Pioneer UDP-LX800 4K UHD Blu-ray Player With Jailbreak (Sold Out)
Pioneer UDP-LX800 4K UHD Blu-ray Player With Jailbreak Brand New. Now Selling At RM13,499. Free Shipping Within West Malaysia.
Flagship 4K UHD Universal Disc Player
此旗艦級 4K UHD 通用影碟播放機,是 Pioneer 多年不斷開發光碟播放器所累積的豐富專業知識之最佳體現。為帶來最理想光碟播放效果而精心設計,UDP-LX800 具備超高剛性之結構,實現高 S/N 訊噪比之高質素聲音及影像表現。透過支援最新 Ultra HD Blu-ray:tm:格式,你可以享受解像度高於 1,080p 全高清影像 4 倍的瑰麗畫面。採用一對並聯 ESS SABRE PRO 系列 DAC,提供發燒級聲音表現。其他功能包括 SDR / HDR 預設影像模式、直通模擬傳輸 / 數碼轉盤功能,與及 XLR 平衡輸出端子。
Ultra-Rigid Construction with Ventless Steel Plate Top Panel and Aluminium Side Panels
3 mm Steel Plate Rigid Under Base for Rigidity and Low Centre of Gravity
6-Layered IVH Main Circuit Board for High S/N Ratio
Rigid & Quiet BD Drive
Honeycomb Mechanism Drive Cover with Anti-Vibration Paint
Acoustic Damper Tray with Anti-Vibration Paint
Float-Mounting Structure
Anti-Standing Wave Insulators
4 Presets According to Display Type, with Automatic Detection/Switching for SDR/HDR Signals
Video Adjust
HDR10
Dolby Vision (Low Latency Compatible)
36-bit Deep Colour/”x.v.Colour”
Large-Capacity Power Supply Transformer
Custom Electrolytic Capacitors
Direct Function for Pure Analogue Audio Output
Transport Function for Pure Digital Audio/Video Output
Dual HDMI Output
PQLS Jitter-less Sound Transmission via HDMI (with compatible AV Receiver)
BD-Live/BONUSVIEW
Continued Viewing Playback
30 sec Skip Forward/10 sec Skip Back
Auto Power Off
Firmware Update (USB/Network)
Self-Illuminating Remote Control
DVD-ROM (DVD-Video/DVD-Audio)/DVD-R (DL)/DVD-RW/DVD+R (DL)/DVD+RW
Audio CD (CD-DA/SACD)/CD-ROM/CD-R/CD-RW
USB Memory/HDD
Digital Coaxial Out
Digital Optical Out
USB 2 In (1 Front, 1 Rear)
Ethernet
RS-232C
Analogue Audio Out (RCA Unbalanced, XLR Balanced)
Zero Signal Terminal (for Audio/Video Quality Tuning)
Power Consumption: 42 W
Power Consumption During Standby: 0.45 W (Full)/1.4 W (Network Standby On)
Dimensions (W X H x D): 435 x 131 x 339 mm
Weight: 13.8 kg
UDP-LX800
OVERVIEW
This flagship universal disc player is the embodiment of Pioneer’s considerable expertise amassed over the years through the development of successive optical disc players. Elaborately engineered for the ideal disc playback, the UDP-LX800 features extremely rigid construction to achieve high S/N ratio for quality audio and video performance. With support for the latest Ultra HD Blu-ray:tm: format, you can enjoy the beautiful spectacle with four times the resolution of 1080p Full HD. Two ESS SABRE PRO Series DACs are used in parallel to provide audiophile sound. Other features include SDR/HDR Preset Mode, Direct/Transport Function, and XLR balanced output terminal.此旗艦級 4K UHD 通用影碟播放機,是 Pioneer 多年不斷開發光碟播放器所累積的豐富專業知識之最佳體現。為帶來最理想光碟播放效果而精心設計,UDP-LX800 具備超高剛性之結構,實現高 S/N 訊噪比之高質素聲音及影像表現。透過支援最新 Ultra HD Blu-ray:tm:格式,你可以享受解像度高於 1,080p 全高清影像 4 倍的瑰麗畫面。採用一對並聯 ESS SABRE PRO 系列 DAC,提供發燒級聲音表現。其他功能包括 SDR / HDR 預設影像模式、直通模擬傳輸 / 數碼轉盤功能,與及 XLR 平衡輸出端子。
Three-Part Chassis Structure
The blocks for power supply, drive/digital processing, and analogue audio are separated into three to eliminate electrical and magnetic interference between the blocks. The rigid beams placed between the blocks further reinforce the structure, while the internal layout is optimally designed to minimize vibration and signal loss.三區域獨立區塊內部佈局
用於供電、碟盤/數碼處理及模擬音訊的線路板被劃分為 3 份,以消除線路板之間的電氣和磁干擾。在分區之間設置高剛性橫樑,進一步穩定內部結構,內部佈局亦針對減少振動及訊號流失作最佳化設計。Ultra-Rigid Construction with Ventless Steel Plate Top Panel and Aluminium Side Panels
Even the holes for heat radiation are excluded to realise a flat form with optimal electric circuit design, to minimise the mechanical motion sound from the BD drive. The result is significantly low noise and even more rigid and stable chassis structure.配備無散熱孔鋼製頂蓋及鋁製側板之超剛性結構
排除用作散熱的孔洞,實現最佳電路設計的平面形態,從而降低來自 BD 碟盤的機械運動聲音。而底盤結構亦更堅固穩定,更顯著地降低噪音。Rigid Under Base for Rigidity and Low Centre of Gravity
The 1.6 mm-thick chassis base is reinforced with a 3 mm-thick steel plate Rigid Under Base. This Double-Layered Chassis structure provides a low centre-of-gravity and overall rigidity that prevents the transfer of external vibration to the inner chassis, and offers a superior reading of the disc.剛性底盤實現高剛性及低重心
1.6mm 厚底層機殼以 3mm 厚不鏽鋼板加固。這種雙層機殼結構提供低重心及總體高剛性,有效防止外來震動轉往至內部機箱,從而提供卓越的光碟讀取效果。Large-Capacity Power Transformer and Power Supply Circuitry
The dedicated large-capacity power transformer for the analogue audio circuitry and the custom capacitor constitute the superior power circuitry capable of instantaneous power supply. The unnecessary electromagnetic wave generated by the transformer is confined within the copperplated shield case with anti-vibration paint. The f-hole-shaped embossing also helps to suppress standing-waves within the case, thereby achieving sound quality with both dynamic and silent features. The power supply circuitry has a case with an F clef emboss for suppressing standing waves, and black anti-vibration paint, allowing stable and high-quality power supply to the drive and digital blocks.大型電源變壓器及供電線路
用於模擬音訊線路之專用大型電源變壓器以及定製電容,帶來卓越電源線路以應付瞬時供電。變壓器產生之不必要電磁波,將被阻隔在帶有防振塗料的鍍銅屏蔽罩之內。「f 音孔」壓印標記有助於抑制機殼內的駐波,從而實現同時具備動態及寧靜特質之高音質。而供電線路加入帶有 「F 低音譜號」壓印標記的外殼,用作抑制駐波,而黑色抑振塗層則可為碟盤及數碼線路板,提供穩定及高質素的供電。Universal Disc Player with Ultra HD Blu-ray Playback
As a universal disc player, the UDP-LX800 can play various optical discs including the latest disc format Ultra HD Blu-ray which has four times the resolution of 1080p Full HD, as well as Hi-Res Audio and other music files, and video files.通用影碟播放機對應播放 Ultra HD Blu-ray
作為通用影碟播放機,UDP-LX800 能夠播放不同的光碟格式,包括最新格式 Ultra HD Blu-ray,擁有 4 倍於 1080p Full HD 的解像度,以及 Hi-Res Audio 高解析度音訊及其他音樂檔案,以至影像檔案。6-Layered Main Circuit Board for High S/N Ratio
A 6-layered IVH is used for the main circuit board to thoroughly eliminate digital noise. This optimises the digital signal wiring and minimises GND impedance, and dramatically improves S/N ratio in audio/video signal processing. The maximum 18 Gbps transmission through the latest HDMI standard becomes even more precise.高訊噪比 6 層主線路板
主線路板採用 6 層 IVH (內導通孔) 以徹底消除數碼噪音。此設計改善數碼訊號佈線及全面降低接地阻抗,顯著改善聲音/影像訊號處理的訊噪比。更可提升傳播最新 HDMI 標準高達 18Gbps 高容量傳輸訊號的精準度。Audio Circuitry for Quality Sound
The technologies for Pioneer’s SACD player PD-70AE is incorporated to further improve the analogue audio block. The paths for L and R signals are made identical including the pattern and parts layout. The L/R signal balance is strictly maintained, resulting in evermore precise and superior separation during playback. The bus bar between L and R signals also help to stabilize the ground.高音質音訊線路
搭載 Pioneer SACD 播放機 PD-70AE 的技術,進一步改善模擬音訊線路板。包括格局及零件佈局,左聲道及右聲道的訊號路徑完全相同,從而嚴格保持 L/R 訊號平衡,在播放過程中更為精準,及呈現更佳的分離度。左聲道及右聲道的訊號之間的母線,也有助於穩定接地。SDR/HDR Preset Mode for Optimal Performance for the Display
In addition to the video parameter “Reference” for reproducing the master quality, you can select “LCD TV”, “OLED TV”, or “Projector” for the video quality best suited to your display. Additionally, there are SDR/HDR presets for each video parameter, that automatically switches between SDR preset and HDR preset according to the output signal.SDR/HDR 預設模式,針對顯示器提供最佳表現
除了用作重現原生畫質的影像参數「Reference」外,你還可以選擇「LCD TV」、「OLED TV」或「Projector」(投影機),以獲得最適合你的顯示裝置之影像質素。此外,每個參數都設有 SDR/HDR 預設數值,可根據輸出訊號於 SDR 預設及 HDR 預設之間自動切換。Disc Information On-Screen Display
You can display the disc information on your screen by pressing and holding the remote control’s DISPLAY button. In addition to the playing disc’s details, you can easily check mastering information such as MaxFALL (Maximum Frame Average Light Level) and MaxCLL (Maximum Content Light Level) available on some HDR content, as well as HDMI output information.疊加屏幕影碟資訊顯示
你可以透過緊按遙控器的「DISPLAY」按鍵,在屏幕上疊加顯示影碟資訊。除了播放影碟的詳細資料,你還可以輕易地檢視部分 HDR 內容之母帶資料例如 MaxFALL(最大畫格平均亮度水平)及 MaxCLL(最大內容亮度水平),與及 HDMI 輸出資訊。Transport Function for Pure Digital Audio/Video Output
The function completely turns off the analogue audio circuitry from power supply to output, by cutting the power supply to the transformer during HDMI connection. The HDMI’s S/N ratio further improves and realises highquality audio and video playback.純數碼轉盤功能帶來純數碼音訊/影像輸出
此 Transport 功能由供電至輸出完全關閉模擬音訊線路。透過使用 HDMI 連接時切斷變壓器供電,可進一步提高 HDMI 的 S/N 訊噪比,實現高質素音訊及影像播放。Interested please feel free to contact:
Specification
Construction
Three-Block Internal Layout (Power Supply, Drive/Digital Processing, Analogue Audio)Ultra-Rigid Construction with Ventless Steel Plate Top Panel and Aluminium Side Panels
Video Features
Ultra HD Blu-ray Playback4 Presets According to Display Type, with Automatic Detection/Switching for SDR/HDR Signals
Video Adjust
HDR10
Audio Features
8ch Parallel Drive with SABRE ES9026PRO DAC x 2Large-Capacity Power Supply Transformer
Dual HDMI Output
Convenience
Disc/HDMI/HDR Information On-Screen DisplayBD-Live/BONUSVIEW
Auto Power Off
Playback Media
BD-ROM (UHDBD/3D BD/BD)/BD-R (DL)/BD-R LTH/BD-RE (DL)DVD-ROM (DVD-Video/DVD-Audio)/DVD-R (DL)/DVD-RW/DVD+R (DL)/DVD+RW
USB Memory/HDD
Terminals
HDMI 2 Out (1 Main for Audio/Video, 1 Sub for Audio)Digital Coaxial Out
Digital Optical Out
Ethernet
RS-232C
Power Requirements: AC 220-240 V, 50/60 HzPower Consumption: 42 W
Weight: 13.8 kg
- Number of posts : 1323
» Pioneer UDP-LX800 4K bluray player
» Pioneer BDP180 Bluray Player Jailbreak (Sold)
» Pioneer BDP180 Network 3D Blu-Ray Player Jailbreak Version
» Pioneer UDP-LX500 4K Bluray, SACD, DVD, CD Universal Disc Player (Jailbreak)
» Oppo Blu Ray player Jailbreak (Sold)
