SOLDThe Gryphon Tabu Dual Mono Integrated Amplifier
Item: The Gryphon Tabu Dual Mono Integrated Amplifier
Condition: 8.5/10. Item is in like new condition. No dents or scratches. Comes with original remote control.
Price: SOLD or swap/topup
Click here to Whatsapp:
http://wasap.my/60123816611
Features:
- True Dual Mono configuration
- Fully discrete construction
- Zero negative feedback
- Full remote controlled operation
- Motor-driven analog ALPS volume control
- Custom massive dual C core Transformers
- Military spec. double-sided circuit boards
- Balanced inputs with gold-plated Swiss Neutric XLR socket
- Single-ended inputs with gold-plated WBT rca socket
- Extensive mechanical decoupling
- Minimal internal wiring
- Ultra-short signal path
- Frequency-independent damping factor
- Non-invasive protection system
- Separate power supply for all non audio circuits
- Designed and built in Denmark
Technical specification:
- 2x 100W in 8 ohm
- 2x 200W in 4 ohm
- 2x 300W in 2 ohm
- Gain 38,2 dB
- Sensitivity: 350mV
- THD: 0,07% at 100W
- Output impedance: 0,07 ohm
- Max. voltage: 50V
- Max current: 20A
- Power consumption in idle: 110W
- Max. power consumption: 1100W
- Dimensions: H 160mm, W 480mm, D 490mm
- Weight: 25kg
- List price: $11,000
http://www.audioreview.com/product/amplification/integrated-amplifiers/gryphon-audio/tabu-integrated-amp.html
https://audiosolutions.net.au/product/gryphon-tabu-2-onehundred-stereo-power-amplifier-trade-in/
Features:
- 2x 100W in 8 ohm
- 2x 200W in 4 ohm
- 2x 300W in 2 ohm
- Gain 38,2 dB
- Max. voltage: 50V
- Max current: 20A
- Weight: 25kg
» Gryphon dual mono integrated amplifier (used) SOLD
» USED Gryphon Diablo 250 Dual Mono Integrated Amplifier
» Gryphon Bel Canto Dual Mono Preamp & Gryphon DM100 Dual Mono Class A Power Amp (Used) SOLD
» Gryphon the tabu A.T integrated amplifier (Used)SOLD
» Gryphon Bel Canto dual mono pre amp & DM100 power amplifier SOLD
