MS HD Power MS S20 V2 Silver 6 Ways UK Filter Sockets with Surge Protection (SOLD)
6 Way Distribution Block
A high specification 6 way distribution block with integral cable and UK plug – for audio and A/V use, with silver plated power conductors throughout.
A 6 ways switched distribution block with integral 2 Mtr. cable and plug that offers very high quality specifications. The design includs silver plated conductors throughout to offer quality mains power distribution for audio and A/V use.
Each part of this distribution block has been designed for audio and A/V use.
The 2m long integral mains cable is made from 3 Core 6N OFC wire and double screened. The mains plug has silver plated conductors and a silver plated 13A fuse. The internal power ‘buss-bars’ are an impressive silver plated 5mm sq. for instant power transmission, the high spring rate silver plated phosphor bronze socket clips pass the BS Standard 30,000 times plug IN / OUT test and the high spring rate phosphor bronze fuse clips are also silver plated.
This distribution block also comes with a high quality noise filtration network, effective EMI and RFI suppression, and anti-surge protection – to ensure your equipment is safe from mains spikes, and your audio sound quality is not impaired by noisy mains.
Specifications:
Number of outlets: 6
Conforms to BS1363
Mains lead: 2m. Conforms to VDE standards
UK plug, BS1363; fused and un-switched, with 3.0 µm Pure 925 Silver Plated Pins
Fuse: 13A BS-1362 Silver Fuse fitted at plug
13A BS-1362 Silver Fuse fitted at distribution strip
3.0 µm Pure 925 Silver Plating to All high spring rate phosphor bronze power clips
Mains Voltage: 200 – 240 VAC / 50~60Hz
Mains on/off Switch: Fitted on distribution strip
PRRT Noise Filtration Network using Selected Components
Excellent EMI and RFI Suppression to Improve Audio and Visual Performance
48,000 Amp. Surge Suppression Protect Hi Fi / AV Appliances
5 mm² Power Transmission Bus Bars with Pure Silver Plating for High Current Flow
Max. Current: 13 Amp.
Max. Wattage: 3,000 Watt (230V)
Dimensions: 60mm x 402mm x 30mm (W x L x H)
Net Weight: 0.8 KG (net)
Price : SOLD Conforms to BS1363
Please contact us at 012-614 3049 (Ms Wee) for further details.
FB : [You must be registered and logged in to see this link.]
Last edited by aiyen on Mon Apr 25, 2022 4:15 pm; edited 1 time in total (Reason for editing : Unit sold)
aiyen- Dealer\Reseller\Trader\Service Provider
- Number of posts : 1245
Registration date : 2010-08-24
» MS-POWER S20 V2 Silver 6 Ways UK Filter Sockets with Surge Protection-Ver.2 (New)
» MS HD POWER MS-E02S Silver 6-Ways UK Filter Sockets
» MS-1080P V2 6 Ways UK Filter Sockets with Surge Protection-Ver.2 (New)
