Xavian Madre Perla Floorstanding Loudspeaker
MADRE PERLA
“Nature in everything is enough for everything” Hippocrates
Wherever aesthetics and space allow, we offer a columned version of our most acclaimed Perla Esclusiva – the Madre Perla compact floorstander. It has all the advantages of the Perla Esclusiva, including its exceptionally compact footprint and yet great sound, but on a larger scale.
The solid oak wood enclosures, with their organic rounded edges, are inspired by natural principles, but inside they hide sophisticated technologies and high-end components.
Sophisticated crossovers with Mundorf and Janzten premium components connect the drivers in series with Fase Zero technology – the result is a harmonious and musical sound that is unique in its class, as evidenced by dozens of reviews from renowned world magazines.
The Madre Perla is a materialized fascination with music and a living euphoria of listening.
EXCLUSIVE SOLUTIONS:
-custom-made AudioBarletta drivers made in Italy
-extremely rigid enclosures from solid oak wood made by hand
-sand-filled bottom of the enclosure for better stability and resonance resistance
-organic shapes that blend easily into any interior
-five finishes to choose from
-front bassreflex for easy placement
-easy installation thanks to the leveler system (from September 2019)
-decorative pearl at the back, emphasizing the exceptional value of the speakers
drivers connected in series with Fase Zero technology
-precise internal damping using several layers of complementary materials.
Specification:
Mid Bass Frequency Unit
150 mm custom made XAVIAN – special polypropylene membrane – soft dome – die-cast chassis
High Frequency Unit
AudioBarletta – 26 mm voice coil, soft dome, short-circuiting copper rings, die-cast chassis with controlled radiation
System
two-way damped bassreflex, front firing slot bassreflex, “Fase Zero” crossover, high precision Mundorf capacitors
Corpus
massive “mosaic” oak, rests for 3 weeks before milling
Frequency Response
( -3dB on reference axis): 50 – 20000 Hz
Connection
1 pair of single mounted Xavian binding posts
Impedance
8 ohm
Crossover Frequency
3000 Hz
Sensitivity (2,83V / 1m)
88 dB
Recommended Amplification
30 – 120 W
Dimensions (HxWxD)
920 x 190 x 236 mm
Weight (1 Piece)
18 kg
Made in Czech Republic with using solid Italian Oak wood.
MRSP: RM11990.00
Contact: 0122876106 Matthew
You are welcome to audition at AFC Top Hi-Fi, BK5 Puchong!
Specification:
High Frequency Unit
System
Corpus
Frequency Response
Connection
Impedance
8 ohm
Crossover Frequency
3000 Hz
88 dB
30 – 120 W
Dimensions (HxWxD)
920 x 190 x 236 mm
Weight (1 Piece)
18 kg
MRSP: RM11990.00
Last edited by matthew on Thu Nov 14, 2019 7:09 pm; edited 2 times in total (Reason for editing : Edit error!)
matthew- Dealer\Reseller\Trader\Service Provider
- Number of posts : 102
Registration date : 2009-06-14
» Xavian Jolly Floorstanding Loudspeaker
» Xavian Perla Esclusiva (dark Oak) bookshelf speakers
» Xavian Joy Bookshelf Loudspeaker
» B&W floorstanding loudspeaker
» Kef Q900 floorstanding loudspeaker
