Class A power amplifier (钟神音响)
+2
davidyu
Ao-Ao Yeh
6 posters
Class A
Solid Built
80W class A
Fully -Balanced Input (XLR)
输出功率 80W+80W(甲类,RMS,8Ω)
谐波失真 ≤0.06%(1kHz)
信噪比 ≥100dB(A)
频率响应 20Hz??20kHz(±0.5dB)
输入阻抗 100kΩ
Class A working status is another feature of this power amplifier . Transistor amplifiers often have a blunt sound, and the Class A working state is an effective way to eliminate the stiff feeling in the sounds. Some people think that the sound of a well-designed Class A transistor amplifier can be comparable to a tube amplifier as almost as close .
As we all known, the Class A amplifier has excellent linearity at low levels, and there is no switching "distortion"; since the transistor is always on, there is no crossover distortion. When the output power changes rapidly (for example, during a large dynamic symphony signal swing), the current phase shift of the power supply is almost zero, so the voltage regulation rate is excellent; because there is always a consistent current present in the circuit, it is very sensitive to sudden signals (such as piano, plucking) The instant rise and fall of music, percussion, etc.) can responded so quickly. This powerful driving capability enables the speaker to work properly and controlled . In this way, the inherent advantages of the Class A amplifier have the ability to shine , the sound is warm, sweet, and delicate. It is a model that senior-experienced enthusiasts are diligently seeking, and even considered the highest quality musics playback mechanism.
在元器件选用上,全平衡传输和甲类工作状态铸就了必选优质品,并且优中选优。比如前级配置两只电源变压器分别为两声道供电,动用8只各为15000μF共12万微法日本乐声电容滤波。后级专门设计了680W电源变压器,连同前级共用了日本乐声滤波电容15000μF×20=300000μF,这是在高级机中也少见的。每声道4对日本山肯管C4883、A1859推动管推动东芝4对功放管2SC5200、2SA1943
built like a tank sial!
Chi- Fi 钟神 (world class sounds at peanut price!) you wont know until you try bro
RM2699
Ao-Ao Yeh- Frequent Contributor
- Number of posts : 174
Registration date : 2012-11-09
Source(s): Marantz
Amplification: Cyrus 2
Speakers: Mission 753
Re: Class A power amplifier (钟神音响)
do you have any contact number ??
davidyu- Frequent Contributor
- Number of posts : 115
Registration date : 2013-09-25
No toroidal trans but at 300,000
μF it’s impressive. How do we get to listen to it? TQ
WillT- Frequent Contributor
- Number of posts : 261
Registration date : 2018-11-22
Source(s): Lumin U1 Mini & Matrix Audio X Sabre Pro
Amplification: Silbatone JI-107
Speakers: Graham Audio LS 8/1 and Rogers LS 3/5a Classic ... REL T7x
Hi,please check your inbox.thanks
chiewsc- New Member
Registration date : 2018-10-08
still have ? pls contact me if available 0193379357
rickyhow123- Frequent Contributor
- Number of posts : 118
Registration date : 2017-01-17
Ao-Ao Yeh wrote:PM me if still available
Class A
Solid Built
80W class A
谐波失真 ≤0.06%(1kHz)
信噪比 ≥100dB(A)
输入阻抗 100kΩ
RM2699
aoc- New Member
- Number of posts : 5
Registration date : 2009-11-03
Please PM if still available
aoc- New Member
Source(s): Marantz
» Plinius SA-50 Class A/ Class AB power amplifier (Used) SOLD
» DIY Class A Power Amplifier SOLD
» DIY Class A - Power Amplifier (Used)
» DIY Class-A Power Amplifier (Used)
» N.E.W DCA-33 class A power amplifier for sale.
