Cary Audio SLP-98L Tube Preamplifier with External Power Supply
Cary Audio SLP-98L Tube Preamplifier with External Power Supply Empty Cary Audio SLP-98L Tube Preamplifier with External Power Supply
Post by raymond88 Tue Mar 03, 2020 1:26 pm
Item: Cary Audio SLP-98L Tube Preamplifier with External Power Supply
Condition: Like New Display Unit. With original Remote Control.
New Unit Price is USD4,995
Selling this unit for only RM7,500 or swap/topup
Cary Audio SLP-98L Tube Preamplifier with External Power Supply C810
Cary Audio SLP-98L Tube Preamplifier with External Power Supply C910
Cary Audio SLP-98L Tube Preamplifier with External Power Supply C1010
Cary Audio has offered this preamplifier and its predecessors for over 20 years, and it is still as musically satisfying today as it was then. Continuing to be hand-built and hand-wired in North Carolina, and utilizing matched tubes and zero feedback for the most accurate musical presentation. What’s more, the SLP-98 uses an external power supply and enclosure, like its big brother the SLP-05, to keep any high voltage electrical noise away from the circuits that handle the delicate musical reproduction.
With five inputs, the SLP-98 can manage an elaborate system, and gives you the convenience of remote volume control. With turntables and vinyl making a big comeback, we even offer an optional built-in phono stage for MM cartridges, truly making it a value for its level of performance (model SLP-98P with phono stage, SLP-98L as a line-stage only). Regardless of whether you listen to vinyl records, tape, CDs, or any of today’s digital sources, the SLP-98 will elevate your sources to levels you didn’t think were possible.
Product Information:
Circuit Type
Class A Triode
Output
Rated 2 volts, 12 volts maximum
Gain
20dB – Line Stage
43 dB – Phono Stage (SLP 98P only)
Noise and Hum
-88 dB below full output
Input Impedance
50,000 Ohms – Line
47,000 Ohms – Phono
Output Impedance
440 Ohms
Frequency Response
5 Hz to 163,000 Hz
Tubes
4 ea – 6SN7 Line Stage
2 ea – 12AX7 Phono Stage
2 ea – 12AU7 Phono buffer
Power Transformer(s)
EI Laminate, 200% Duty Cycle
Resistors
1% Metal Film
Capacitors
Polystyrene, Film and Foil
(Optional Oil-Filled)
Power Supply Capacitors
4 ea – 560µF @ 400 VDC
AC Cord
3 Conductor, Detachable
AC Power Requirements
117/234 VAC @ 50/60 Hz
Consumption
44 watts – Operation
Warm-Up Time
3 Minutes
Break-In Time
100 hours of playing time
Finish
Anthracite black chassis with silver or black aluminum faceplate
Weight
22 lbs
Dimensions
5″ H x 12.5″ W x 12″ D
Cary Audio SLP-98L Tube Preamplifier with External Power Supply C113
Cary Audio SLP-98L Tube Preamplifier with External Power Supply C213
Cary Audio SLP-98L Tube Preamplifier with External Power Supply C313
Cary Audio SLP-98L Tube Preamplifier with External Power Supply C511
Cary Audio SLP-98L Tube Preamplifier with External Power Supply C610
http://caryaudio.com.au/product/slp89p-preamplifier-silver/
https://sg.carousell.com/p/cary-audio-slp-98-vacuum-tube-preamplifier-158491144/
https://www.ebay.com/itm/183847877216
https://www.audiogon.com/listings/lis9f21b-pass-labs-x350-8-solid-state?refsource=hifishark
https://www.stereophile.com/tubepreamps/204cary/index.html
http://www.audioreview.com/product/amplification/preamplifiers/cary-audio-design/slp-98l.html
https://www.upscaleaudio.com/products/cary-audio-slp-98p-formula-1-edition
https://www.stoneaudio.co.uk/?product=cary+audio+slp%2D98+valve+pre+amplifier
https://hometheaterreview.com/cary-audio-slp-98l-preamplifier-reviewed/
Number of posts : 10073
Cary Audio SLP-98L Tube Preamplifier with External Power Supply Empty Re: Cary Audio SLP-98L Tube Preamplifier with External Power Supply
Post by raymond88 Wed Mar 11, 2020 5:36 pm
Post by raymond88 Wed Mar 18, 2020 9:52 pm
Post by raymond88 Sat Mar 28, 2020 12:45 am
Post by raymond88 Sun Apr 05, 2020 5:13 pm
Post by raymond88 Mon Apr 13, 2020 4:30 pm
Post by raymond88 Tue Apr 21, 2020 2:21 pm
Post by raymond88 Wed Apr 29, 2020 2:15 pm
