Onkyo A-9110 + Monitor Audio Bronze 50 6G Hi-Fi System Package
Onkyo A-9110 + Monitor Audio Bronze 50 6G Hi-Fi System Package Brand New. Now Selling At RM3,299. Free Shipping Within West Malaysia.
Bronze 6G
Designed to perform in the smallest of living spaces, the compact and bookshelf-friendly Bronze 50s will deliver the renowned Monitor Audio sound even when placed close to a wall. They are truly versatile and are ideal for both hi-fi and home cinema playback – they can bring games to life by revealing fresh audio detail. Add the Bronze AMS Dolby Atmos enabled speakers atop the Bronze 50 to heighten the surround experience.
The smallest speaker in the Bronze Series houses our renowned C-CAM mid-bass driver and C-CAM Gold dome tweeter to ensure powerful and detailed audio reproduction with an improved stereo performance.
The choice of four modern finishes and stylish contrasting baffle give the Bronze 50s a superior appearance and ensure they will complement the décor of any room. Should you prefer to have the speakers mounted on the wall, there’s an option to do so utilising the rear fixing point and FIX-M Speaker Mount.
Key Features
Onkyo A-9110
HIGHLIGHTS
50 W + 50 W high-current amplification
WRAT (Wide Range Amplification Technology)
Direct Mode for source-authentic audio reproduction
Phase Matching Bass Boost
High-current EI transformer, large custom audio capacitors, and discrete output stage
MM phono input, 4 x RCA
New fine display for easy source selection
AMPLIFICATION FEATURES
WRAT (Wide Range Amplifier Technology)
Customized high-current EI transformer
Two large custom-fabricated audio-grade main capacitors
Optimum Gain Volume Circuitry for clear low-volume playback
Four-ohm speaker-driving capability
Rigid anti-resonant 1.6 mm metal chassis
CONNECTION FEATURES
4 analog RCA inputs
1 phono input with discrete MM phono equalizer
1 analog RCA line-level output
Subwoofer pre-out
Non-magnetic speaker posts with clear knobs
6.35 mm headphone jack
RI (Remote Interactive) input
ADDITIONAL FEATURES
Fine display shows active input
Independent tone controls for bass and treble with balance control
Easy-to-use controls for smooth operation without a remote
RI (Remote Interactive) input enables connection of a supported component for integrated control with one remote controller
Auto Power Standby
Available in black
GENERAL SPECIFICATIONS
Power output: 50 W + 50 W (4 ohms, 20 Hz–20 kHz, 0.9% THD, 2-ch driven, IEC)
Frequency response: 10 Hz–100 kHz/+1 dB, -3 dB (Direct Mode)
Dimensions (W x H x D): 435 x 129 x 330 mm
Weight: 7.0 kg
System Format
2-Way
Frequency Response (-6 dB)
62 – 25,000 Hz (Free field)
40 – 30,000 Hz (In room)
Sensitivity (2.83v @ 1m)
85 dB
Nominal Impedance
8 ohms
Minimum Impedance
4.4 ohms
Maximum SPL
107 dBA (pair)
Power Handling (RMS)
80 W
20 — 80 W
Bass Alignment
Bass reflex - HiVe II port system
Crossover Frequency
2,500 Hz
Drive Unit Complement
1 x 51/2" C-CAM bass/mid-range driver
1 x 25 mm C-CAM Gold Dome tweeter with UD Waveguide
External Dimensions (Including Grille and Terminals (H x W x D))
281 x 166 x 265 mm (111/16 x 69/16 x 107/16")
External Dimensions (including Outrigger Feet and Spikes (H x W x D))
N/A
Weight (each)
5 kg (11 lb)
Sold As
Pair
A-9110
Integrated Stereo AmplifierVersatile pre-main amp refreshes your music life
Onkyo builds on the success of its A-9010 pre-main amp with the new A-9110 Integrated Stereo Amplifier, a component that refines an original amp design that’s won an excellent critical and commercial reputation for dynamic, musical sound. Lively dynamics, deep bass, and layered detail emerge from warm and expressive tuning sure to please European ears. WRAT delivers high-current power stability via large custom capacitors, while low-NFB amps capture the depth and spatiality of analog and hi-res recordings. Five RCA inputs including MM phono stage connect your sources while high-quality speaker-posts reveal Onkyo’s hi-fi heritage and careful attention to detail. The A-9110 invites you into each album, the hours passing comfortably in pure analog sound.Authentic High-Fidelity Amplification System
The A-9110 features Onkyo’s time-proven low-negative-feedback amplifier topology that distinguishes the timbral warmth, fullness, and vibrancy of the recording. This circuitry captures a wide frequency spectrum with uncommonly low distortion.Stable high-current power with wide-range amplifiers
Dynamic changes in music cause impedance to fluctuate. If power can’t be delivered when impedance drops, sound quality suffers. Onkyo’s solution is WRAT, specifically its high-output EI transformer, huge custom-made main audio capacitors, and carefully selected high-quality parts. High-current stability controls the speaker-drivers for accurate and assured reproduction of dynamic musical passages.Direct Mode brings you closer to the source
Direct Mode bypasses tone and PM Bass circuitries. In combination with a refined amp circuit design, signal-path-lengths have been significantly reduced in comparison to the A-9010 for even more accurate and faithful sound. Enjoy end-to-end analog music reproduction from turntable to speakers, and recapture the atmosphere of the original recording with any connected source.Phase Matching Bass Boost enriches sound at low volume
Most pre-main amps have a loudness button designed to boost low-mid frequency sound. However, conventional designs are prone to phase-shift, which degrades the clarity of the vocal frequency band. Onkyo’s Phase Matching Bass Boost function eliminates phase-shift between low- and mid-range frequency bands above 300 Hz. Bass response is enhanced without compromising vocal clarity, and that’s something especially useful when playing music at low volume where bass and high-frequency sounds are more difficult to hear.New fine display shares info clearly
A new display panel boasts fine text resolution, making it easier to read at a distance than single bulbs. It shows active selected input at a glance.Quality speaker-posts make perfect contact
Speaker cables with your choice of terminal are firmly secured by high-quality speaker binding posts. Each wide-spaced non-magnetic post prevents interference and features a large, easy-to-grip transparent knob.Sounds clearer at low volumes
When playing music at low volume, the signal normally drops close to the component’s noise floor. The signal picks up noise, which is amplified, and the result is muffled sound. To avoid this, the A-9110 features Optimum Gain Volume Circuitry, a volume circuit that requires less than half the usual amount of attenuation. The signal never approaches the noise floor, so you can enjoy clearest sound at low volume.Thick and rigid chassis tames resonance
Every hi-fi component generates electromechanical resonance. This translates into signal noise, and that impacts on the sound coming out of your speakers. To combat the negative effects of vibration, the A-9110 features a rigid metal chassis that’s 1.3 times thicker than the A-9010 at 1.6 mm. Working together with large, wide-spaced insulators, unwanted resonance is virtually eliminated.Bronze 6G
Bronze 50
The Monitor Audio Bronze 50 bookshelf loudspeaker is the most compact model in the series and delivers a size-defying audio performance.Designed to perform in the smallest of living spaces, the compact and bookshelf-friendly Bronze 50s will deliver the renowned Monitor Audio sound even when placed close to a wall. They are truly versatile and are ideal for both hi-fi and home cinema playback – they can bring games to life by revealing fresh audio detail. Add the Bronze AMS Dolby Atmos enabled speakers atop the Bronze 50 to heighten the surround experience.
Key Features
- Monitor Audio signature C-CAM Gold Dome Tweeter upgraded with the new Uniform Dispersion (UD) Waveguide for an incredibly lifelike sound
- C-CAM mid-bass driver featuring updated cone geometries and Damped Concentric Mode (DCM) technology which allows the speaker to have a deeper, fuller sound while retaining a clean and precise presentation
- Designed for performance – intricately optimised listening experience for music and movies
- Hive II rear port tuned for ease of positioning without affecting sound performance
- Acoustically transparent hexagonal dispersion pattern grille also featured on our award-winning Silver and Gold Series, for the Monitor Audio family look
- High-quality gold-plated bi-wire terminals
- Pureflow silver-plated oxygen-free copper internal cabling for highest quality current transfer through the signal chain
- Audio transparent bespoke cloth covered magnetic grilles for a more discreet appearance
- Add Bronze AMS Dolby Atmos enabled speakers atop for use in any AV home cinema system
- Can be wall-mounted using Monitor Audio FIX-M Speaker Mount, utilising its rear fixing point
Onkyo A-9110
HIGHLIGHTS
CONNECTION FEATURES
4 analog RCA inputs
Subwoofer pre-out
ADDITIONAL FEATURES
Auto Power Standby
Available in black
Weight: 7.0 kg
System Format
2-Way
85 dB
Nominal Impedance
8 ohms
Minimum Impedance
4.4 ohms
Maximum SPL
107 dBA (pair)
80 W
20 — 80 W
Bass Alignment
Crossover Frequency
2,500 Hz
N/A
Weight (each)
5 kg (11 lb)
Sold As
Pair
- Number of posts : 1323
» NAD C 316BEE V2 + Monitor Audio Bronze 50 6G Hi-Fi System Package
» WiiM Amp + Monitor Audio Bronze 50 6G Hi-Fi System Package
» Rega io + Monitor Audio Bronze 100 6G Hi-Fi System Package
» Yamaha R-N303 + Monitor Audio Bronze 50 6G Hi-Fi System Package
» Monitor Audio Bronze 6 5.1 Home Theater Package
