Yaqin SD-35A Valve Vacuum Tube Amplifier Hi-End HDCD CD Player
Yaqin SD-35A Valve Vacuum Tube Amplifier Hi-End HDCD CD Player Empty Yaqin SD-35A Valve Vacuum Tube Amplifier Hi-End HDCD CD Player
Post by yuenyan Tue Feb 23, 2021 1:00 pm
Yaqin SD-35A 6N8P Valve Vacuum Tube Amplifier Hi-End HDCD CD Player
Yaqin SD-35A Valve Vacuum Tube Amplifier Hi-End HDCD CD Player Cafb8814
Yaqin SD-35A Valve Vacuum Tube Amplifier Hi-End HDCD CD Player 41g1u914
Yaqin SD-35A Valve Vacuum Tube Amplifier Hi-End HDCD CD Player Yaqin-31
Features:
Servo circuit using the Philips SAA7824 chip.
Using the U.S. company PCM l732U BB and with HDCD decoder chip
with coaxial digital signal output terminal , external audio decoder.
Use CD dedicated Sanyo precision movement, good stability, its reading ability
Use the excellent stable multilayer filter circuit, effectively remove the digital signal to your hi-fi music signal output.
Using two low resistance to promote strong , gall 6N8P flavor and high-fidelity amplifier circuit OPA2604 op amp output ,Two groups are available.
The machine coupling circuit using fever- Philips nonpolar (MKP) capacitors and electrolytic dedicated audio enthusiast for filtering and blocking high-precision manufacturing gold .
Dedicated power transformer silicon steel imported audio (thickness 0.35mm) and high-strength oxygen-free copper wire and special winding process production, make the machine less electromagnetic interference , driving strong, transparent sound quality and powerful.
Specifications:
Audio output signal : 2.3V (± 0.5dB)
Frequency Response: 10Hz-30kHz(±0.5dB)
SNR : ≥ 110dB (A -weighted )
Distortion: ≤0.005%(1kHZ OPA)
Dynamic Range: 110db
Analog Output: One tube output and one OPA output
Digital Output: Coaxial a set
Tube: 6N8P×2
Power Consumption: 90W
Dimension(L*W*H): 375mm×205mm×345mm
Net Weight: 10kg
Gross weight: 13.6kg
Power input: 110/120v or 220/230v 50/60hz
18 months warranty
New in box
Price: RM3,699
yuenyan
Number of posts : 1404
Yaqin SD-35A Valve Vacuum Tube Amplifier Hi-End HDCD CD Player Empty Re: Yaqin SD-35A Valve Vacuum Tube Amplifier Hi-End HDCD CD Player
Post by yuenyan Fri Mar 12, 2021 4:41 pm
yuenyan
Post by yuenyan Sat Apr 10, 2021 2:25 pm
yuenyan
Post by yuenyan Sat Jun 19, 2021 10:49 am
yuenyan
Post by yuenyan Sat Sep 04, 2021 8:37 am
yuenyan
Post by yuenyan Sat Jan 08, 2022 8:51 am
yuenyan
Post by yuenyan Fri Apr 08, 2022 8:41 am
yuenyan
Post by yuenyan Sat Jun 18, 2022 8:38 am
yuenyan
Post by yuenyan Tue Aug 23, 2022 11:16 am
yuenyan
Post by yuenyan Mon Nov 14, 2022 8:46 am
yuenyan
Post by yuenyan Mon Feb 06, 2023 10:00 am
yuenyan
Post by yuenyan Thu Jul 20, 2023 9:24 am
yuenyan
