Focal Chora 826 Floorstanding Speaker Made In France
Focal Chora 826 Floorstanding Speaker Made In France Brand New. Now Selling At RM7,899. Free Shipping Within West Malaysia.
The Chora 826 bass-reflex loudspeaker is the embodiment of an accessible high-fidelity solution for a complete listening pleasure. Equipped with the exclusive Slatefiber cone developed and manufactured at the Focal site in France, the speaker drivers deliver balanced and precise midranges and perfectly articulated bass; leaving you to enjoy a big, full and generous sound. In addition, the presence of an aerodynamic front port eliminates distortion and gives more impact in the bass.
Its sleek, modern design combined with your choice of finish, and the tilted stand for a better sound image, make Chora 826 the flagship model of this line, ideal for large rooms.
Chora 826 低音反射扬声器体现了一种亲民的高保真解决方案。这些音响驱动配有在Focal法国工厂制造的专属石板纤维音盆,能够精准表现出均衡的中音效果和准确的低音;让您能够感受到宏大、饱满而大气的声音。此外,空气动力正面接口消除了失真,让低音更富有影响力。
它丝滑而富有现代感的设计会与您选择的饰面效果相结合,倾斜的支架会带来更好的音画效果,这些都让Chora 826成为该产品线中的旗舰型号,适合用于最大为431平方英尺(40平米)的房间。
The TNF Aluminium/Magnesium tweeter
SOFT AND PRECISE TREBLE
The surround linking the dome to its stand uses a memory foam material called Poron. This surround is directly derived from the Utopia’s famous Beryllium tweeter and reduces distortion by a third between 2,000Hz and 3,000Hz, the ear’s high-sensitivity range. The spatialisation and very low directionality of the inverted dome allow silky trebles to be heard from any point in your listening room.
TNF铝/镁高音喇叭
柔和和精准的高音
环绕音箱用名为Poron的记忆海绵材料将圆顶连接到支架上。该环绕音箱直接源自Utopia知名的铍高音喇叭,能够在2000Hz 和3000Hz之间减少 30%的失真,这是耳朵最高敏感度的范围。倒圆顶的空间化和极低的方向性能够然供您在房间内的任何一点都能听到丝滑的高音效果。
The Slatefiber cone
PERFECTLY BALANCED SOUND
Slatefiber technology, exclusive to Focal, involves the use of recycled, non-woven carbon fibres applied as a sandwich between two layers of thermoplastic polymer. In their quest for perfection, Focal engineers have opted to use non-woven carbon fibres, all pointing in the same direction to achieve even greater rigidity and better damping.
Manufactured in the Focal workshops using an ultra-modern industrial tool, the “slate” effect of the cone provides better damping and rigidity, but also lightness – the three “essentials” of a good speaker driver.
石板纤维音盆
完美均衡的声音
Focal专属的石板纤维技术涉及对再回收、无纺布碳纤维的运用,将其夹在两层热塑聚合物之间。为追求完美,Focal工程师们选择使用无纺布碳纤维,这些都是为了实现更大的刚性和更好的阻尼效果。
音盆是在Focal工厂中借助极为现代的工业工具打造而成,其“石板”效果具有更好的阻尼和刚性,同时也更轻便——这是优质音响驱动的三大“必备品质”。.
A SLEEK, MODERN DESIGN
The Chora range boasts a modern design, all lifted onto a tilted stand for Time Alignment, which provides an optimal soundstage, more focused on the listener. The slate colour of the Slatefiber cone adds a final refined, authentic touch.
顺滑而现代的设计
Chora系列以其富有现代感的设计为主要特色,将一切都置于倾斜的支架上,以达到”时间一致性”的效果。这提供了一种优化的声场,更加专注于聆听者。石板纤维音盆的“石板”颜色也让产品更显精致和逼真的感觉。
ON-TREND FINISHES
Chora is available in three finishes: Black, Light Wood and Dark Wood. On-trend colours that blend into different interiors and lend them a unique aesthetic signature.
时尚的饰面效果
Chora推出了3种饰面效果:黑色、浅木色和深木色。时尚的色彩与不同的室内装饰融为一体,让它们呈现出独特美感。
SPECIFICATION
Type 3-way bass-reflex floorstanding loudspeaker
Drivers 2 x 61/2" (16.5cm) Slatefiber Woofer
61/2" (16.5cm) Slatefiber Midrange
1" (25mm) TNF Al/Mg inverted dome tweeter
Sensitivity (2,83V/1m) 91dB
Frequency response (±3 dB) 48Hz-28kHz
Low frequency point (-6 dB) 39Hz
Nominal impedance 8Ω
Minimum impedance 2.9Ω
Recommanded amplifier power 40/250W
Crossover frequency 270Hz - 2.700Hz
Dimensions (WxDxH) 117/8x151/4x411/2" (30.3 x 38.8 x 105.3cm)
Net weight (unit with grille) 46.6lbs (21.15kg)
Packaging dimensions
(WxDxH)
441/2x133/8x187/8" (113x34x48cm)
Net weight (with packaging) 52.9lbs (24kg)
Focal Chora 826
Key points- High-fidelity 3-way loudspeaker providing precise, dynamic sound
- New speaker drivers with Slatefiber cone developed and manufactured in France by Focal
- Time Alignment thanks to the tilted stand: better soundstage
- Sleek, modern design
THE FLAGSHIP MODEL
3-WAY FLOORSTANDING LOUDSPEAKERThe Chora 826 bass-reflex loudspeaker is the embodiment of an accessible high-fidelity solution for a complete listening pleasure. Equipped with the exclusive Slatefiber cone developed and manufactured at the Focal site in France, the speaker drivers deliver balanced and precise midranges and perfectly articulated bass; leaving you to enjoy a big, full and generous sound. In addition, the presence of an aerodynamic front port eliminates distortion and gives more impact in the bass.
旗舰型号
3路落地式扬声器Chora 826 低音反射扬声器体现了一种亲民的高保真解决方案。这些音响驱动配有在Focal法国工厂制造的专属石板纤维音盆,能够精准表现出均衡的中音效果和准确的低音;让您能够感受到宏大、饱满而大气的声音。此外,空气动力正面接口消除了失真,让低音更富有影响力。
TNF铝/镁高音喇叭
柔和和精准的高音
The Slatefiber cone
石板纤维音盆
完美均衡的声音
顺滑而现代的设计
ON-TREND FINISHES
时尚的饰面效果
SPECIFICATION
(WxDxH)
- Number of posts : 1336
» Focal Chora 816 Floorstanding Speaker Made In France
» Focal Chora 806 Bookshelf Speaker Made In France
» Focal Chorus 716 Floorstanding Speaker France Made
» Focal Chora Speaker Stand ( Pair )
» Focal JMLab 702 Odeon K2 limited Execution FRANCE made Floorstanding Speaker (used)
