SPEC Corporation RSA-M3EX Integrated Amplifier
SPEC Corporation RSA-M3EX Integrated Amplifier Empty SPEC Corporation RSA-M3EX Integrated Amplifier
Post by raymond88 Fri Sep 03, 2021 12:46 pm
Item: SPEC Corporation RSA-M3EX Integrated Amplifier
Condition: 9/10. Item is in LIKE NEW condition. No dents or scratches. Comes with original box and packaging. This unit comes with the optional remote control which is a very dear €900 option
Excerpt:
The superb tone color and rich timbral textures that are normally the purview of fine vacuum tube designs are now present is this class-D amplifier from Mr. Shirokazu Yazaki. If you're interested in an amplifier with the beauty, tone color, timbral naturalness, and rich stereoscopic musicality of the best vacuum tube designs in a non-fussy and classy solid-state design, I suggest that you listen to the SPEC RSA-M3 EX amplifier. You may very well decide it is one of the best amplifiers out there regardless of price. At least that's my take on the SPEC, and I suspect it'll be yours too if you get a chance to give it a listen.
Retail Price: RM45,000.00
Price: RM26k RM24k or swap/topup
Can Trade-In your Amplifier/CD player/Speakers/Etc
SPEC Corporation RSA-M3EX Integrated Amplifier Spec110
Review:
"It really wears its tube lover's heart on the sleeve" - 6 Moons
Read the entire 6 Moons review here
" If you’re interested in an amplifier with the beauty, tone color, timbral naturalness, and rich stereoscopic musicality of the best vacuum tube designs in a non-fussy and classy solid-state design, I suggest that you listen to the SPEC RSA-M3 EX amplifier." - Jeff's Place
"...the sweet and rich tonal character in the mid to high ranges of the amplifier is almost like the tone of the best triode tube amplifiers"
SPEC Corporation RSA-M3EX Integrated Amplifier Spec210
RSA-M3EX
Maximum output: 120 W × 2 (4O), 90 W × 2 (6O),
60 W × 2 (8O)
Frequency response: 10 Hz - 30 kHz ±1dB (6O, 1W)
Harmonic distortion ratio: 0.02% (at 1 kHz, 80% output)
Input sensitivity, gain: 300 mVrms, 37.3 dB (at MAX volume, 6O, 1kHz, unbalanced input)
Line input terminals: XLR input: 1 RCA inputs: 3
Speaker terminal: One
Power voltage: 220 V AC, 50 Hz
Electrical consumption With no signal: 15 W, during maximum output: 215 W (8 O, 100 Hz)
External dimensions: 440 mm (width) × 125 mm(height)
× 414 mm (depth)
Weight: 15.5kg
SPEC Corporation RSA-M3EX Integrated Amplifier Spec1010
SPEC Corporation RSA-M3EX Integrated Amplifier Spec310
SPEC Corporation RSA-M3EX Integrated Amplifier Spec410
SPEC Corporation RSA-M3EX Integrated Amplifier Spec510
SPEC Corporation RSA-M3EX Integrated Amplifier Spec710
SPEC Corporation RSA-M3EX Integrated Amplifier Spec810
https://positive-feedback.com/Issue78/spec_realsound.htm
https://www.6moons.com/audioreviews/spec3/1.html
https://recordclean.com.au/spec-rsa-m3ex-integrated-amplifier.html
https://www.soundstageaustralia.com/index.php/reviews/83-spec-corporation-rsa-m3ex-integrated-amplifier
https://www.soundgallery.com.au/product-page/spec-rsa-m3ex-real-sound-amplifier
https://www.the-ear.net/review-hardware/spec-rsa-m3ex-integrated-amplifier
Number of posts : 10041
SPEC Corporation RSA-M3EX Integrated Amplifier Empty Re: SPEC Corporation RSA-M3EX Integrated Amplifier
Post by raymond88 Fri Sep 10, 2021 2:04 pm
Post by raymond88 Fri Sep 17, 2021 6:19 pm
Post by raymond88 Fri Sep 24, 2021 2:17 pm
