Roger Modjeski's Music Reference RM-5 MK IV Tube Preamplifier with Phono
Item: Roger Modjeski's Music Reference RM-5 MK IV Tube Preamplifier with Phono
Condition: 8.0/10. Item is in excellent working condition. No dents or scratches. Using 3 pcs RAM 6922 tubes (Sovteks).
Price: SOLD or swap/topup
Music Reference RM-5 MK IV Preamplifier Music Reference developed the RM-5 preamplifier based on sound engineering principles following years of research. Our challenge was this: How to provide excellent sonic performance at a price that represents a great value to the audiophile. The electrical sections of the RM-5 are the phono RIAA equalizer, phono amplifier, and the line amplifier. Each active stage was designed with a power supply, which exceeds its requirements, by a factor of ten. Thus, each stage is ultimately over-load proof and stable under dynamic and line voltage extremes. The result: an accurate sound stage with precise focus on individual instruments. The RM-5 is built to standards well beyond its price. All controls are custom-made and are plated for long life and low noise. All chassis components are mil spec anodized. Circuit boards are mil spec also. The RM-5 front panel lettering is made by a process, which guarantees long life. Unlike most panels in which lettering is silk-screened onto an anodized or painted panel, our Anofax process puts the lettering into the aluminum with a two-color process. Therefore, it can never wear off. Your preamp will look like new forever. Our one-board construction, with minimum point-to-point wiring, provides extremely high reliability. Control functions are logically placed to facilitate easy connection and operation. Logic circuitry is incorporated to drive the automatic and manual muting, assuring freedom from switching noises, line voltage drops, and preamplifier power-up. The rugged electrical and mechanical design assure years of trouble-free use. And the fine sound delivered by the RM-5 will never become obsolete. RM-5 MK.IV Specifications Maximum Output Voltage: 40 Volts Line amp; 40 Volt phono amp into 50k ohm load. Dynamic Range: Line: 120dB; Phono: 120dB Gain: 36dB @ 1kHz (Phono). Bandwidth (-3dB frequencies): 0.72Hz & 60Hz (Phono); 0.17Hz & 350 kHz at 14dB gain; 0.7Hz & 90Khz at 28dB (Line). Inputs: Gold plated Tiffany RCA connectors Input Impedance: 47k ohms in parallel with 30pF (Phono); 25k ohms (Line). Phono RIAA deviation: +0/-0.2dB, 10Hz-20kHz. Output Impedance: 800 ohms at 14dB. Phono Acceptance Level: 600mV at 1kHz. Dimensions: 19" x 3.5" x 8.25" Tube Complement: 1 6922 (Line); 2 6922 (Phono). Net Weight: 16 Pounds Designer: Roger A. Modjeski Price: $1950.00
https://www.audiogon.com/listings/music-reference-rm-5-mk-iv-mark-4-low-noise-vacuum-t
All my other items for sale:
CD Player:
Marantz CD-17Ki CD Player
Marantz SA-11s2 CD Player
Bluesound Node 2i (New)
DAC:
Topping D50s USB DAC @ RM750
Audio Research DAC9 Tube DAC @ RM27k
Audiolab Q-DAC Digital To Analogue Converter @ RM1100
Cambridge Audio DACMagic Upsampling DAC @ RM750
Phono Stage:
Pathos Acoustics In The Groove Mk2 MM/MC Phono Stage @ RM3300
Rega Aria Switchable MM/MC Turntable Phono Stage @ RM3300
AV Processors/Receiver:
Denon AVC-X8500H Receiver @ RM15,900
Pioneer LX-88 Receiver @ RM3650
Emotiva XPA-5 5-Channels Power Amplifier
Pre Amplifier:
Conrad Johnson PV-12 Pre Amplifier @ RM4500
Herron Audio VTSP-1 Tube Preamp @ RM7500
Bryston BP17 Preamplifier @ RM7800
Melos SHA-1 Tube Preamp/ Headphone Amplifier @ RM2200
Musical Fidelity M1 CLiC Universal Music Controller / Network Player /Streamer/ Pre-Amplifier @ RM3100
Conrad Johnson Premier 16LS
Spec RSA - M3 EX
Music Reference RM-5 Mk4 Tube Preamplfier @ RM4500
Power Amplifier:
Music Reference RM-10 Power Amplifier @ RM7800
Rogue Audio Magnum M-120 Monoblock Power Amplifier @ RM8500
ATI AT1502 2-Channel Power Amplifier @ RM2300
Naim NAP-155xs Power Amplifier @ RM4200
Naim NAPSC Power Supply @ RM1500
Conrad Johnson Premier 140 Tube Power Amplifier @ RM15,500
Integrated Amplifier:
Devialet D200 Integrated Amplifier
MONA A1 Class A KT120 Tube Single-Ended Integrated Amplifier With Bluetooth 5.0 @ RM2,100
Teac AX-501 Integrated Amplifier (Black) @ RM2500
Wharfedale 10.CM Center Speaker @ RM1000
Sonus Faber Olympica III Floorstanding Speaker @ RM30k
Thiel CS3.6 Floorstanding Speakers @ RM7500
Rogers LS66 Bookshelf Speakers @ RM1500
Dynaudio Contour S5.4 Floorstand Speakers
Odeon Audio Orfeo Bookshelf Speakers
Spendor Classic 200 Speakers
PSB Imagine X2T Tower Loudspeakers @ RM5500
Dynaudio Audience 72 SE Floor Standing Speakers @ RM3300
Speaker Stand:
Guizu Solid Teak Wood Speaker Stand with Cast-iron Base and Spikes @ RM1000
Custom-made 6-Columns Audiophile Bookshelf Speakers Stands @ RM1600
Speaker Cables:
XLO Ultra 12 Bi-wire Speaker Cable - 6 feet pair @ RM1500
Xindak FS-1 Speaker Cable - 2.5m @ RM1200
Subwoofers:
JL Audio Dominion D-110 10"Inch Powered Subwoofer - 750W (Black Ash) (NEW) @ RM5500
MBWS Audio MS-12 USA Subwoofer @ RM4999
Orisun USA SUB-1230 Active Sub 12" @ RM1999
Interconnects:
Stage III Concepts Baron AG Pure Silver RCA Interconnect - 1.5m @ RM2300
Van Den Hul The Second XLR Interconnect - 0.8m @ RM730
Kimber Kable Illuminati Orchid AES/EBU Digital Cable - 1.5m @ RM1850
FURUTECH FireBird-96 ( 9pin-6pin ) IEEE1394 Fire Wire Cable 0.6m @ RM450
Power Cables:
Tice Power Cord Model "Power Conductor 2"- 2.5m @ RM1500
Furutech NanoFlux Power Cord - 1.8m @ RM8500
Power Conditioner:
Shunyata Hydra 6 Power Conditioner
Others:
JL Audio JLINK TRX: Wireless, High-Fidelity Audio Transmitter & Receiver Kit @ RM1290
Solid Tech Feet Of Silence (Set of 4) NEW @ RM1500
Entreq Cleanus Ground Box (Made In Sweden) @ RM3600
Subwoofer Base Vibration Isolation Platform @ RM800
Graham Slee - Solo Ultra-Linear Headphone Amplifier + PSU1 Power Supply @ RM1800
CAN VIEW THE DETAILS HERE:
CD Player:
DAC:
Phono Stage:
Pre Amplifier:
Spec RSA - M3 EX
Power Amplifier:
Speaker Stand:
Speaker Cables:
Subwoofers:
Interconnects:
Power Cables:
Power Conditioner:
Others:
» Roger Modjeski's Music Reference RM-5 MK IV Tube Preamplifier with Phono
» Music Reference RM-5 MK IV Tube Preamplifier with Phono & Music Reference RM-10 Stereo Tube Power Amplifier
» Music Reference RM-5 MK IV Tube Preamplifier with Phono AND RM-10 Stereo Tube Power Amplifier
