LVX12 Direct Servo Subwoofer 12″ multi-tuned ported audiophile sub
Description:
LFE meets accuracy and control
LVX12 multi-tuned ported servo subwoofer is the little brother of our FV15HP/FVX15 subwoofers. It is our answer to the need for a “bang for buck” home theatre solution that retains the dynamic and accurate bass that FV15HP/FVX15 become known for. Correctly integrated, our vented subwoofers can achieve the tight bass normally associated with a sealed enclosure, yet with greater low frequency output. We recommend this subwoofer for systems in which home theatre has a high priority. LVX12 also features multi-tune capability. Customers can select either one-port or two-port operation.
Direct Servo Technology
All our subwoofers use our patented Direct Servo technology. The servo enables precise control over the cone which is essential for tight, dynamic and accurate bass. It also counteracts many different driver non-linearities and allows us to use lighter drivers which avoid the need for excessive amounts of amplifier power.
Some of the benefits of Direct Servo include:
- Reduction of the effects of thermal compression are eliminated under normal operation
- Higher efficiency allowing output which would normally require a more powerful amplifier
- Deep bass extension can be achieved using a low mass driver with superior transient response
- Mechanical and thermal memory effects are reduced, further improving transient response
- The effective Q value is 0.1 resulting in much tighter and accurate bass than conventional designs
- Dramatic reduction of the re-radiation of bass from inside the box
New in box
Price: RM6,800
- Number of posts : 1404
» FVX15 Direct Servo Subwoofer 15″ ported audiophile sub
» Rythmik FV15HP Direct Servo subwoofer 15″ ported audiophile subwoofer
» Rythmik F12 Direct Servo subwoofer 12″ sealed audiophile subwoofer
» Rythmik F12G PEQ 12" Sealed Audiophile Direct Servo Subwoofer
» Rythmik G22 Dual opposed 12″ sealed audiophile Direct Servo subwoofer
