Music Reference RM-5 MK IV Tube Preamplifier with Phono
Item: Roger Modjeski's Music Reference RM-5 MK IV Tube Preamplifier with Phono
Condition: 8.0/10. Item is in excellent working condition. No dents or scratches. Using 3 pcs RAM 6922 tubes (Sovteks).
Price:RM4300 RM3900 or swap/topup
Music Reference RM-5 MK IV Preamplifier Music Reference developed the RM-5 preamplifier based on sound engineering principles following years of research. Our challenge was this: How to provide excellent sonic performance at a price that represents a great value to the audiophile. The electrical sections of the RM-5 are the phono RIAA equalizer, phono amplifier, and the line amplifier. Each active stage was designed with a power supply, which exceeds its requirements, by a factor of ten. Thus, each stage is ultimately over-load proof and stable under dynamic and line voltage extremes. The result: an accurate sound stage with precise focus on individual instruments. The RM-5 is built to standards well beyond its price. All controls are custom-made and are plated for long life and low noise. All chassis components are mil spec anodized. Circuit boards are mil spec also. The RM-5 front panel lettering is made by a process, which guarantees long life. Unlike most panels in which lettering is silk-screened onto an anodized or painted panel, our Anofax process puts the lettering into the aluminum with a two-color process. Therefore, it can never wear off. Your preamp will look like new forever. Our one-board construction, with minimum point-to-point wiring, provides extremely high reliability. Control functions are logically placed to facilitate easy connection and operation. Logic circuitry is incorporated to drive the automatic and manual muting, assuring freedom from switching noises, line voltage drops, and preamplifier power-up. The rugged electrical and mechanical design assure years of trouble-free use. And the fine sound delivered by the RM-5 will never become obsolete. RM-5 MK.IV Specifications Maximum Output Voltage: 40 Volts Line amp; 40 Volt phono amp into 50k ohm load. Dynamic Range: Line: 120dB; Phono: 120dB Gain: 36dB @ 1kHz (Phono). Bandwidth (-3dB frequencies): 0.72Hz & 60Hz (Phono); 0.17Hz & 350 kHz at 14dB gain; 0.7Hz & 90Khz at 28dB (Line). Inputs: Gold plated Tiffany RCA connectors Input Impedance: 47k ohms in parallel with 30pF (Phono); 25k ohms (Line). Phono RIAA deviation: +0/-0.2dB, 10Hz-20kHz. Output Impedance: 800 ohms at 14dB. Phono Acceptance Level: 600mV at 1kHz. Dimensions: 19" x 3.5" x 8.25" Tube Complement: 1 6922 (Line); 2 6922 (Phono). Net Weight: 16 Pounds Designer: Roger A. Modjeski Price: $1950.00
https://www.audiogon.com/listings/music-reference-rm-5-mk-iv-mark-4-low-noise-vacuum-t
All my other items for sale:
CD Player/Streamer:
Bluesound NODE 2021 Wireless Multi-Room Hi-Res Music Streamer @ RM2699
DAC:
Antelope Audio Zodiac+ HD Mastering 192 kHz D/A Converter/ Pre-amp @ RM4600
Lampizator Big 7 5th Gen DSD DAC @ RM28k
TOPPING E30 USB DAC @ RM450
Cambridge Audio DacMagic @ RM850
Phono Stage:
AV Processors/Receiver:
Denon AVC-X8500H Receiver @ RM15,900
Pioneer LX-88 Receiver @ RM3650
Pre Amplifier:
Herron Audio VTSP-1 Tube Preamp @ RM6900
Bryston BP17 Preamplifier @ RM7800
Melos SHA-1 Tube Preamp/ Headphone Amplifier @ RM2200
Music Reference RM-5 Mk4 Tube Preamplfier @ RM4000
Jeff Rowland Capri S1 Preamplifier w Phono @ RM6300
Power Amplifier:
Music Reference RM-10 Power Amplifier @ RM7800
Rogue Audio Magnum M-120 Monoblock Power Amplifier @ RM8500
Naim NAP-155xs Power Amplifier @ RM4200
Naim NAPSC Power Supply @ RM1500
Sanders Magtech Stereo Power Amplifier @ RM12,800
XTZ Edge A2-300 Power Amplifier @ RM2300
Integrated Amplifier:
Devialet D200 Integrated Amplifier @ RM20k
MONA A1 Class A KT120 Tube Single-Ended Integrated Amplifier With Bluetooth 5.0 @ RM2,100
SPEC Corporation RSA-M3EX Integrated Amplifier @ RM29k
Thiel CS3.6 Floorstanding Speakers @ RM7500
Rogers LS66 Bookshelf Speakers @ RM1500
Dynaudio Contour S5.4 Floorstand Speakers
Odeon Audio Orfeo Bookshelf Speakers @ RM7500
PSB Imagine X2T Tower Loudspeakers @ RM5500
Sonus Faber Venere Center Speaker @ RM2,200
Speaker Stand:
Guizu Solid Teak Wood Speaker Stand with Cast-iron Base and Spikes @ RM1000
Custom-made 6-Columns Audiophile Bookshelf Speakers Stands @ RM1600
Speaker Cables:
ASI Liveline Speaker Cables - 3.4m @ RM
XLO Ultra 12 Bi-wire Speaker Cable - 6 feet pair @ RM1500
Xindak FS-1 Speaker Cable - 2.5m @ RM1200
XLO Ultra 6 Speaker Cables - 6 feet pair @ RM900
Taralabs The One
Subwoofers:
JL Audio Dominion D-110 10"Inch Powered Subwoofer - 750W (Black Ash) (NEW) @ RM5500
JBL
Interconnects:
FURUTECH FireBird-96 ( 9pin-6pin ) IEEE1394 Fire Wire Cable 0.6m @ RM450
Cardas Audio Lightning 15 75 ohm SPDIF Coaxial Digital Cable - 1.5m @ RM1350
Transparent Audio
Taralabs The One
Audioquest Diamondback RCA Interconnect - 1m @ RM380
Shunyata Research Cobra XLR Interconnect - 1.5m @ RM3300
Cardas Cross XLR Interconnect - 1m @ RM680
NBS Professional IV Digital AES/EBU Cable - 1m @ RM3800
Black Rhodium Twist RCA Interconnect - 1.5m @ RM250
Power Cables:
Tice Power Cord Model "Power Conductor 2"- 2.5m @ RM1500
Furutech NanoFlux Power Cord - 1.8m @ RM8500
Vitus Andromeda Power Cord - 1.5m @ RM3600
ASI Liveline Power Cable - 1.8m @ RM2700
Shunyata Research Diamondback Platinum Power Cable - 20A @ RM690
Shunyata Research Etron Cobra Power Cable - 20A @ RM2200
Aural Symphonics 20A Missing Link Cubed Power Cable @ RM1900
Power Conditioner:
Torus IS Toroidal Isolation Power Transformers @ RM8300
Others:
JL Audio JLINK TRX: Wireless, High-Fidelity Audio Transmitter & Receiver Kit @ RM1290
Solid Tech Feet Of Silence (Set of 4) NEW @ RM1500
Subwoofer Base Vibration Isolation Platform @ RM690
Graham Slee - Solo Ultra-Linear Headphone Amplifier + PSU1 Power Supply @ RM1800
CAN VIEW THE DETAILS HERE:
Price:
CD Player/Streamer:
DAC:
Phono Stage:
Pre Amplifier:
Power Amplifier:
Speaker Stand:
Speaker Cables:
Taralabs The One
Subwoofers:
JBL
Interconnects:
Transparent Audio
Taralabs The One
Power Cables:
Power Conditioner:
Others:
» Music Reference RM-5 MK IV Tube Preamplifier with Phono & Music Reference RM-10 Stereo Tube Power Amplifier
» Music Reference RM-5 MK IV Tube Preamplifier with Phono AND RM-10 Stereo Tube Power Amplifier
» Roger Modjeski's Music Reference RM-5 MK IV Tube Preamplifier with Phono
