Cary Audio SLP-98L Tube Preamplifier with External Power Supply
Item: Cary Audio SLP-98L Tube Preamplifier with External Power Supply
Condition: Like New Unit. With original Remote Control.
New Unit Price is USD4,995
Selling this unit for onlyRM12,800 RM9,200 or swap/topup
Cary Audio has offered this preamplifier and its predecessors for over 20 years, and it is still as musically satisfying today as it was then. Continuing to be hand-built and hand-wired in North Carolina, and utilizing matched tubes and zero feedback for the most accurate musical presentation. What’s more, the SLP-98 uses an external power supply and enclosure, like its big brother the SLP-05, to keep any high voltage electrical noise away from the circuits that handle the delicate musical reproduction.
With five inputs, the SLP-98 can manage an elaborate system, and gives you the convenience of remote volume control. With turntables and vinyl making a big comeback, we even offer an optional built-in phono stage for MM cartridges, truly making it a value for its level of performance (model SLP-98P with phono stage, SLP-98L as a line-stage only). Regardless of whether you listen to vinyl records, tape, CDs, or any of today’s digital sources, the SLP-98 will elevate your sources to levels you didn’t think were possible.
Product Information:
http://caryaudio.com.au/product/slp89p-preamplifier-silver/
https://sg.carousell.com/p/cary-audio-slp-98-vacuum-tube-preamplifier-158491144/
https://www.ebay.com/itm/183847877216
https://www.audiogon.com/listings/lis9f21b-pass-labs-x350-8-solid-state?refsource=hifishark
https://www.stereophile.com/tubepreamps/204cary/index.html
http://www.audioreview.com/product/amplification/preamplifiers/cary-audio-design/slp-98l.html
https://www.upscaleaudio.com/products/cary-audio-slp-98p-formula-1-edition
https://www.stoneaudio.co.uk/?product=cary+audio+slp%2D98+valve+pre+amplifier
https://hometheaterreview.com/cary-audio-slp-98l-preamplifier-reviewed/
Circuit Type | Class A Triode |
Output | Rated 2 volts, 12 volts maximum |
Gain | 20dB – Line Stage 43 dB – Phono Stage (SLP 98P only) |
Noise and Hum | -88 dB below full output |
Input Impedance | 50,000 Ohms – Line 47,000 Ohms – Phono |
Output Impedance | 440 Ohms |
Frequency Response | 5 Hz to 163,000 Hz |
Tubes | 4 ea – 6SN7 Line Stage 2 ea – 12AX7 Phono Stage 2 ea – 12AU7 Phono buffer |
Power Transformer(s) | EI Laminate, 200% Duty Cycle |
Resistors | 1% Metal Film |
Capacitors | Polystyrene, Film and Foil (Optional Oil-Filled) |
Power Supply Capacitors | 4 ea – 560µF @ 400 VDC |
AC Cord | 3 Conductor, Detachable |
AC Power Requirements | 117/234 VAC @ 50/60 Hz |
Consumption | 44 watts – Operation |
Warm-Up Time | 3 Minutes |
Break-In Time | 100 hours of playing time |
Finish | Anthracite black chassis with silver or black aluminum faceplate |
Weight | 22 lbs |
Dimensions | 5″ H x 12.5″ W x 12″ D |
» Cary Audio SLP-98L Tube Preamplifier with External Power Supply
» Leben RS28CX flagship tube Pre-amp with external power supply ( display set )
» Cary Audio Design SLP-50 Tube Preamplifier and CAD-40M Signature Edition Class A Tube Mono-Blocks (Used) SOLD
» Onix OA24 preamplifier with Onix SOAP2 external power supply
» Naim Audio "Olive" Series Hi-Cap External Power Supply Unit
