and Omnimagnet technology
Dual Concentric™ Low Frequency
200 mm (8”) multi-fibre paper 44 mm (1.75”) voice coil
Bass Driver
200 mm (8”) multi-fibre paper pulp cone with rubber surround. 44 mm (1.75”) edge wound voice coil
Crossover
Crossover Frequency
250 Hz & 1.8 kHz
Crossover Type
Passive low loss 2nd order low pass, 1st order high pass
Construction
Enclosure Type
Downwards ported twin cavity coupled reflex
Volume
48.8 l (1.72 cu. ft.)
Dimensions H x W x D
(incl. plinth)
1080 x 317 x 345 mm
(42.5 x 12.5 x 13.6”)
Weight
19.9 kg (43.9 lbs)
Finish    Piano Black
Number of posts : 1323
