MS HD Power MS1080P V2 6 way Distribution Block with cable and UK plug (SOLD)
6 way distribution block
A 6 way switched distribution block with integral cable and UK plug for audio and A/V use – quality specifications and build at a sensible price.
A 6 ways switched distribution block that offers quality specifications at a sensible price. The design, build and component specifications that are offered in far higher priced multi-way distribution blocks for audio and A/V use.
Each part of this distribution block has been designed for audio and A/V use.
The 2m long integral mains cable is made from 3 Core 6N OFC wire and double screened. The mains plug has silver plated power pins and silver plated 13A fuse. The internal power ‘buss-bars’ are an impressive 5mm sq. for instant power transmission, the high spring rate phosphor bronze socket clips pass the BS Standard 30,000 times plug IN / OUT test and the high spring rate phosphor bronze fuse clips are silver plated.
This distribution block also comes with a high quality noise filtration network, effective EMI and RFI suppression, and anti-surge protection – to ensure your equipment is safe from mains spikes, and your audio sound quality is not impaired by noisy mains.
Specifications: MS HD Power MS-1080P V2
Number of outlets: 6Conforms to BS1363
Mains lead: 2m. Conforms to VDE standards
UK plug on lead – conform to BS1363; fused and un-switched
Fuse: 13A BS-1362 Silver Fuse fitted at plug
13A BS-1362 Silver Fuse fitted at distribution strip
Mains on/off Switch: Fitted on distribution strip
Mains Voltage: 200 – 240 VAC / 50~60Hz
Max. Current: 13 Amp.
Max. Wattage: 3,000 Watt (230V)
Dimensions: 60mm x 402mm x 30mm (W x L x H)
Net Weight: 0.8 KG (net)
Price : SOLD
Please contact us at 012-614 3049 (Ms Wee) for further details.
FB : [You must be registered and logged in to see this link.]
Last edited by aiyen on Mon Apr 25, 2022 11:17 am; edited 1 time in total (Reason for editing : Unit sold)
aiyen- Dealer\Reseller\Trader\Service Provider
- Number of posts : 1245
Registration date : 2010-08-24
» MS HD Power: MS Power S20 V2 Distribution Block with Cable and UK plug
» MS HD Power MS-1080P V2 6 way Distribution Block (UK Plug)
» WireWorld Matrix 2 6-Way Power Distribution Block and Stratus 7 Power (UK Plug)
» MS HD Power MS-POWER S20 V2 6 Ways Distribution Block (UK Plug)
