Pioneer SPEC-3 + SPEC-4 (Pre Amp and Power Amp)
Pioneer C-73 (SPEC-3 Japan version)
Total harmonic distortion: 0.01%
Input sensitivity: 2.5mV (MM), 150mV (line)
Signal to noise ratio: 80dB (MM), 100dB (line)
Dimensions: 480 x 142 x 390mm
Weight: 7.7kg
Year: 1978
Pioneer M-75 (SPEC-4 Japan Version)
This provides a stable operation and also high gain over a wide frequency range.
The pre-driver stage is a class A circuit with a regulated current circuit for the load.
This makes for high gain amplification with superior linearity.
Furthermore, there is an overdrive limiter and power limiter circuit which is designed to protect the power transistors and make for added reliability.
Frequency response: 5Hz to 100kHz
Damping factor: 100
Input sensitivity: 1V
Signal to noise ratio: 115dB
Semiconductors: 2 x IC, 61 x transistors, 62 x diodes
Dimensions: 480 x 187 x 445mm
Weight: 24.5kg
Great condition, recently maintained.
Produce a fantastic sound.
COD KLCC
Price:RM6.3K
contact: Paul o!2 6o9 98!2
Frequency response: 10Hz to 100kHzTotal harmonic distortion: 0.01%
Weight: 7.7kg
Year: 1978
Description
The Spec-4 employs DC construction which excludes capacitors from the NFB circuits and uses a dual transistor differential amplifier with a current mirror circuit in the 1st stage.This provides a stable operation and also high gain over a wide frequency range.
Power output: 150 watts per channel into 8Ω (stereo)Frequency response: 5Hz to 100kHz
Damping factor: 100
Weight: 24.5kg
COD KLCC
Price:RM6.3K
esteboune- Club Member
- Number of posts : 27
Registration date : 2011-04-10
Re: Pioneer SPEC-3 + SPEC-4 (Pre Amp and Power Amp)
Still available!
» Pioneer Power AMP Spec-2
» Pioneer SPEC 1 & 4 pre n power
» Pioneer SPEC-4 power amp (Used)SOLD
» PIONEER SPEC SG-9800 12 Band Graphic Equalizer Silver Face TOTL
» Pionner spec 4 power amplifier (Used)SOLD
