Denon AVR-S960H + Taga Harmony TAV-606 V.3 5.0 Home Theatre Package
Denon AVR-S960H + Taga Harmony TAV-606 V.3 5.0 Home Theatre Package Brand New. Now Selling At RM6,599. Free Shipping Within West Malaysia.
Package Included:
Denon AVR-S960H 7.2Ch 8K Atmos Network AV Receiver
Taga Harmony TAV-606 V.3 5.0 Speaker Package
Please choose your preferred Subwoofer using FREE Voucher
We accept trade in your old system
* Free Rm300 Voucher For New Subwoofer (Valid For 6 Months)
* Free QED QX075 Speaker Cable 30Meter (Free cable Not included banana plugs)
* One voucher redeemable for each product *
* Free gift will be packed nicely in the product’s box for shipping option
7.2声道8K超高清AV接收机,单声道185W,支持3D音频格式,如Dolby Atmos、Dolby Atmos Height Virtualization技术、DTS:X和DTS Virtual:X,支持8K/60Hz和4K/120Hz传输等最新HDMI规格。具备Wi-Fi、蓝牙、HEOS内置无线多室音乐流媒体和语音控制性能。
The front-panel USB offers convenient audio playback of MP3 and Hi-Res audio formats (WAV, FLAC, ALAC and DSD 2.8/5.6MHz files). Stream popular music services like Spotify, Amazon Music HD, TIDAL and more wirelessly via Bluetooth, Apple AirPlay 2 and Wi-Fi with HEOS Built-in. The new Denon AVR-S960H also works with Amazon Alexa, Google Assistant and Apple Siri for effortless voice control.
By visually guiding you through each step in the setup process, the award-winning Denon Setup Assistant ensures a fast, simple onboarding experience. Because the acoustics of every home theatre are different, the AVR-S960H features premium room calibration technology from Audyssey to automatically measure and optimize your AV receiver, providing a truly immersive 3D audio experience.
前面板USB可用于轻松播放MP3和高解析度音频格式(WAV、FLAC、ALAC和DSD 2.8/5.6 Mhz文件)的音频。借助蓝牙、Apple AirPlay 2和内置HEOS的Wi-Fi,Denon AVR-S960H可提供多种流媒体音乐服务。此外,它还支持苹果Siri,可轻松实现语音控制。
屡获殊荣的Denon设置助手能直观地指导您完成每一步设置,确保您快速轻松地完成设置。每一个家庭影院都与众不同,AVR-S960H采用Audyssey的高级室内校准技术(它可以自动测量和优化AV接收机),根据您独特的聆听环境量身定制真正沉浸式3D音频体验。
Adding high value to price ratio, the TAV-606 is great bargain both for hi-fi stereo as well as home theatre systems.
Although the price of speakers is extremely attractive, there was no place for compromises during process of designing and production and our sound engineers have used best components and technology to ensure sound performance exceeding level set by most of the competitors.
The sound performance is light, fast, well-define and with a great dynamics and deep, reach low bass.
The TAV-606 v.3 can be described as “transparent” speakers, as well as their performance focuses on natural playback and sonic accuracy.
Denon AVR-S960H Specs
Amplifier
Channels 7.2
Object-Based Configuration: 5.1.2
Power Output per Channel 2-Channel Driven:
90 W at 8 Ohms / 20 Hz to 20 kHz / 0.008% THD
125 W at 6 Ohms / 1 kHz / 0.7% THD
1-Channel Driven:
145 W at 6 Ohms / 1 kHz / 0.7% THD
185 W at 6 Ohms / 1 kHz / 10% THD
Frequency Response 10 Hz to 100 kHz +1/-3 dB (Direct Mode)
Speaker Impedance 4 to 16 Ohms
Audio Processing
DTS Compatibility DTS-HD Master Audio, DTS:X
Dolby Compatibility Dolby Atmos, Dolby Pro Logic IIz, Dolby TrueHD
Auro 3D Support No
Upmixing Technology Dolby Surround, DTS Neural:X, DTS Virtual:X, Dolby Atmos Height Virtualization Technology
Supported File Formats AAC, ALAC, DSD, FLAC, MP3, WAV, WMA
Video
HDR Compatibility HDR10, HDR10+, Dolby Vision, Hybrid Log Gamma
Pass-Through Support 8K60p 4:4:4 (3D, BT.2020)
Upscaling 8K
GUI Yes
Connectivity
Rear A/V Inputs 6 x HDMI
2 x 3RCA Component
2 x RCA Composite
2 x Optical TOSLINK
1 x Digital Coaxial
4 x Stereo RCA
1 x Stereo RCA (Phono) with Ground Screw
Rear A/V Outputs 2 x HDMI
1 x 3RCA Component
1 x RCA Composite
2 x RCA Subwoofer
Front I/O 1 x USB Type-A Input
1 x 1/4" / 6.35 mm Headphone Output
1 x 1/8" / 3.5 mm Setup Mic Input
Other Rear I/O 2 x Bluetooth/Wi-Fi Antenna Terminal Input
1 x AM Antenna Terminal Input
1 x FM Antenna Terminal Input
1 x RJ45 (Ethernet)
Speaker Connectors 7 x Binding Post Pairs
HDCP Support Version 2.3
Audio Return Channel (ARC) Yes, eARC
HDMI CEC Yes
Input Sensitivity 200 mV
Signal to Noise Ratio 100 dB (Direct Mode / IHF-A)
Wireless Connectivity
Wireless Audio Protocols AirPlay 2, HEOS
Control
Virtual Assistant Support Amazon Alexa, Apple Siri, Google Assistant, Josh.ai
Tuner Section
Tuner Type AM, FM
Radio Frequencies AM: 520 to 1710 kHz
FM: 87.5 to 107.9 MHz
Power
AC Input Power 240 VAC, 50/60 Hz
Power Consumption Active: 500 W
No Sound (ECO Off): 70 W
No Sound (ECO On): 35 W
CEC Standby: 0.5 W
Standby: 0.1 W
Physical
Dimensions (W x H x D) 17.1 x 9.3 x 13.4" / 43.4 x 23.6 x 34.0 cm (Antenna Up)
17.1 x 6.6 x 13.4" / 43.4 x 16.8 x 34.0 cm (Antenna Down)
17.1 x 6.6 x 13.0" / 43.4 x 16.8 x 33.0 cm (Antenna Removed)
Weight 21 lb / 9.53 kg
Packaging Info
Package Weight 25.495 lb
Box Dimensions (LxWxH) 20.4 x 17 x 9.7"
FRONT SPEAKER
Design Floorstanding, 3-way
4 drivers
Bi-wiring, bi-amp
TLIE enclosure
Crossover points: 500Hz, 3.8kHz
Power handling 20 - 120W (recommended amplifier power)
90W RMS
Frequency response 40Hz - 25kHz
Bassreflex Front single
Impedance 6ohm
Sensitivity 90dB
High-frequency driver 25 mm (1"), TWG
Midrange driver 133 mm (5.25")
Bass driver 2 x 165 mm (6.5")
Dimensions (H x W x D) 98 x 23 x 25 cm (excl. spikes)
Weight 13.5 kg / pc.
CENTER SPEAKER
Design Center, 2-way, 3 drivers
TLIE enclosure
Crossover points: 4.5kHz
Power handling 20 - 100W (recommended amplifier power)
50W RMS
Frequency response 55Hz - 25kHz
Impedance 6ohm
Sensitivity 88dB
Bass-Midrange driver 2 x 102 mm (4")
Features / accessories Wall mounts
Dimensions (H x W x D) 16.5 x 43 x 14.5 cm
Weight 3.32 kg / pc.
SURROUND SPEAKER
Design Surround, 2-way, 2 drivers
TLIE enclosure
50W RMS
Impedance 6ohm
Sensitivity 86dB
Bass-Midrange driver 102 mm (4")
Dimensions (H x W x D) 26.5 x 16.5 x 14.5 cm
Weight 2.34 kg / pc.
Package Included:
Denon AVR-S960H
7.2 channel 8K Ultra HD AV receiver with 145W per channel, supports 3D audio with Dolby Atmos, Dolby Atmos Height Virtualization Technology, DTS:X and DTS Virtual:X, as well as the latest HDMI specifications such as 8K/60Hz and 4K/120Hz** pass-through. Features Wi-Fi, Bluetooth, HEOS Built-in wireless multi-room music streaming and voice control compatibility.7.2声道8K超高清AV接收机,单声道185W,支持3D音频格式,如Dolby Atmos、Dolby Atmos Height Virtualization技术、DTS:X和DTS Virtual:X,支持8K/60Hz和4K/120Hz传输等最新HDMI规格。具备Wi-Fi、蓝牙、HEOS内置无线多室音乐流媒体和语音控制性能。
Overview
Upgrade your home theatre with the Denon AVR-S960H. With 145W per channel, the performance-tuned Denon AV receiver delivers an amazing 3D audio experience. The Denon AVR-S960H supports the latest in 3D sound formats such as Dolby Atmos, Dolby Atmos Height Virtualization Technology, DTS:X, and DTS Virtual:X. The AVR-S960H also supports the latest video technologies such as 8K/60Hz and 4K/120Hz** pass-through, Dolby Vision, HDR10, HDR10+, Dynamic HDR, HLG, as well as 8K upscaling and HDCP 2.3 support on all HDMI inputs (6 in/2 out).The front-panel USB offers convenient audio playback of MP3 and Hi-Res audio formats (WAV, FLAC, ALAC and DSD 2.8/5.6MHz files). Stream popular music services like Spotify, Amazon Music HD, TIDAL and more wirelessly via Bluetooth, Apple AirPlay 2 and Wi-Fi with HEOS Built-in. The new Denon AVR-S960H also works with Amazon Alexa, Google Assistant and Apple Siri for effortless voice control.
概述
全新Denon AVR-S960H为您带来更精彩的家庭影院娱乐体验。每声道145W,这款性能经过优化的Denon AV接收机能提供真正意义上的沉浸式3D音频体验。Denon AVR-S960H采用了最新的3D音频格式,如Dolby Atmos、Dolby Atmos Height Virtualization技术、DTS:X和DTS Virtual:X等。AVR-S960H还支持最新的视频技术,如8K/60Hz和4K/120Hz传输、Dolby Vision、HDR10、HDR10+、动态HDR、HLG,并在所有HDMI输入上支持8K增强技术和HDCP 2.3(6个输入/2个输出)。前面板USB可用于轻松播放MP3和高解析度音频格式(WAV、FLAC、ALAC和DSD 2.8/5.6 Mhz文件)的音频。借助蓝牙、Apple AirPlay 2和内置HEOS的Wi-Fi,Denon AVR-S960H可提供多种流媒体音乐服务。此外,它还支持苹果Siri,可轻松实现语音控制。
TAV-606 V.3
The third edition of TAV-606, one of our top selling speakers is now introduced in highly redesigned version with revised more stylish cabinets, upgraded drivers and crossovers and totally better fine-tuned sound performance.Adding high value to price ratio, the TAV-606 is great bargain both for hi-fi stereo as well as home theatre systems.
Amplifier
Channels 7.2
1-Channel Driven:
Audio Processing
Auro 3D Support No
Video
Upscaling 8K
GUI Yes
Connectivity
2 x 3RCA Component
2 x RCA Composite
2 x Optical TOSLINK
1 x Digital Coaxial
4 x Stereo RCA
1 x 3RCA Component
1 x RCA Composite
2 x RCA Subwoofer
1 x RJ45 (Ethernet)
HDMI CEC Yes
Control
Tuner Section
Tuner Type AM, FM
Power
CEC Standby: 0.5 W
Standby: 0.1 W
Physical
Packaging Info
FRONT SPEAKER
4 drivers
Bi-wiring, bi-amp
TLIE enclosure
90W RMS
Impedance 6ohm
Sensitivity 90dB
CENTER SPEAKER
TLIE enclosure
50W RMS
Impedance 6ohm
Sensitivity 88dB
SURROUND SPEAKER
TLIE enclosure
50W RMS
Impedance 6ohm
Sensitivity 86dB
- Number of posts : 1336
» Yamaha RX-V6A+Taga Harmony TAV-806 5.0 Home Theatre Package
» Denon AVR-S960H + Monitor Audio Mass 2G 5.1 Home Theatre Package
» Taga Harmony TAV-806 5.0 Speaker Package
» Taga Harmony TAV-606 V.3 5.0 Speaker Package
» Denon AVR-S660H + Monitor Audio Mass 2G 5.1 Home Theatre Package
