FVX15 Direct Servo Subwoofer 15″ ported audiophile sub
FVX15 Direct Servo Subwoofer 15″ ported audiophile sub Empty FVX15 Direct Servo Subwoofer 15″ ported audiophile sub
Post by yuenyan Thu Mar 11, 2021 4:46 pm
FVX15 Direct Servo Subwoofer 15″ ported audiophile sub with one-band PEQ
FVX15 Direct Servo Subwoofer 15″ ported audiophile sub Fvx15_11
FVX15 Direct Servo Subwoofer 15″ ported audiophile sub Fvx15_10
Description
LFE meets accuracy and control
FVX15, a lower power version of the our well regarded FV15HP, is our answer to the need for a “bang for buck” home theatre solution that retains the dynamic and accurate bass that we have become known for. Correctly integrated, our vented subwoofers can achieve the tight bass normally associated with a sealed enclosure, yet with greater low frequency output. We recommend this subwoofer for systems in which home theatre has a high priority. FVX15 also features multi-tune capability. Customers can select either one-port or two-port operation.
Direct Servo Technology
All our subwoofers use our patented Direct Servo technology. The servo enables precise control over the cone which is essential for tight, dynamic and accurate bass. It also counteracts many different driver non-linearities and allows us to use lighter drivers which avoid the need for excessive amounts of amplifier power.
Some of the benefits of Direct Servo include:
  • Reduction of the effects of thermal compression are eliminated under normal operation
  • Higher efficiency allowing output which would normally require a more powerful amplifier
  • Deep bass extension can be achieved using a low mass driver with superior transient response
  • Mechanical and thermal memory effects are reduced, further improving transient response
  • The effective Q value is 0.1 resulting in much tighter and accurate bass than conventional designs
  • Dramatic reduction of the re-radiation of bass from inside the box
FVX15 Direct Servo Subwoofer 15″ ported audiophile sub Screen70
FVX15 Direct Servo Subwoofer 15″ ported audiophile sub Screen69
FVX15 Direct Servo Subwoofer 15″ ported audiophile sub Screen68
FVX15 Direct Servo Subwoofer 15″ ported audiophile sub Screen72
FVX15 Direct Servo Subwoofer 15″ ported audiophile sub Screen71
FVX15 Direct Servo Subwoofer 15″ ported audiophile sub Screen73
FVX15 Direct Servo Subwoofer 15″ ported audiophile sub Screen74
New in box
Price: RM8,800
yuenyan
Number of posts : 1404
FVX15 Direct Servo Subwoofer 15″ ported audiophile sub Empty Re: FVX15 Direct Servo Subwoofer 15″ ported audiophile sub
Post by yuenyan Mon Mar 29, 2021 11:35 am
yuenyan
Post by yuenyan Tue May 25, 2021 10:17 am
yuenyan
Post by yuenyan Tue Mar 08, 2022 9:43 am
yuenyan
Post by yuenyan Wed May 18, 2022 8:51 am
yuenyan
Post by yuenyan Sat Jul 23, 2022 9:14 am
yuenyan
Post by yuenyan Thu Sep 29, 2022 10:30 am
yuenyan
Post by yuenyan Fri Dec 30, 2022 9:37 am
yuenyan
Post by yuenyan Thu Apr 27, 2023 8:46 am
UP
yuenyan
