Halcro MC50 Multichannel Amplifier
This is a 240v unit . Selling for RM8200 Interested call Song 0123355330
P/s . Photos not posted correctly . If u need more photos , Sms me. In excellent condition except the rubberized bottom of footer
Features
Inputs, selectable
Outputs
Command Functions
Gain
Power Supply
Fault Indications
Distortion
Impedance
Input
Output impedance at 7kHz
Power
Consumption
Mains Voltage
Dimensions
Features
- Power Output: 350W RMS continuous into 4 Ohms
- Distortion THD: <0.007% at 1kHz at all powers up to 350W into 4 Ohms, <0.03% at 7kHz at all powers up to 350W
- Unbalanced and Balanced Voltage Inputs
- Thermally controlled forced air cooling
- Mains Voltage: 100 – 120VAC or 190 – 250VAC
- Remote trigger switch between On & Standby
- Command Functions:
- Switch between On & Standby
- Ability to inhibit individual amplifier modules
- Amplifier module will indicate Over Temperature condition
- Halcro Reliability Assurance Service Software
Inputs, selectable
- Unbalanced: RCA sockets
- Balanced: XLR sockets
Outputs
- Internally bridged: Binding Posts
Command Functions
- Amplifier module will indicate Over Current condition
Gain
- Unbalanced and balanced: 29x = 29dB
Power Supply
- Universal switch mode
- Power factor corrected
- Fully protected
- Compliant in all countries
Fault Indications
- LED turns red if Heatsink temperature exceeds 78°C
- LED flashes red if current limit exceeded
Distortion
- THD:<0.005% at 1kHz at all powers up to 350W into 4ohms
- 0.02% at 7kHz at all powers up to 350W (typically <0.01% at 350W)
- Noise: <30nV/sqrt(Hz) @ 1kHz referred to input
Impedance
Input
- Unbalanced: 10k Ohms
- Balanced: 10k Ohms
- <80 milliohms
Power
Consumption
- Idle: <14W
- 350W with 4 Ohm load: <22W heat (>94% efficient)
Mains Voltage
- 100-250 VAC
Dimensions
- Weight: 25.0 kg
- Height: 7 inches or 169mm
- Width: 17 inches or 438mm
- Depth: 16 inches or 410mm
Last edited by trailblazers_song on Wed May 03, 2023 7:07 am; edited 2 times in total (Reason for editing : Change price)
trailblazers_song- Regular
- Number of posts : 80
Registration date : 2009-09-21
» used halcro ssp 100
» Halcro DM 68 £5,900.00
» Classe CAV-75 Multichannel Amplifier - 6 channel (bridge-able)
» Sherbourn PT-7030 AV Processor & Sherbourn PA 7-150 Multichannel Power Amplifier ( 7channel x 150w ) ( sold )
» Anthem MCA 5 Multichannel Power Amplifier for sale(not for sale anymore)
