Rega io + Monitor Audio Bronze 100 6G Hi-Fi System Package
Rega io + Monitor Audio Bronze 100 6G Hi-Fi System Package Brand New. Now Selling At RM4,799. Free Shipping Within West Malaysia.
Bronze 6G
The Bronze 100’s larger cabinet size ensures the speakers deliver a grander audio presentation than the smaller Bronze 50. Our renowned C-CAM technology in the new 8" driver guarantees a detailed and powerful listening experience. The Bronze 100 rear Hive II port is designed and tuned to facilitate easy positioning without affecting performance.
As with all the loudspeakers in the Bronze Series, the superior build quality and choice of contemporary finishes ensures that the speakers are a stylish addition to any home.
Key Features
Rega io
Technical Specification
Power outputs at 230/115 V supply voltage
30 W RMS both channels driven into the rated load of 8 Ω
Input 1 (Phono) input sensitivity 2.1 mV @ 47 kΩ in parallel with 220 pF
Maximum input 1 (Phono) input level 100 mV
Input 2-3 (Line) input sensitivity 210 mV @ 47 kΩ
Maximum input 2-3 (Line) input level 10.25 V
Headphone output
No load 8 V
32 Ω 1.6 V
54 Ω 2.4 V
300 Ω 5.7 V
Source impedance: 109 Ω
Power consumption
135 W @ 230 V / 220 V / 115 V / 100 V into the rated load of 8 Ω
Frequency response
Phono: 15 Hz to 40 kHz (-3 dB points) / 27 Hz to 20.5 kHz (-1 dB points)
RIAA accuracy: (100Hz to 10 kHz) ±0.4 dB typically better than ±0.3 dB
Line: 12 Hz (-1 dB points) to 43 kHz (-3 dB points)
Remote control
Batteries included –2 x AAA Alkaline.
Fuse ratings
T1.6 AL 250 V: 230 V / 50Hz and 220 V / 60 Hz
T3.15 AL 250 V: 115 V / 60 Hz and 100 V / 50/60 Hz
Weight
2.9Kg
Dimensions (W x D x H) in mm
180 x 290 x 68
System Format
2-Way
Frequency Response (-6 dB)
52 – 25,000 Hz (Free field)
37 – 30,000 Hz (In room)
Sensitivity (2.83v @ 1m)
87 dB
Nominal Impedance
8 ohms
Minimum Impedance
4.5 ohms
Maximum SPL
110 dBA (pair)
Power Handling (RMS)
100 W
30 — 100 W
Bass Alignment
Bass reflex - HiVe II port system
Crossover Frequency
2,200 Hz
Drive Unit Complement
1 x 8" C-CAM bass/mid-range driver
1 x 25 mm C-CAM Gold Dome tweeter with UD Waveguide
External Dimensions (Including Grille and Terminals (H x W x D))
376 x 231 x 325 mm (1413/16 x 91/8 x 1213/16")
External Dimensions (including Outrigger Feet and Spikes (H x W x D))
N/A
Weight (each)
7.8 kg (17 lb 3 oz)
Sold As
Pair
Rega io
The io has been designed to offer exceptional Rega performance at an affordable price point. It uses the same amplifier stage as the multi-award winning Brio now designed to run at 30 W per channel into 8 Ω. The io features two line level inputs, a high specification Rega moving magnet phono stage, and a dedicated high quality headphone output. The io will integrate seamlessly into any home audio system whilst remaining simple to use and easy to set up. A must for demonstration.KEY FEATURES
- Integrated phono stage
- Headphone socket
- Mini remote control
- All new custom designed chasis
Because music matters
The io uses the same power amplifier and phono stage as its larger brother, the multi-award winning Brio. The io aims to deliver exceptional sound quality in a smaller and more cost effective package. The class A/B circuit shares its DNA with the rest of Rega’s amplifiers, and as usual, great care has been taken in component selection. Sanken output transistors and an Alps volume potentiometer and a linear power supply that enables an output of 30 watts per channel into 8 Ω. Two line level inputs and a high quality moving magnet phono input are available as sources. There is a headphone output provided on the front of the unit for powering standard hi-fi headphones; this is driven from the power amplifier stage of the unit through relays to avoid signal degradation when headphones are inserted or the product is muted. A new redesigned mini remote handset is included.Bronze 6G
Bronze 100
The Bronze 100 speakers are the natural step up from the Bronze 50s and feature larger cabinets and renowned Monitor Audio speaker construction to give a larger and more compelling performance.The Bronze 100’s larger cabinet size ensures the speakers deliver a grander audio presentation than the smaller Bronze 50. Our renowned C-CAM technology in the new 8" driver guarantees a detailed and powerful listening experience. The Bronze 100 rear Hive II port is designed and tuned to facilitate easy positioning without affecting performance.
Key Features
- Monitor Audio signature C-CAM Gold Dome Tweeter upgraded with the new Uniform Dispersion (UD) Waveguide for an incredibly lifelike sound
- C-CAM mid-bass driver featuring updated cone geometries and Damped Concentric Mode (DCM) technology which allows the speaker to have a deeper, fuller sound while retaining a clean and precise presentation
- Designed for performance – intricately optimised listening experience for music and movies
- Hive II rear port tuned for ease of positioning without affecting sound performance
- Acoustically transparent hexagonal dispersion pattern grille also featured on our award-winning Silver and Gold Series, for the Monitor Audio family look
- High-quality gold-plated bi-wire terminals
- Pureflow silver-plated oxygen-free copper internal cabling for highest quality current transfer through the signal chain
- Audio transparent bespoke cloth covered magnetic grilles for a more discreet appearance
- Add Bronze AMS Dolby Atmos enabled speakers atop for use in any AV home cinema system
Rega io
Headphone output
No load 8 V
32 Ω 1.6 V
54 Ω 2.4 V
300 Ω 5.7 V
Power consumption
Frequency response
Remote control
Fuse ratings
Weight
2.9Kg
180 x 290 x 68
System Format
2-Way
87 dB
Nominal Impedance
8 ohms
Minimum Impedance
4.5 ohms
Maximum SPL
110 dBA (pair)
100 W
30 — 100 W
Bass Alignment
Crossover Frequency
2,200 Hz
N/A
Weight (each)
7.8 kg (17 lb 3 oz)
Sold As
Pair
- Number of posts : 1323
» NAD C 316BEE V2 + Monitor Audio Bronze 50 6G Hi-Fi System Package
» WiiM Amp + Monitor Audio Bronze 50 6G Hi-Fi System Package
» Yamaha R-N303 + Monitor Audio Bronze 50 6G Hi-Fi System Package
» Onkyo A-9110 + Monitor Audio Bronze 50 6G Hi-Fi System Package
» Monitor Audio Bronze 6 5.1 Home Theater Package
