Rega io + KEF Q350 Hi-Fi System Package
Rega io + KEF Q350 Hi-Fi System Package Brand New. Now Selling At RM5,399. Free Shipping Within West Malaysia.
Rega io
Technical Specification
Power outputs at 230/115 V supply voltage
30 W RMS both channels driven into the rated load of 8 Ω
Input 1 (Phono) input sensitivity 2.1 mV @ 47 kΩ in parallel with 220 pF
Maximum input 1 (Phono) input level 100 mV
Input 2-3 (Line) input sensitivity 210 mV @ 47 kΩ
Maximum input 2-3 (Line) input level 10.25 V
Headphone output
No load 8 V
32 Ω 1.6 V
54 Ω 2.4 V
300 Ω 5.7 V
Source impedance: 109 Ω
Power consumption
135 W @ 230 V / 220 V / 115 V / 100 V into the rated load of 8 Ω
Frequency response
Phono: 15 Hz to 40 kHz (-3 dB points) / 27 Hz to 20.5 kHz (-1 dB points)
RIAA accuracy: (100Hz to 10 kHz) ±0.4 dB typically better than ±0.3 dB
Line: 12 Hz (-1 dB points) to 43 kHz (-3 dB points)
Remote control
Batteries included –2 x AAA Alkaline.
Fuse ratings
T1.6 AL 250 V: 230 V / 50Hz and 220 V / 60 Hz
T3.15 AL 250 V: 115 V / 60 Hz and 100 V / 50/60 Hz
Weight
2.9Kg
Dimensions (W x D x H) in mm
180 x 290 x 68
MODEL Q350
DESIGN Two-way bass reflex
DRIVE UNITS 165mm (6.5in.) aluminium Uni-Q
25mm (1in.)vented aluminium dome HF
FREQUENCY RANGE FREE FIELD 42Hz (-6dB)
FREQUENCY RESPONSE 63Hz-28kHz (±3dB)
CROSSOVER FREQUENCIES 2.5kHz
MAXIMUM OUTPUT 110dB
AMPLIFIER REQUIREMENTS 15-120W
SENSITIVITY 87dB (2.83V/1m)
NOMINAL IMPEDANCE 8 Ohms (min.3.7 Ohms)
DIMENSIONS H x W x D:
358 x 210 x 306 mm
362 x 210 x 306 mm (with Rubber Feet)
WEIGHT 7.6kg(16.8lbs)
UNIT MEASUREMENT Pair
Rega io
The io has been designed to offer exceptional Rega performance at an affordable price point. It uses the same amplifier stage as the multi-award winning Brio now designed to run at 30 W per channel into 8 Ω. The io features two line level inputs, a high specification Rega moving magnet phono stage, and a dedicated high quality headphone output. The io will integrate seamlessly into any home audio system whilst remaining simple to use and easy to set up. A must for demonstration.KEY FEATURES
- Integrated phono stage
- Headphone socket
- Mini remote control
- All new custom designed chasis
Because music matters
The io uses the same power amplifier and phono stage as its larger brother, the multi-award winning Brio. The io aims to deliver exceptional sound quality in a smaller and more cost effective package. The class A/B circuit shares its DNA with the rest of Rega’s amplifiers, and as usual, great care has been taken in component selection. Sanken output transistors and an Alps volume potentiometer and a linear power supply that enables an output of 30 watts per channel into 8 Ω. Two line level inputs and a high quality moving magnet phono input are available as sources. There is a headphone output provided on the front of the unit for powering standard hi-fi headphones; this is driven from the power amplifier stage of the unit through relays to avoid signal degradation when headphones are inserted or the product is muted. A new redesigned mini remote handset is included.Q350 Bookshelf Speaker
The remarkable Q Series bookshelf speakers excel when space is limited. Featuring the signature KEF Uni-Q driver array with Computational Fluid Dynamics (CFD) port design, the Q350s deliver detailed natural sound with high clarity and tight bass."Sit anywhere" Uni-Q sound
At the heart of the evolved Q Series is the Uni-Q driver array. The signature innovation places the tweeter in the acoustic centre of the midrange and bass cone, bringing the acoustic ideal of a single point source closer than ever to realisation. The result is a more detailed, accurate three-dimensional sound image, which is dispersed more evenly throughout the room than is possible with any conventional speaker. Uni-Q's ultra-wide dispersion is further enhanced through KEF's 'tangerine' waveguide over the tweeter dome.New system design
To optimise the high-resolution purity of the Q Series bookshelf speakers, the Uni-Q driver is repositioned to the center of the cabinet to reduce unwanted internal resonance and adding refinement to sonic clarity and detail. With the addition of the damped tweeter loading tube providing a gentle termination of sound produced from the back of the tweeter, lower treble performance is improved dramatically and a new low-distortion inductor on the crossover provides cleaner bass.CFD-designed port
Featuring a Computational Fluid Dynamics (CFD) port design with the port repositioned to the rear of the speaker, clarity is improved by reducing the audibility of the midrange leakage through the port.Interested please feel free to contact:
Rega io
Headphone output
No load 8 V
32 Ω 1.6 V
54 Ω 2.4 V
300 Ω 5.7 V
Power consumption
Frequency response
Remote control
Fuse ratings
Weight
2.9Kg
180 x 290 x 68
MODEL Q350
358 x 210 x 306 mm
- Number of posts : 1336
» Denon PMA-600NE + KEF Q350 Hi-Fi System Package
» Marantz PM6006 + KEF Q350 Hi-Fi System Package
» Rega io + Monitor Audio Bronze 100 6G Hi-Fi System Package
» WiiM Amp + Wharfedale Diamond 220 Hi-Fi System Package
» WiiM Amp + Klipsch R-40M Hi-Fi System Package
