Focal Chora 806 Bookshelf Speaker Made In France
Focal Chora 806 Bookshelf Speaker Made In France Empty Focal Chora 806 Bookshelf Speaker Made In France
Post by stylelaser.com.my Sat Dec 21, 2019 10:58 am
Focal Chora 806 Bookshelf Speaker Made In France Brand New. Now Selling At RM3,899. Free Shipping Within West Malaysia.
          Focal Chora 806 Bookshelf Speaker Made In France Es_foc20          Focal Chora 806 Bookshelf Speaker Made In France Es_foc19
Chora 806
Key points
  • New speaker drivers with exclusive Slatefiber cone, developed and manufactured in France by Focal
  • Sleek, modern design that blends perfectly into interior living spaces
  • Optional stand available, tilted for Time Alignment
COMPACT BUT POWERFUL
2-WAY BOOKSHELF LOUDSPEAKER
The Chora 806 loudspeaker showcases meticulous manufacturing and design. Let yourself be transported by the delightful, dynamic musical quality emitted by its 61/2” (16.5cm) bass/midrange speaker driver, equipped with the exclusive Focal Slatefiber cone. Alongside the TNF Aluminium/Magnesium tweeter with its silky treble, the “slate” colour of the speaker driver makes it an attractive yet high-performance solution.
Perfectly balanced, this bookshelf speaker is ideal for rooms of up to 215ft² (20m²).
兼容并包却功能强大
2路书架式扬声器
Chora 806扬声器展示出精细的做工和设计。让自己沉浸在由61/2” (16.5厘米)音低音/中音响驱动发出的愉悦愉悦、动感的音质中。该驱动配有Focal专属的石板纤维音盆。除了能表现出丝滑高音的 TNF铝/镁高音喇叭,音响驱动的“石板”颜色也使其成为具有吸引力且性能卓越的解决方案。
这款书架式音响拥有完美的均衡效果,适合用于面积最大为215平方英尺(20平米)的房间。
The TNF Aluminium/Magnesium tweeter
SOFT AND PRECISE TREBLE
The surround linking the dome to its stand uses a memory foam material called Poron. This surround is directly derived from the Utopia’s famous Beryllium tweeter and reduces distortion by a third between 2,000Hz and 3,000Hz, the ear’s high-sensitivity range. The spatialisation and very low directionality of the inverted dome allow silky trebles to be heard from any point in your listening room.
TNF铝/镁高音喇叭
柔和和精准的高音
环绕音箱用名为Poron的记忆海绵材料将圆顶连接到支架上。该环绕音箱直接源自Utopia知名的铍高音喇叭,能够在2000Hz 和3000Hz之间减少 30%的失真,这是耳朵最高敏感度的范围。倒圆顶的空间化和极低的方向性能够然供您在房间内的任何一点都能听到丝滑的高音效果。
The Slatefiber cone
PERFECTLY BALANCED SOUND
Slatefiber technology, exclusive to Focal, involves the use of recycled, non-woven carbon fibres applied as a sandwich between two layers of thermoplastic polymer. In their quest for perfection, Focal engineers have opted to use non-woven carbon fibres, all pointing in the same direction to achieve even greater rigidity and better damping.
Manufactured in the Focal workshops using an ultra-modern industrial tool, the “slate” effect of the cone provides better damping and rigidity, but also lightness – the three “essentials” of a good speaker driver.
石板纤维音盆
完美均衡的声音
Focal专属的石板纤维技术涉及对再回收、无纺布碳纤维的运用,将其夹在两层热塑聚合物之间。为追求完美,Focal工程师们选择使用无纺布碳纤维,这些都是为了实现更大的刚性和更好的阻尼效果。
音盆是在Focal工厂中借助极为现代的工业工具打造而成,其“石板”效果具有更好的阻尼和刚性,同时也更轻便——这是优质音响驱动的三大“必备品质”。.
A SLEEK, MODERN DESIGN
The Chora range offers a modern design, the slate colour of the Slatefiber cone adding a final refined, authentic touch.
The stand (optional) is tilted for Time Alignment which provides an optimal soundstage, more focused on the listener.
顺滑而现代的设计
Chora系列为您带来富有现代感的设计,同时石板纤维音盆的“石板”颜色也让产品更显精致和逼真的感觉。
支架(可选)有倾斜度以达到“时间一致性”的效果,为您带来最好的声场效果,更加注重聆听者。
ON-TREND FINISHES
Chora is available in three finishes: BlackLight Wood and Dark Wood. On-trend colours that blend into different interiors and lend them a unique aesthetic signature.
时尚的饰面效果
Chora推出了3种饰面效果:黑色浅木色深木色。时尚的色彩与不同的室内装饰融为一体,让它们呈现出独特美感。
                                                            Focal Chora 806 Bookshelf Speaker Made In France Es_foc18
Peter  012-2536225
Fong   016-3098668
Focal Chora 806 Bookshelf Speaker Made In France Trade
          Focal Chora 806 Bookshelf Speaker Made In France Es_foc21          Focal Chora 806 Bookshelf Speaker Made In France Es_foc23
SPECIFICATION
Type 2-way bass-reflex bookshelf loudspeaker
Drivers 61/2" (16.5cm) Slatefiber Midbass
1" (25mm) TNF Al/Mg inverted dome tweeter
Sensitivity (2,83V/1m) 89dB
Frequency response (±3 dB) 58Hz-28kHz
Low frequency point (-6 dB) 49Hz
Nominal impedance 8Ω
Minimum impedance 4.6Ω
Recommanded amplifier power 25/120W
Crossover frequency 3.000Hz
Dimensions (WxDxH) 81/4x105/8x1631/32" (21x27x43.1cm)
Net weight (unit with grille) 16.2lbs (7.35kg)
Packaging dimensions
(WxDxH)
231/4x153/8x207/8" (59x39x53cm)
Net weight (with packaging) 39.6lbs (18kg)
                                             Focal Chora 806 Bookshelf Speaker Made In France Es_foc22
Number of posts : 1323
