QED performance optical Graphite 1M Toslink
Brand: QED design & engineered in UK
Length: 1M
Like new 9.8/10
Come with Orginal box
Selling: RM275 nett only
** Benefit of Toslink Optical cable - No electrical noise, Ground noise with high performance cable at ultra low jitter... *jitter - 1 and 0 timing error, the lesser error the best sound quality
https://www.qed.co.uk/qed-performance-optical-digital-graphite-audio-cable.html
FEATURES AND BENEFITS
Polymethyl Methacrylate (PMMA) acrylic glass optical fibre
This new optical fibre boasts half the signal attenuation per metre of the previous Performance model, which means 'Performance Graphite' comfortably transmits the higher bandwidth signals for multi channel audio.
Very Low Jitter Design
At QED we have identified jitter or distortions caused by errors in the light transmission as a major factor in the deterioration of the audio signal. By incorporating precision cladding techniques jitter is reduced enabling a cleaner signal with better dynamics and a wider sound stage.
Very Low Loss
Very Low loss < 0.15dB attenuation per metre
Plastic Optical Fibre (POF) core of acrylic glass
Stepped refractive index
Fluorinated Polymer Cladding Material
24K gold plated Toslink connectors
Precision engineered plug with
integrated grip
Attenuation < 0.15dB/m (650nm)
Numerical Aperture 0.5
Minimum bend radius 9 mm
Contact via:
https://www.carousell.com.my/p/qed-performance-optical-graphite-1m-toslink-1041805251/
Length: 1M
Like new 9.8/10
Very Low Loss
integrated grip
Contact via:
jakecmy- New Member
- Number of posts : 6
» [WTS] QED Performance Toslink Digital Optical Audio Cable Graphite 3m (NEW)
» Wireworld Supernova 7 DiGital Optical Toslink-Toslink 1m (Used) SOLD
» Optical Toslink Cable by Maxcable
» DH Labs Toslink Optical Cable 1M (SOLD)
» QED-Performance-Optical Digital Graphite-1.0m-(New)
