Marantz PM8006 Integrated Amplifier & ND8006 Network Music /CD Player Made In Japan
Marantz PM8006 Integrated Amplifier & ND8006 Network Music /CD Player Made In Japan Brand New. Now Selling At RM15,699. Free Shipping Within West Malaysia.
Pure, powerful Marantz sound
For the integrated amplifier connoisseur, the PM8006 delivers the power you expect from a Marantz. Not only does it deliver the controlled power that audiophiles demand, it creates the warm musical sound you expect from Marantz.
Digital Music Source Player with HEOS Built-in
PM8006
Amplifier
Number of Channels 2
Power Rating 70 W per channel @ 8 Ohms RMS
100 W per channel @ 4 Ohms RMS
Frequency Response 5 Hz to 100 kHz
Signal to Noise Ratio MM: 87 dB
High Level: 106 dB (2 V input)
Power Amp Direct In: 125 dB
Total Harmonic Distortion (THD) 0.02%
Damping Factor 100
Connectors
Input 6 x stereo RCA L/R (1 MM phono)
1 x stereo RCA L/R power amp direct
Output 1 x 1/4" (6.35 mm) headphone (front)
1 x stereo RCA L/R
1 x stereo RCA L/R pre-out
Speaker Connectors 4 x binding post pairs
Other Connectors 1 x RCA remote in
1 x RCA remote out
1 x AC power inlet
1 x ground terminal
Input Sensitivity MM: 2 mV / 47 kOhms
High Level: 200 mV / 20 kOhms
Power Amp Direct In: 1.6 V / 15 kOhms
General
Front Panel Construction Metal
Power Requirements 240 VAC, 50/60 Hz
Power Consumption Operational: 220 W
Standby: 0.2 W
Dimensions (W x H x D) 17.3 x 5 x 14.9" (440 x 128 x 379 mm)
Weight (Approximate) 26.5 lb (12 kg)
ND8006
CD Player
Type Single-disc tray
Supported Disc Types CD, CD-R/RW
Supported Disc Formats WMA, MP3, AAC
USB Audio Support DSD 11.2
Network Audio Files Supported WMA, MP3, AAC, DSD 2.8, DSD 5.6, FLAC HD 192/24, WAV 192/24, ALAC 192/24
Frequency Response 2 Hz to 20 kHz
Dynamic Range 100 dB
Signal-to-Noise Ratio 110 dB
THD 0.00002%
Channel Separation 105 dB
Connectivity
AirPlay Yes
Wi-Fi Yes
Bluetooth Yes
Inputs 2 x optical TOSLINK
1 x digital coaxial
1 x USB Type-A (front)
1 x USB Type-B
Outputs 1 x optical TOSLINK
1 x digital coaxial
1 x stereo RCA fixed
1 x stereo RCA variable
1 x 1/4" (6.35 mm) headphones (front)
Other Connectors 1 x Ethernet
2 x Bluetooth/Wi-Fi antennas
1 x 1/8" (3.5 mm) flasher in
1 x RS-232C control in
1 x RCA remote control in
1 x RCA remote control out
1 x AC power in
General
Power Requirements 120 VAC, 60 Hz
Power Consumption Typical: 42 W
Standby: 0.3 W
Dimensions (W x H x D) 17.3 x 4.2 x 13.4" (43.9 x 10.7 x 34 cm)
Weight 17.6 lb (8 kg)
Packaging Info
Package Weight 23.7 lb
Box Dimensions (LxWxH) 21.4 x 18.5 x 8.4"
PM8006
INTEGRATED AMPLIFIER WITH NEW PHONO-EQPure, powerful Marantz sound
Current Feedback
Current Feedback amplification is a well-known, Marantz-original circuit technology, thoughtfully designed to match the requirements of Super Audio hi-res music for wide-bandwidth, high-speed reproduction. The impedance at the Current Feedback point is limited, generating a very low phase shift. Marantz Current Feedback amplifiers reduce the need for phase compensation by minimizing Negative Feedback (NFB). This simplifies the signal path and results in a high through-rate, excellent transient response and superb sonic transparency across the full bandwidth. Unlike conventional Voltage Feedback topology, Current Feedback also makes the power amplifier insensitive to difficult loudspeaker loads.Marantz HDAM Technology
Marantz developed its own discrete circuit boards called Hyper-Dynamic Amplifier Modules, or HDAMs, to replace the chip based amps used elsewhere. Using discrete surface mount components with short mirror-image left and right signal paths, HDAMs outperform the regular integrated Op-amps dramatically in Slew Rate and noise level. The result is much more dynamic, accurate and detailed sound. Over the years, Marantz has developed different HDAMs to fit the particular requirements of players and amplifiers. The PM8006 uses the high-grade SA3 version.Marantz Musical Phono EQ
For a long time, Marantz integrated amplifiers have featured high-quality phono stages. We’ve elevated our commitment to vinyl with the Marantz Musical Phono EQ stage, as seen in the PM8006 amplifier. Enjoy the very best playback of all music sources, be they digital or analog. Marantz Musical Phono EQ uses two-stage amplification, allowing less gain per stage for lower distortion. The PM8006 combines Marantz HDAM technology with JFETs (junction gate field-effect transistors) in the input stage, providing high input impedance that eliminates the need for AC coupling capacitors and simplifies the signal path, vastly improving the signal purity overall.Toroidal Transformer
A Toroidal transformer offers several advantages that derive from its efficiency and power capability. The shape of it lends to low levels of electromagnetic radiation and mechanical vibration, producing improved sound quality over what you might experience with dated transformer models.ND8006
UNIQUE COMPLETE DIGITAL MUSIC SOURCE PLAYERDigital Music Source Player with HEOS Built-in
Effortlessly adds streaming to your Marantz system
Whether you're listening to your CDs, using the USB-DAC function or streaming your content, the ND8006 gives you the flexibility to enjoy all your favourite music the way you've come to expect - with the rich, pure Marantz sound.The Complete Digital Music Source Player
The ND8006 is built to meet all the requirements of the modern digital music listener, combining the technology of three separate audio components into one complete unit. Based on decades of experience in analogue and digital audio, plus featuring enhanced functionality and circuit design, the Marantz ND8006 combines a CD player with a digital sources hub. It offers playback from home network, local USB storage, online sources such as streaming services and Internet radio, HEOS support and DAC functionality — plus, Apple AirPlay and Bluetooth. The ND8006 is future-proof with functionality that accepts file formats all the way up to 11.2Mhz quad-DSD and 384kHz/32-bit PCM via USB-B/USD-DAC.HEOS Music Streaming
With HEOS Built-in technology, enjoy your favourite music in any room of your home for a wireless, whole-home audio experience. Play the same song in every room or select a different song for each connected room; the choice is yours. Enjoy music from TuneIn, Spotify, Amazon Prime Music HD, TIDAL, Deezer and more or your local music file libraries. With additional HEOS Built-in components, like HEOS-capable speakers, play all your music in one room or many.Support For Major Voice Control Agents
Enjoy effortless voice control and total flexibility from the leading voice agents. Speak commands with Amazon Alexa , Google Assistant and Apple Siri. Ask to play your favourite music, turn the volume up, skip to the next track, switch inputs and more. Switch between voice agents, or pick a favourite to use — the choice is yours. Functionality varies by voice agentMarantz Musical Digital Filtering (MMDF)
The ND8006 features the unique Marantz Musical Digital Filtering (MMDF), inspired by our audiophile reference class technology. For Marantz, using standard digital filter solutions is not an option, as this filtering is crucial to the sound reproduction of digital input signals.Interested please feel free to contact:
PM8006
Amplifier
Damping Factor 100
Connectors
1 x stereo RCA L/R
1 x RCA remote out
1 x AC power inlet
1 x ground terminal
General
Standby: 0.2 W
ND8006
CD Player
THD 0.00002%
Connectivity
AirPlay Yes
Wi-Fi Yes
Bluetooth Yes
1 x digital coaxial
1 x USB Type-B
1 x digital coaxial
1 x AC power in
General
Standby: 0.3 W
Packaging Info
- Number of posts : 1318
» Marantz PM8006 Integrated Amplifier Made In Japan
» Marantz ND8006 Network Music /CD Player Made In Japan
» Marantz ND8006 Network Music /CD Player Japan Made (Sold Out)
