Project Elemental Phono USB Turntable
Item: Project Elemental Phono USB Turntable
Colour: Available in Grey and White
Condition: Brand New
Price:RM1450.00 RM1087.50
Warranty: 1 Year
Contact: Please PM me to purchase.
Details:
Plug & Play turntable with phono pre-amp and USB output
Maximum simplicity & outstanding sound quality!
Pro-Ject has decided to go after the entry-level market with an high quality alternative that comes complete with an Ortofon cartridge. The new Elemental table is a real plug & play in every way. No adjustment of counterweight and antiskating is needed, because both are pre-adjusted. This new straight ultra low mass tonearm is optimised for the included Ortofon OM 5E cartridge. The built-in phono stage allows you an easy connection to any standard Line Level inputs and with the USB output you are able to record your vinyl collection.
The hidden secret to the new table’s sonic success, is a central gravity mass point, made from an artificial stone which is placed directly underneath the platter bearing. It is capable to fully absorb unwanted rumble and motor vibration. This turntable appears to be pure simplicity itself, while maintaining high quality audio standards and vinyl recording capability.
Features
Technicial Specifications
Price:
Warranty: 1 Year
Details:
Features
- Belt drive system
- Integrated motor control with DC power supply secures silent running
- Central gravity mass point made from artificial stone
- Main platter bearing made from stainless steel runs in bronze bushing with Teflon bottom
- Low resonance particle board platter with felt mat
- 8.6” ultra low mass tonearm with straight arm tube
- Pre-adjusted tracking force & antiskating
- Gold-plated RCA contacts & cartridge pins
- Integrated phono stage with precise RIAA equalization
- Line level output
- A/D converter for vinyl recording with USB B output
- Colour options: red-black, white-black, silver-black
- speed: 33, 45 (manual speed change)
- speed variance: 33: 0,80% 45: 0,70%
- wow & flutter: 33: 0,29% 45: 0,27%
- platter: 300mm particle board
- tonearm: 8,6” metal tube
- effective arm length: 218,5 mm
- overhang: 22,0 mm
- effective tonearmmass: 8,0gr
- counterweight for cartridge mass: 3 - 5,5g (included)
- tracking force range: 0 - 30mn (OM5 18mn pre-adjusted)
- A/D conversion: 16bit Delta Sigma
- output: RCA & USB-B
- included accessory: RCA cable, USB B cable, 15V DC power supply
- power consumption: 5,0 watts
- dimensions: 415 x 90 x 300mm (WxHxD)
- weight: 2,7 kg
Last edited by Charles B&W TEG on Fri Oct 02, 2020 12:42 pm; edited 1 time in total
Charles B&W TEG- Dealer\Reseller\Trader\Service Provider
- Number of posts : 331
Registration date : 2019-01-25
» Project Elemental Phono USB Turntable (new - sealed)
» Project Elemental TT brand new
» Project phono box s
» Project phono box
» project tubebox ds2 phono
» Project phono box
