Cayin A-300B MKll Class A single-end tube Integrated Amplifier (Used)
FEATURES
- Hand matched electronic tubes
- Hand-made at Cayin's dedicated engineering facility.
- Point-to-point wiring, hand-made with the highest purity silver solder.
- Two extremely high quality wide frequency response EI output transformers .
- Uses a bespoke toroidal power transformer specially developed for this amplifier - hand wound.
- High voltage rectification using two Russian SOVTEK 5AR4 vacuum tubes
- Voltage amplification stage uses hand matched 6SL7 x 2pcs
- Hand matched 6SN7 x 2pcs are used for the driver stage.
- Power amplification stage uses FULL MUSIC 300B x 2pcs vacuum tubes as single-ended pure Class A power amplification.
- External 300B Hum BALANCE function, a fantastic feature to fully allow you to 'dial in' your perfect set-up.
- External independent BIAS ADJ. to adjust the bias and a beautiful BIAS meter for easy and simple adjustment of the power valves.
- Negative Feedback adjustment to 0 or -3db gives further control of the tonal character.
- Infrared full-function remote control.
TECHNICAL DATA
Frequency range | 10 Hz - 32 kHz (-3 dB) |
Total harmonic distortion (THD) | 1% (1kHz) |
Signal to noise ratio | 86 dB |
Input impedance | 100 kΩ |
Tubes | 6SL7×2, 6SN7×2, 5AR4×2, FULL MUSIC 300B |
Output power (RMS) | 10 watts + 10 watts |
Circuit | Class A, Single Ended |
Dimensions W x H x D | 420mm × 382mm × 195mm (W × D × H) |
Weight | 26kg |
Conditions: 9/10 (USED)
Price: RM5800 inclusive postage to West Malaysia
- Number of posts : 5622
» Willsenton R800i 300B 805 Tube Single-Ended Class A Integrated - Sold
» Cayin HA-300B Direct Heated Triode Vacuum Tube Amplifier
» MONA A1 Class A KT120 Tube Single-Ended Integrated Amplifier With Bluetooth 5.0
» Audiovega MC300A Single Ended 300B Tube Amplifier (Used) SOLD
» BEWITCH NO 300B CLASS A TUBE intergrated amplifier (used)
