Xavian Jolly Floorstanding Loudspeaker
Xavian Jolly
Jolly, a floorstanding version of our Joy, uses premium materials and custom-made Xavian technology to combine the nobility of enclosure made from solid oak wood as we know it from the Natura series and the compact ground plan for which the Bon Bonus and Deliziosa are so popular.
Inside the classically looking enclosure are sophisticated technologies, as is customary in Xavian. We use our own custom-designed AudioBarletta drivers, optimized for use in this model, as well as our Fase Zero crossover technology with premium components.
Even this affordable model is made by hand in Hostivice near Prague and offers extraordinary musical experiences with a feeling of precious nobility and value.
PREMIUM SOLUTIONS:
Specification:
Mid Bass Frequency Unit
150 mm AudioBarletta – paper membrane – soft dust cup – copper short-circuiting cup on the pole piece – moulded basket
High Frequency Unit
AudioBarletta – 26 mm voice coil, impregnated silk dome
System
Two-ways damped bass-reflex, front passive membrane
Frequency Response
( -3dB on refrence axis): 50 – 20000 Hz
Connection
1 pair of terminals for banana plugs
Impedance
8 ohm
Crossover Frequency
3500 Hz
Sensitivity ( 2,83V / 1m )
85 dB
Recommended Amplification
30 – 140 W
Dimensions (HxWxD)
900 x 170 x 200 mm
Net Weight (1 Piece)
15 kg
Hand made in Czech Republic using Italian Oak solid wood!
MRSP: RM7880.00
Contact: 0122876106 Matthew
You are welcome to audition at AFC Top HI-Fi, BK5 Puchong.
PREMIUM SOLUTIONS:
- custom-made AudioBarletta drivers made in Italy
- enclosures made by hand from solid oak wood
- sand-filled bottom of the enclosure for better stability and resonance resistance
- front passive membrane (bass reflex) for easy placement
- "levellators" on the base, which makes it very easy to achieve the correct alignment of the enclosure (from September 2019)
- surprising bass range with regard to cabinet dimensions
- six elegant finishes to choose from
- magnetically attached cover grille
- drivers connected in series with our "Fase" Zero technology
Specification:
High Frequency Unit
System
Frequency Response
Connection
Impedance
8 ohm
Crossover Frequency
3500 Hz
85 dB
30 – 140 W
Dimensions (HxWxD)
900 x 170 x 200 mm
15 kg
MRSP: RM7880.00
matthew- Dealer\Reseller\Trader\Service Provider
- Number of posts : 102
Registration date : 2009-06-14
» Xavian Madre Perla Floorstanding Loudspeaker
» Xavian Joy Bookshelf Loudspeaker
» B&W floorstanding loudspeaker
» Kef Q900 floorstanding loudspeaker
» Thiel CS 3.6 Floorstanding Loudspeaker (Used) SOLD
