Marantz AV7705 Surround Pre-Amplifier & Marantz MM8077 Power Amplifier
Marantz AV7705 Surround Pre-Amplifier & Marantz MM8077 Power Amplifier Brand New. Now Selling At RM23,999. Free Shipping Within West Malaysia.
11.2CH 4K Ultra HD AV Surround Pre-Amplifier with IMAX Enhanced, Dolby Atmos, Auro-3D, HEOS, AirPlay 2 and Alexa Voice Compatibility
Featuring 11.2 channel XLR and RCA pre-outs, the Marantz AV7705 supports all three-dimensional audio format Dolby Atmos, DTS:X, Auro-3D and DTS Virtual:X. For pristine picture quality, an advanced HDMI section supports 4K full-rate pass-through, 4:4:4 pure color, HDR and HDCP2.2. Enjoy audio playback with exceptional quality thanks to Marantz-proprietary HDAM modules and stream from Pandora, Spotify, TIDAL, Deezer and more with HEOS built-in. Ideal for custom integrations, the AV7705 features Creston Control and RS-232C serial port for third-party remote monitoring. Calibrate your listening environment with the full suite of Audyssey EQ tools and control the pre-amplifier with your voice and Amazon Alexa voice compatibility.
Key Features
150W 7-CHANNEL CURRENT FEEDBACK POWER AMPLIFIER CIRCUIT FOR SUPERIOR SOUND
The MM8077 is expertly crafted to meet all your high powered needs and drive even the most demanding speakers by designing the entire unit to deliver consistent and precise power wherever and however you need it.
Marantz AV7705 Specs
Connectivity
Bluetooth Version: 3.0 + EDR (Enhanced Data Rate)
Supported Profiles: A2DP 1.2, AVRCP1.5
Supported Codec: SBC
Range: 98.4' / 30 m in line of sight
Transmission Range (A2DP): 20 Hz to kHz
AirPlay Yes, AirPlay 2
Wi-Fi Dual-band (2.4/5 GHz) Wi-Fi 4 (802.11a/b/g/n)
Wi-Fi Security WEP 64-bit, WEP 128-bit, WPA/WPA2-PSK (AES), WPA/WPA2-PSK (TKIP)
Supported File Types WMA, MP3, WAV 192/24, MPEG-4 AAC, FLAC, FLAC HD 192/24, ALAC 192/24, DSD, Apple Lossless
Inputs 8 x HDMI (1 front)
3 x RCA component video
4 x RCA composite video (1 front)
2 x optical TOSLINK
2 x digital coaxial
6 x stereo RCA (1 front)
1 x stereo RCA phono with ground screw
1 x 7.1-channel RCA
1 x USB (front)
Outputs 3 x HDMI
1 x 11.2-channel XLR pre-out
1 x 11.2-channel RCA pre-out
2 x stereo RCA pre-outs (Zone 2/3)
1 x 1/4" / 6.35 mm headphone (front)
Other Ports 1 x RJ45 Ethernet LAN
1 x RCA remote in
1 x RCA remote out
2 x 1/8" / 3.5 mm trigger out
1 x 1/8" / 3.5 mm IR flasher in
1 x RS-232C
2 x wireless antennas
1 x FM antenna in
1 x AM antenna in
1 x 1/8" / 3.5 mm setup mic in (front)
Input Sensitivity Analog Audio: 200 mV
Phono: 2.5 mV
Rated Output Unbalanced RCA: 1.2 V
Balanced XLR: 2.4 V
D/A: 2 V (at 0 dB playback)
Input/Output Level and Impedance Composite, Component Y-Signal: 1 Vp-p, 75 Ohms
Component PB/CB, PR/CR Signal: 0.7 Vp-p, 75 Ohms
Audio
Audio Formats Dolby Atmos, Dolby TrueHD, Dolby Surround, DTS:X, DTS Neural:X, DTS Virtual:X, DTS HD Master, Auro-3D, Aurmatic, IMAX Enhanced
DAC 32-bit AKM D/A converters on all channels
Frequency Response Analog: 10 Hz to 100 kHz (+1, -3 dB, direct mode)
Signal to Noise Ratio Analog: 105 dB (IHF-A weighted, direct mode)
Phono: 74 dB (A weighting, with 5 mV input)
Digital: 102 dB
Distortion Analog: 0.005% (20 Hz to 20 kHz, direct mode)
Phono: 0.03% (1 kHz, 3 V)
Total Harmonic Distortion D/A Output: 0.008% (1 kHz, at 0 dB)
Dynamic Range D/A Output: 100 dB
Deviation RIAA: ±1 dB (20 Hz to 20 kHz)
Video
HDR Support HDR10, Dolby Vision, HLG pass-through
HDCP Version 2.2
Upscaling Up to 4K/60p, analog to HDMI, HDMI to HDMI
Frequency Response Composite Video: 5 Hz to 10 MHz (0, -3 dB)
Component Video: 5 Hz to 60 MHz (0, -3 dB)
Tuner
Tuner Bands AM, FM
Frequency Range AM: 520 to 1710 kHz
FM: 87.5 to 107.9 MHz
Sensitivity Effective, AM: 18 μV
Effective, FM: 1.2 μV (12.8 dBf)
50 dB, Mono FM: 2.8 μV (20.2 dBf)
Signal to Noise Ratio FM, Mono: 70 dB (IHF-A weighted, direct mode)
FM, Stereo: 67 dB (IHF-A weighted, direct mode)
Distortion FM, Mono: 0.7% (1 kHz)
FM, Stereo: 1% (1 kHz)
Physical Specifications
Power Requirements 240 VAC, 50/60 Hz
Power Consumption (Active) 60 W
Standby Power Consumption 0.2 W
CEC Standby: 0.5 W
Dimensions With Antennas Down: 17.38 x 7.38 x 16.25" / 440 x 185 x 411 mm
With Antennas Up: 17.38 x 9.75 x 16.25" / 440 x 247 x 411 mm
Weight 22.93 lb / 10.4 kg
Packaging Info
Package Weight 28.6 lb
Box Dimensions (LxWxH) 21 x 19.8 x 11.4"
Marantz MM8077 Specs
Channels 7
Power Output 8 ohms Rated: 150 W per channel (20 Hz to 20 kHz, THD = 0.08%, 2-channels driven)
6 ohms Rated: 180 W per channel (20 Hz to 20 kHz, THD = 0.08%, 2-channels driven)
6 ohms Maximum: 210 W per channel (1 kHz, THD = 10%, 2-channels driven)
Output Connectors 6 to 8 ohms
Frequency Response 8 Hz to 100 kHz (1 W, 8 ohms) (± 3 dB)
Damping Factor 100
Input Sensitivity/Impedance 1.2 V / 22 k ohms (unbalanced)
2.4 V / 30 k ohms (balanced)
Signal-to-Noise Ratio 105 dB (IHF-A)
Voltage Amplification Level 29 dB
Input & Output 7 x Balanced inputs
7 x Unbalanced inputs
7 x Speaker channels
1 x IR flasher input
1 x DC control input
1 x DC control output
1 x Remote control input
1 x Remote control output
Switch Balanced and unbalanced
Supply Voltage 240 VAC, 50/60 Hz
Power Consumption Operational: 800 W
Standby: 0.4 W
Dimensions (WxHxD) 17.3 x 7.3 x 15.1" / 440.0 x 185.0 x 383.5 mm
Weight 39.7 lb / 18.0 kg
AV7705
Key Features
- 11.2 channel XLR pre-out; 11.2 channel RCA pre-out
- 8 HDMI inputs (incl. 1 front) with full HDCP 2.2 support; 3 HDMI outputs (incl. Zone 2)
- 4K/60 Hz full-rate pass-through, Dolby Vision compatibility, HDR, HLG and BT.2020
- Advanced video processing with analog to HDMI conversion; SD to HD/4K upscaling
- Dolby Atmos, DTS:X (up to 7.1.4 with an external 2ch amplifier), Auro-3D and DTS Virtual:X for height virtualization effects
- eARC (Enhanced Audio Return Channel) support via firmware update supports the most advanced surround and object-based audio formats via single HDMI connection between AVRs and compatible TVs
- Stream music from Internet Radio, Spotify Connect, Pandora, SiriusXM, Amazon Music, TIDAL, Deezer and more with Bluetooth, Airplay2 or HEOS built-in
- Built-in Wi-Fi with 2.4GHz/5GHz dual band support
- Enjoy multi-room whole-home audio streaming with HEOS technology
- Amazon Alexa voice control via the HEOS Home Entertainment skill
- Marantz 2016 AVR remote app for control over the latest generation of Marantz network AV Receivers. Available on iOS and Android.
- High resolution DSD (2.8/5.6MHz), FLAC, ALAC and WAV support
- AKM AK4458 32-bit D/A converters, HDAM circuit boards and Current Feedback circuitry for optimum fidelity and maximum dynamic range
- Suite of Audyssey room correction software: Audyssey MultEQ XT32, Dynamic Volume and Dynamic EQ, LFC and Sub EQ HT
- Third-party integration and IR remote control, RS-232C serial port and Creston Connected for external control
- Seamless out-of-the-box experience with Quick Start Guide, guided Setup Assistant and Marantz AVR Remote App
MM8077
Key Features
Clean And Consistent Power
The power supply features a high current toroidal power transformer along with high power (71WVDC) filter capacitors with a total 100,000µF capacitance to easily handle sharp short-term transient peaks.Ultimate Powerhouse
Designed for the ultimate music and movie surround sound experience, the Marantz MM8077 7-channel power amplifier delivers power and detail, and is rated at 150 watts per channel into 8 ohms, and 180 watts per channel into 6 ohms.Power The Most Demanding Of Systems
Designed for the ultimate music and movie surround sound experience, the Marantz MM8077 7-channel power amplifier delivers power and detail, and is rated at 150 watts per channel into 8 ohms, and 180 watts per channel into 6 ohms.Toroidal Transformer Power Supply
The power supply features a high current toroidal power transformer along with high power (71WVDC) filter capacitors with a total 100,000µF capacitance to easily handle sharp short-term transient peaks.Featuring Our Unique Current Feedback
Featuring our unique current feedback discrete power amp output stages that are identical for all channels, the MM8077 is equipped with multiple high current discrete power transistors that feature high slew rate and wide operating bandwidth to extract the most detail from today’s high resolution audio formats.Masterfully Built
The output devices are mounted on our unique dual extruded aluminum alloy heat sink assembly, configured in a tunnel arrangement that provides both passive and active cooling. The massive heat sinks feature multiple ribbed fins that provide a large passive cooling area, and the assembly is book-ended with a whisper quiet fan that automatically kicks in to provide near silent active cooling when the soundtrack heats up. As the fan is mounted internally directly to the heat sinks, and not externally to the chassis cover as is often the case, even when it’s running, it’s designed to be whisper quiet.Interested please feel free to contact:
Connectivity
2 x optical TOSLINK
2 x digital coaxial
1 x 7.1-channel RCA
1 x USB (front)
Outputs 3 x HDMI
1 x RCA remote in
1 x RCA remote out
1 x RS-232C
1 x FM antenna in
1 x AM antenna in
Phono: 2.5 mV
Balanced XLR: 2.4 V
Audio
Digital: 102 dB
Video
HDCP Version 2.2
Tuner
Tuner Bands AM, FM
CEC Standby: 0.5 W
Packaging Info
Channels 7
Damping Factor 100
Standby: 0.4 W
- Number of posts : 1318
» Marantz AV7706 Surround Pre-Amplifier & Marantz MM8077 Power Amplifier (Out of Stock)
» Marantz AV8805 Surround Pre-Amplifier & Marantz MM8077 Power Amplifier
» Marantz AV7705 11.2Ch 4K Ultra HD AV Surround Pre-Amplifier
» Marantz MM8077 (NEW)
» Marantz MM8077 7CH Power Amplifier(Sold)
