Marantz M-CR612 Network CD Receiver
Marantz M-CR612 Network CD Receiver Brand New. Now Selling At RM3,599. Free Shipping Within West Malaysia.
Network CD Receiver Featuring HEOS, FM/AM, Bluetooth, AirPlay 2 and Voice Control Compatibility
Enjoy all your music from multiple sources in exquisite detail. The Marantz M-CR612 compact network CD receiver supports near limitless streaming platforms through AirPlay 2, Bluetooth and HEOS connectivity. Connect your speakers to the M-CR612 through four high-efficiency digital audio amplifier channels and enjoy the most musical sound. With two optical digital inputs, directly connect the M-CR612 to your television for elevated sonic output through your other Hi-Fi components. The built-in disc player is compatible with music CDs, CD-R/CD-RW recordable and erasable discs, and is equipped with an AM/FM tuner. Control the M-CR612 with your voice and your favorite voice agent — Amazon Alexa, Google Assistant and Apple Siri are all compatible for ultimate ease of use.
Key Features
特點:
The Most Musical Sound
Engineered and extensively tuned by a team drawing on more than 65 years of Hi-Fi expertise, the M-CR612 provides exceptional performance for your audio collection. Whether digital or analog, enjoy the most musical sound from any source.
最富音樂性的聲音
憑藉長達65年之久的Hi-Fi專業知識,通過團隊設計和深度調校,M-CR612為您收藏的音訊提供了出色的表現性能。不管是數碼還是模擬音訊,都能欣賞到最富音樂性的聲音。
配備了四個高效、低失真數碼放大器,能輕易將M-CR612配置成驅動兩對揚聲器並具有單獨音量控制,或將其配置成單獨以雙倍輸出功率驅動一對揚聲器,還可選擇連接一對高質的可以雙放大器驅動的揚聲器。
Elegant Design
The M-CR612 combines refined elegance and thoughtful design into a compact network CD receiver. Styled in a high-gloss black finish, the M-CR612 offers a beautiful look to complement its superb performance.
典雅設計和發燒音響構造
M-CR612將簡練典雅和深邃的設計融入緊湊的網路CD音響系統上。外觀採用光漆黑色和經典的銀金色外觀,M-CR612提供了美麗的設計,襯托其出色的性能。前面板上有兩道奢華的垂直發光色條額外彰顯其品質感。設計時考慮到現代音響發燒友的需要,製造時採用了高級材料以提高音訊品質。全面優化以盡可能再現最佳音訊性能,縮短的信號路徑減少了失真並改善了音質。高品質無源和有源元件提高聲音放大精准和音訊品質。
Digital Audio Amplifier Technology
Featuring four channels of high-efficiency, low-distortion digital audio amplification, easily configure the M-CR612 to drive two pairs of loudspeakers with independent volume control for each pair. Or, configure it to drive a single pair of speakers with double the output power, with the option to connect a pair of audiophile bi-amp compatible speakers. Additionally, the M-CR612 is fully compatible with low impedance speakers, including 4-Ohm models.
Built-in Wi-Fi and Bluetooth Wireless Streaming with Dual Diversity Antennas
Featuring dual diversity antennas, the M-CR612 lets you stream your favorite audio tracks wirelessly via Wi-Fi and Bluetooth. The dual diversity antenna system ensures stable streaming even in congested urban environments, and the Wi-Fi function features 2.4GHz(11b/g/n), 5GHz(11a/n) technology for compatibility with the widest range of smart devices. The M-CR612 offers quick and easy push button Wi-Fi protected setup and simple iOS Wi-Fi sharing.
HEOS Multi-Room Streaming
Built-in HEOS technology lets you enjoy your favorite music in any room of your home for a wireless, whole-home audio experience. Play the same song in every room, or select a different song for each connected room — the choice is yours. Enjoy music from Spotify, TuneIn Internet Radio, Sound Cloud, Tidal, Napster, Deezer or your local music file libraries. With additional HEOS products like the HEOS speaker range or other HEOS-capable receivers, easily play all of your music in one room or many.
Supports Major Voice Control Agents
Enjoy effortless voice control and total flexibility from the leading voice agents. Speak commands with Amazon Alexa, Google Assistant or Apple Siri. Ask to play your favorite music, turn the volume up, skip to the next track, switch inputs and more. Switch between voice agents, or pick a favorite to use — you’re in control. Functionality varies by voice agent.
AirPlay 2 + Apple Siri Voice Control
Stream audio from your favorite music services like Apple Music and Spotify or watch videos from services like YouTube and Netflix from any iPhone, iPad, Mac or Apple TV. Hear the audio perfectly synced to your speakers from AirPlay 2 sources.
AirPlay 2 also supports multi-room audio — wirelessly stream content to multiple AirPlay 2 compatible devices simultaneously with improved audio buffering to ensure smooth audio playback. AirPlay 2 provides control and grouping of compatible audio devices within the Apple Music or Home app. Use AirPlay 2 in-app or with your voice via Siri.
Amazon Alexa Voice Control
Use your voice to stream your favorite music services through Alexa to this device with HEOS built-in. Ask Alexa to play music from Pandora, Spotify, Amazon Music and more. Turn volume up or down, pause, mute and play the next song — all with your voice.
With HEOS Home Entertainment and Alexa, easily stream to this product and any other device with HEOS built-in.
Google Assistant Voice Control
Ask your Google Home, Google app or other devices with Google Assistant built-in to control content across your listening environment. Start music in the HEOS app, then ask your Google Assistant to control volume, play, pause, skip tracks and more. ‘Works with the Google Assistant’ feature is always improving.
Supports Wide Range of File Types, Including 2.8 and 5.6 MHz DSD
In addition to compatibility with conventional PCM audio tracks from digital audio sources such as CD, the M-CR612 supports all major audio file types.
Hi-Res Audio Support
Enjoy music exactly as the artist intended. The M-CR612 decodes hi-res audio ALAC, FLAC and WAV lossless files up to 24-bit/192-kHz, as well as DSD 2.8MHz and 5.6MHz tracks (the audiophile format of SACD).
2 Optical Digital Inputs
Connect your digital TV or cable/satellite set-top-box and a Blu-ray or DVD player to either of the two digital audio inputs to enjoy full dynamic range digital audio playback of your favorite movies and TV shows. The M-CR612 can automatically wake when sensing an audio signal from the television, and can be programmed to work with your TV’s remote for volume, mute and source selection.
Variable Output Terminal
Provides a selectable fix or variable level connection output to connect directly to powered speakers, active speakers or a power amplifier for digital source player/pre-amplifier use. Control volume with the remote handset or via compatible apps.
3-Line OLED Display
The front panel features a clear, legible three-line Organic Light Emitting Diode (OLED) display. Provides numerical and text display from a wide-angle view for easy operation and control.
Audiophile Construction
Designed with the modern audiophile in mind and crafted with superior materials that elevate audio quality. Fully optimized to reproduce the best audio performance possible, the compact signal paths reduce distortion and improve sound. Premium passive and active components amplify precision sound and audio quality.
Compact Chassis with Upgraded Cosmetics and New Accent Lighting
Place the M-CR612 anywhere you like with its compact chassis, which features upgraded cosmetics including a durable acrylic top plate cover. Deluxe vertical lighting accents on the front panel offer four user-selectable choices to perfectly match your taste.
More Than 65 Years of Audiophile Heritage
Founded in 1953, Marantz has a long and rich history of designing audiophile components embraced by music lovers and critical listeners around the world. Because Music Matters so much in our lives, the M-CR612 carries on the long Marantz tradition of delivering a superlative music listening experience.
設計優雅,具有CD播放、音樂串流媒體以及內置HEOS功能的真正Hi-Fi音響系統。
一看到全新的M-CR612,您就會知道這款最新音響是純淨和精緻的化身。它不僅外表出色,其性能也同樣出眾。多元化的網路接收播放機通過AirPlay 2、藍牙和HEOS WiFi連接功能支持幾乎不受限制的串流媒體平臺。可通過四個高效的數碼放大器將您的揚聲器連上M-CR612。利用兩個光纖數碼輸入,甚至可以連接電視以提升您的娛樂體驗。加上內置 DAB+/FM調諧器以及TuneIn Internet Radio(互聯網廣播)構成一套完整的音樂信源。如果您很在乎音樂,那麼M-CR612是您的首選音響系統。
特點:
最富音樂性的聲音
典雅設計和發燒音響構造
不受限制的音樂源
不僅能播放CD和DAB+/FM廣播。利用內置HEOS技術,可通過最方便的App應用操作欣賞您最喜歡的數碼音樂。享受Spotify,TuneIn Internet Radio ,Tidal或您當地音樂文件庫的音樂。使用附加HEOS元件,如HEOS揚聲器系列或其他支援HEOS AV接收機,輕鬆地在一個或多個房間播放您所有的音樂。AirPlay 2和藍牙功能讓您直接從智能手機輕鬆串流傳輸音樂和應用程式內容。
遠比Soundbar更好的音訊品質
將數碼電視或有線電視/衛星機上盒以及藍光或DVD播放機連接至兩個光纖數碼音訊輸入之一,可欣賞您最喜歡的電影和電視節目的全動態範圍數碼音訊播放效果。M-CR612可在檢測到電視音訊信號時自動喚醒,並能程式設計以配合電視機遙控器使用,進行音量、靜音控制和音源選擇。
支援主要的語音控制助手
通過先進的語音助手享受語音控制樂趣和全然靈活性。向Amazon Alexa, Google Assistant 或Apple Siri說出指令。請求播放您最喜歡的音樂、調整音量、跳到下一曲目、切換輸入源等等。在各語音助手之間相互切換,或選擇一個最喜歡的使用——都在您的控制中。功能會因語音助手不同而異。
超過65年的發燒傳統的傳承
馬蘭士創辦於1953年,具有悠久豐富的傳真音響器材設計歷史,其產品得到全球音樂愛好者和挑剔收聽者的推崇。因為音樂在我們生活中不可或缺,M-CR612延續了提供出色音樂收聽體驗的悠久馬蘭士傳統。
Media playback features:
Connections:
Dimensions and warranty:
Key Features
- Power and connectivity to suit your audio preference: 60W x 2ch (6 ohms), or 4 x 30W for speaker A/B with individual volume setting
- Plays CD, WMA/MP3 (CD-R/RW) and features an AM/FM tuner: No matter how you listen, enjoy your music with elevated Marantz sound
- Stream music from your favorite sources: Play songs from TuneIn, Internet Radio, Pandora, Spotify, SiriusXM, Amazon Prime Music, TIDAL and more via AirPlay 2, Bluetooth and the HEOS app (music streaming services may vary by region)
- Supports Amazon Alexa, Google Assistant and Apple Siri voice agents: Use your voice to control the M-CR612
- High-performance, high-resolution audio playback for every source: Supports WAV/FLAC/ALAC 192kHz/24bit, DSD 2.8/5.6MHz and Gapless playback (WAV/FLAC/ALAC, DSD)
- Built-in Bluetooth and Wi-Fi with 2.4GHz/5GHz dual band support: Improved network stability even in Wi-Fi-crowded homes
- Includes two digital Optical inputs for your TV or digital device: The M-CR612 automatically detects the signal input from your TV and outputs elevated sound
- Works with your TV remote: Program the M-CR612 to work with your TV remote and easily adjust volume up, volume down, mute and source selection
特點:
- 60W x 2聲道 (6 Ω)或4x 30W用於揚聲器A/B(帶獨立音量設置)
- 功率和連接性可適應苛刻的音訊偏好 - 播放CD、WMA/MP3 (CD-R/RW)並配備DAB+/FM調諧器
- 無論聽什麼,都能享受美妙的馬蘭士音質。 - 播放來自Internet Radio(互聯網廣播)的歌曲以及通過AirPlay 2或藍牙來自智慧手機上的歌曲
- 從您喜愛的各種音源串流傳輸音樂 - 支援Amazon Alexa, Google Assistant和Apple Siri語音助手
- 透過對相關語音裝備用語音控制M-CR612 - 支援MP3和無縫WAV/FLAC/ALAC 192kHz/24bit、DSD 2.8/5.6MHz播放
- 支援各種高性能、高清音訊播放 - 內置藍牙和Wi-Fi並支持2.4GHz/5GHz雙頻寬
- 改善了網路穩定性,特別是在Wi-Fi繁忙的家庭 - 包括兩個數碼光纖輸入和自動檢測電視或數碼設備
- M-CR612可檢測來自電視的信號輸入並輸出改善音訊 - 可配合現有電視遙控器使用
- 可學習遙控指令,M-CR612可配合電視遙控器使用,輕鬆調節音量升、降、靜音和選擇音源
最富音樂性的聲音
Elegant Design
典雅設計和發燒音響構造
3-Line OLED Display
特點:
最富音樂性的聲音
典雅設計和發燒音響構造
不受限制的音樂源
遠比Soundbar更好的音訊品質
支援主要的語音控制助手
超過65年的發燒傳統的傳承
Product highlights:
- 50 watts x 2 into 6 ohms (1 kHz) at 0.7% THD in stereo mode
- 4-channel amplifier lets you bi-amp one pair of speakers or drive a second pair in A/B configuration (4 x 30W)
- integrated CD player (plays standard CDs, CD-Rs, and CD-RWs)
- AM/FM tuner for listening to local radio
- dual-band Wi-Fi for music streaming over your wireless home network
- built-in Bluetooth:registered:
- works with Amazon Alexa, [url=https://www.crutchfield.com/g_463250/Voice-Control-Assistants.html?tp=72967#&nvpair=FFBrand|Google Home]Google Home[/url] and Siri voice control assistants
- compatible with HEOS wireless whole-home audio
- Apple:registered: AirPlay:registered: 2 for streaming music from an Apple device
- built-in streaming from Pandora, Spotify, SiriusXM, Amazon Prime Music, TIDAL and thousands of free Internet radio stations (subscription required for some services)
- plays high-resolution digital music files via USB storage device or a networked computer (PCM up to 24-bit/192kHz resolution; DSD up to 5.6 MHz .dsf files)
- gapless playback of digital music files (for WAV, FLAC, ALAC, AIFF, DSD only)
Connections:
- 2 optical digital inputs
- RCA analog stereo input
- analog stereo RCA output
- preamp output for a powered subwoofer
- Ethernet port for wired network connection
- rear USB input
- four pairs of binding post speaker connectors
- 3.5mm headphone output
- 11-1/16"W x 4-3/8"H x 11-15/16"D
- weight: 7.28 lbs.
- Number of posts : 1318
» Marantz M-CR612 (New)
» Marantz M-CR511 network receiver (black)
» Marantz SR7015 9.2ch. 8K Atmos Network AV Receiver
» Marantz NR1508 5.2Ch Network Av Receiver (Sold Out)
» Marantz SR6013 9.2Ch Atmos Network Av Receiver
