Yaqin MS845 Class A Hi-End Vacuum Valve Tube Pre-Amplifier
YAQIN MS845 12AX7 CLASS A HI-END VACUUM VALVE TUBE PRE-AMPLIFIER + FREE GIFT
Features:
1.Pre-amplifier drive circuit as “SRPP” circuit, and for the dual parallel, wide frequency response, pushing strong.2.Japan imported the audio output transformer using dedicated oriented silicon steel Z11 (0.35mm thick) and oxygen-free high strength enameled wire and special winding process multi-group production, so that the machine wide frequency response, to ensure that the machine high, medium and low frequency sounds good , transparent and powerful.
3.This machine adopts foreign name Factory sound dedicated enthusiast and non-polarized electrolytic (MKP) Need for high-quality imported French Suren gold blocking capacitors and manufacturing, the main audio channel dedicated to use imported from Japan (ALPS) volume motor potentiometer, with quiet background music, low noise, no sound pollution and durable.
4.High-voltage power supply for the automatic delay control, can effectively extend the tube life.
Specifications:
Output Power: 25W + 25W (8Ω)Distortion: ≤ 2.5% (1kHz)
Frequency response: 10Hz – 40kHz (-2dB)
SNR: ≥ 86dB (A)
Input Sensitivity: ≤ 0.2V
Load Impedance: 4Ω – 8Ω
Tubes: 12AX7 x2 12AU7 x1
Power supply voltage: 110/220V 60Hz/50Hz
Volume: 195mm x 275mm x 390mm (D x W x H)
Gross weight: 12kg
18 months warranty
New in box
Price: RM5,499
- Number of posts : 1404
» Yaqin SD-35A Valve Vacuum Tube Amplifier Hi-End HDCD CD Player
» Yaqin MS-6V6 Class A Vacuum Tube Integrated Headphone Amplifier
» YAQIN MC-13S Class A Vacuum Tube Push-Pull Hifi Integrated Amplifier
» Yaqin MS-20B Hi-End Vacuum Tube Amplifier
