Marantz HD-DAC1 HEADPHONE AMPLIFIER WITH DAC (New)
HD-DAC1
HEADPHONE AMPLIFIER WITH DAC-MODE
Marantz HD-DAC1 Headphone Amplifier with
DAC-mode
The powerful HD-DAC1 can drive audiophile high-impedance headphones up to 600 ohm - with complete MODE ease. All thanks to its three-level gain control, Marantz HDAM-SA2 modules, a high current audiophile DAC (CS4398), and its Premium Quality fixed and variable RCA outputs. It is so powerful it not only drives headphones, you can also directly connect it to your Hi-Fi integrated amplifier or to a pair of active speakers or power amps. It’s also highly connectable.
Optical and coaxial digital inputs as well as a USB-B port enable you to stream music directly from your PC or MAC; iDevices can also be connected via the USB port on the front. For even more connectivity we have also included an analog input. The USB-B works in asynchronous mode to support not only 192 kHz / 24bits high-resolution audio but also the DSD 2.8MHz and 5.6MHz for maximized performance and the most direct way to enjoy excellent quality. To safeguard quality when connected to a computer, we built extended isolation around the USB-B input to eliminate the chance of a high frequency noise being generated by the computer when entering the HD-DAC1. We even included a jitter remover and Dual Clock for extreme accuracy. Info on volume, input, resolution, etc. is shown on the stylish Marantz Porthole Display. The solid aluminum front is supported by a double layer bottom plate and retro-style side panels. Pure craftsmanship.
SPEC:https://www.us.marantz.com/en-us/shop/hificomponents/hddac1
All Stock Is New In Box.
Warranty 12 Month.
Rm5,699
Free Mytery Gift.
Free Postage In Peninsular Malaysia.
Whatapps Mr Jung 0162215648
Last edited by yong zhen jung on Sat Apr 09, 2022 11:07 am; edited 3 times in total
yong zhen jung- Frequent Contributor
- Number of posts : 1092
Registration date : 2018-11-20
» Marantz AV7705 Surround Pre-Amplifier & Marantz MM8077 Power Amplifier
» Marantz HD-DAC1 Desktop DAC, Pre-amp, Headphone Amplifier
» Marantz HD-DAC1 -DSD DAC,headphone amp.preamp, SOLD
» Marantz AV7706 Surround Pre-Amplifier & Marantz MM8077 Power Amplifier (Out of Stock)
» Marantz AV8805 Surround Pre-Amplifier & Marantz MM8077 Power Amplifier
