Denon PMA-A110 Integrated Amplifier & DCD-A110 CD Player Made In Japan
Denon PMA-A110 Integrated Amplifier & DCD-A110 CD Player Made In Japan Brand New. Now Selling At RM38,499. Free Shipping Within West Malaysia.
Celebrating 110 years of audio excellence, Denon is proud to deliver the limited edition Anniversary Series PMA-A110 Integrated Amplifier marking the pinnacle of Denon HiFi technology.
為慶祝Denon110年的卓越音響成就,Denon自豪地推出限量週年紀念版PMA-A110合併放大器,該放大器具有最新技術,可以體驗Denon給與的Hi-Fi特質。
DENON PMA-A110具有110年的音響設計承傳,可讓最挑剔的發燒友滿意,對於想要構建夢想中的2聲道HiFi系統的聽眾來說,它是絕佳的選擇。 PMA-A110擁有DENON獲得專利的高級超大電流(UHC)單端推挽電路功率放大器,每聲道功率為160W(4ohm,1kHz,THD:0.7%)。 輕鬆將模擬和數碼音源或您的黑膠唱盤連接到內置唱機前置放大器。 使用4組384 kHz / 32bit DAC聆聽您喜歡的高清音頻內容,以實現最高質量的音頻播放。 PMA-A110合併放大器與DCD-A110完美搭配,旨在提升您對音樂的期望。
Celebrate 110 years of defining audio excellence with the masterfully crafted Denon limited edition Anniversary Series silver graphite SACD player, the DCD-A110. Offering a Quad DAC configuration and new Ultra AL32 Processing, upgrade your expectations and enjoy your music in perfect detail.
精心製作的Denon DCD-A110限量系列週年紀念版石墨銀色SACD播放機,是為慶祝Denon 110年的卓越音響成就。 採用並列4 DAC配置和新的Ultra AL32 Processing處理功能,可以提高您的聆聽期望,並享受完美的音樂。
Denon PMA-A110
Features
Channels 2
110th Anniversary Audio Tuning Yes
All black interior Yes
Exclusive A110 speaker terminals Yes
Aluminium Top Cover Yes
Aluminium Feet Yes
Digital in: USB-B / optical / coaxial / USB-A 1 / 3 / 1 / No
Sample Rate digital In 192 kHz / 24-bit
USB-B DSD Audio Streaming (DoP): DSD2.8 / DSD5.6 <=DSD11.2
USB-B PCM sample rate 384 kHz / 32-bit
Quad DAC Configuration Yes
DAC chip 4x PCM1795, Burr Brown
Mono-Mode
Asynchronous mode rear USB Yes
Bit-perfect transmission Yes
Ground isolator for DAC Mode operation Yes
AL 32 Processing ULTRA AL32
DAC Master Clock Design Yes
Streaming audio from PC Yes
Analogue Mode Yes
UHC-MOS single push pull circuit 7th Generation
LC mounted twin transformer Yes
Wide range amplifier Yes
High current dynamic power supply Yes
Power amp discrete construction Yes
Balance / Bass / Treble / Loudness Yes / Yes / Yes / No
Others
Shottky diodes Yes
Solid Heat Sinks Yes (BLACK)
Source Direct Yes
Power Amp direct Yes
Inputs Outputs
Audio Inputs 5
Phono Input: MM / MC Yes / Yes
Audio Outputs 1
Power Amp Direct IN Yes
Gold plated Cinch Yes
Number of terminals 4
Remote Control Bus in / out Yes
Headphone Out Yes
Output power 8 Ohm (20 Hz - 20 kHz, T.H.D. 0.07%) 80 W
Output power 4 Ohm (1 kHz, T.H.D. 0.7%) 160 W
Total Harmonic Distortion 0.01%
Input Sensitivity: MM 2.5 mV / 47 kohm
Input Sensitivity: MC 200 uV-100 ohm
Signal to Noise Ratio: MM/MC 89 dB / 74 dB
Input Sensitivity: High level 135 mV / 47 kohms
Signal to Noise Ratio: High level 110dB
Treble Control ± 8 dB at 10 kHz
Bass Control ± 8 dB at 100 Hz
General
Available colors: Premium Silver / Black Silver Graphite
Metal Front Panel Yes
Power Consumption in W 400
Standby Consumption in W 0.2
Auto Power Off Yes
Detachable Power Cable Yes
Remote Control RC-1237
System Remote Function Yes
Maximum Dimensions (W x D x H) in mm 434x450x182
Weight in kg 25
Carton Maximum Dimensions (W x D x H) in Inches 573 x 533 x 317
Carton Weight (inc. product) in LBS 29.8
Denon DCD-A110
Features
CD Compatibility: CD / CD-R/RW / SA-CD / WMA / MP3 / AAC Yes / Yes / Yes / Yes / Yes / Yes
Data Disc Compatibility: DSD / WAV / ALAC <=5.6 / 192 / 96
Aluminium Feet Yes
Mechanism stabilizer - made of copper Yes
Quad DAC Configuration 4x PCM1795
Extra metal plate for chassis strengthing Yes
Aluminium side panels Yes
Others
Display: Dimmer / Off Yes / Yes
Playback
Program Play (CD / SA-CD) Yes / Yes
Repeat Yes
Random Play Yes
Start Sound Mode for SA CD Yes
Inputs Outputs
Analogue Out (Cinch) 2ch
Digital Optical In / Out No / 1
Digital Coaxial In / Out No / 1
Mechanism SVH Loader
DAC IC 4x PCM1795, Burr Brown
Mono-Mode
Frequency Response (Cust.) 2 Hz-50 kHz
Dynamic Range (SA) 118 dB
Signal to Noise Ratio (SA) 122 dB
Total Harmonic Distortion (SA) 0.00%
Frequency Response 2 Hz-20 kHz
Dynamic Range 101 dB
Signal to Noise Ratio 122dB
Total Harmonic Distortion 0.00%
General
Power Consumption in W 42
Standby Consumption in W 0.1
Auto Power Off Yes
Maximum Dimensions (W x D x H) in mm 434 x 405 x 138
Weight in kg 16.2
Carton Maximum Dimensions (W x D x H) in Inches 577 x 555 x 302
Carton Weight (inc. product) in LBS 21.5
PMA-A110
FEATURES - PMA-A110
Limited Edition Denon 110-Year Anniversary Series PMA-A110 Silver Graphite Integrated Amplifier with 160 Watts per ChannelOverview
Designed with 110 years of audio heritage to please the most discerning audiophile, the Denon PMA-A110 is the superior choice for listeners who want to build the 2-channel Hi-Fi system of their dreams. Powered by Denon’s patented Advanced Ultra High Current (UHC) single-push-pull circuit power amplifier, the PMA-A110 integrated amplifier delivers 160 Watts of power-per-channel. Easily connect both analogue and digital sources or your turntable to the built-in phono pre-amp. Listen to your favourite Hi-Res audio content through the Quad 384-kHz/32-bit DAC section with the highest resolution in audio quality. Paired perfectly with the DCD-A110, the PMA-A110 Integrated Amplifier was designed to upgrade your expectations with your music in mind.DENON PMA-A110具有110年的音響設計承傳,可讓最挑剔的發燒友滿意,對於想要構建夢想中的2聲道HiFi系統的聽眾來說,它是絕佳的選擇。 PMA-A110擁有DENON獲得專利的高級超大電流(UHC)單端推挽電路功率放大器,每聲道功率為160W(4ohm,1kHz,THD:0.7%)。 輕鬆將模擬和數碼音源或您的黑膠唱盤連接到內置唱機前置放大器。 使用4組384 kHz / 32bit DAC聆聽您喜歡的高清音頻內容,以實現最高質量的音頻播放。 PMA-A110合併放大器與DCD-A110完美搭配,旨在提升您對音樂的期望。
DCD-A110
Overview
To celebrate 110 years of defining audio excellence, Denon is proud to bring you our premium flagship SACD player featuring Denon’s original patented Advanced S.V.H. Mechanism for the highest audio accuracy. With an outstanding Quad DAC configuration, advanced Ultra AL32 Processing, and strong aluminum feet, upgrade your musical expectations. This celebratory Anniversary Series SACD player comes in a unique silver graphite colour, with a 5-year out-of-box warranty and a special Certificate of Authenticity stamped with the approval of Denon’s Head Engineer.概述
為了慶祝Denon成立110週年在音響上的卓越成就,精心製作了限量版石墨銀色DCD-A110 高級旗艦SACD播放機,讓它實現您對播放機的所有期望。它採用Denon的專利的Advanced S.V.H轉盤。,是最高音頻檢拾準確性的機制。 憑藉出色的並列4 DAC配置,先進的Ultra AL32 Processing處理和堅固的鋁製機腳,可提高您對音樂的期望。 這款為慶祝周年紀念版SACD播放機具有5年的即用保養,並附有經Denon總工程師批準的特別真品證書。110 YEARS OF DEFINING AUDIO EXCELLENCE
Celebrate 110 years of defining audio excellence with the Denon limited edition Anniversary Series silver graphite DCD-A110 SACD Player. Denon has been upgrading your expectations in the audio and video industry since 1910 and we are proud to celebrate this great achievement with the DCD-A110 and its partner product, the PMA-A110.DENON 110年慶祝卓越音響成就
自1910年以來,Denon就一直在提高您對音頻和視頻的期望,通過推出Denon限量系列週年紀念版石墨銀色DCD-A110 SACD播放機,與及其合作夥伴產品PMA-A110,來一起慶祝Denon110年以來卓越音響的偉大成就。Interested please feel free to contact:
Denon PMA-A110
Features
Channels 2
Aluminium Feet Yes
Mono-Mode
Analogue Mode Yes
Others
Shottky diodes Yes
Source Direct Yes
Inputs Outputs
Audio Inputs 5
Audio Outputs 1
Headphone Out Yes
General
Auto Power Off Yes
Weight in kg 25
Denon DCD-A110
Features
Aluminium Feet Yes
Others
Playback
Repeat Yes
Random Play Yes
Inputs Outputs
Mono-Mode
General
Auto Power Off Yes
Weight in kg 16.2
- Number of posts : 1342
» Denon PMA-A110 110th Anniversary Edition Integrated Amplifier Made In Japan
» Denon DCD-A110 110th Anniversary Edition CD Player Made In Japan
» Denon AVC-A110 110th Anniversary Edition AV Receiver Made In Japan
» Marantz PM8006 Integrated Amplifier & ND8006 Network Music /CD Player Made In Japan
» Denon PMA-A110 Integrated Limited Edition Amplifier (Used)
