Yaqin SD-38A Vacumm Tube CD Player
Stock AvailableToday Order,We Can Ship Out NOW
Product features:
Bile rectifier tube machine
High quality spray tin double-sided 2A copper epoxy fiberboard. The specifications and tightness of the circuit can effectively reduce distortion, improve the signal-to-noise ratio, and achieve high fidelity. Inductive chokes are used for inductive LC filtering to make the sound quality purer and quieter
The high and low voltage transformers are powered independently to reduce the interference of the high and low voltage transformers.
Product parameters:
Audio output level: balanced 4V (+0.5dB) / single-ended 2V (+0.5dB)
Frequency response: 10Hz-35kHz (+0.5dB)
Total harmonic distortion: ≤0.005%
Signal to noise ratio: ≥110dB(A)
Dynamic range: 117dB
Analog output:balanced one group,unbalanced two groups
Digital output:one set of coaxial
Electronic tube:signal amplification: Russia 6H8CX 2/rectifier tube 6Z4X2
Net weight: 24kg
Gross weight: 25 kg
Size: length 375 × width 345 × height 240mm
↓Selling Price↓
Yaqin SD-38A - RM4,999
Interested Please Whatapps Me:
Vendor Sim +6012-5575648
Whatsapp : https://wa.link/d5plao
Vendor Sim- Regular
- Number of posts : 68
Registration date : 2021-06-23
Vendor Sim- Regular
» Yaqin SD-38A Vacumm Tube CD player
» Yaqin SD-38A Vacumm Tube CD player (Used) SOLD
» Yaqin SD-33A Hi-Fi Vacuum Tube CD Player (New)
» Yaqin SD-35A Valve Vacuum Tube Amplifier Hi-End HDCD CD Player
» YAQIN SD-CD3 6N8P Tube Signal Upgrade Hi-End Buffer Processor for CD Player
