Yamaha RX-V6A+Taga Harmony TAV-806 5.0 Home Theatre Package
Yamaha RX-V6A+Taga Harmony TAV-806 5.0 Home Theatre Package Brand New. Now Selling At RM6,199. Free Shipping Within West Malaysia.
This 7.2-channel, 100 Watt AV receiver boldly explores entertainment possibilities for an advanced home theater with the latest in video and audio, including Dolby Atmos Height Virtualization, DTS:X, wireless streaming and more.
The TAV-806F front floorstanders use large cabinets with an enlarged internal volume with two 8 'woofers in each column - offering a huge amount of low-reaching bass, supported by the amazing dynamics usually found in active subwoofers rather than passive speakers!
Adding to this a high-quality midrange and tweeter that uses a silk dome and TAGA WaveGuide TWG technology , the whole creates a multidimensional, spacious, real, fluid and detailed soundstage.
The sound of the TAV-806F can be described as similar in its structure and quality to professional speaker stage systems .
The TAV-806C Center Column offers a high level of articulation and spatial presentation for a comprehensive mix of dialogue, music, and movie track effects.
The TAV-806S Surround Sound Speakers add volume and size to the soundstage for both movie tracks as well as multi-channel music.
Yamaha RX-V6A Specs
Amplifier
Channels 7.2
Power Output per Channel 2-Channel Driven:
100 W at 8 Ohms / 20 Hz to 20 kHz / 0.06% THD
Audio Processing
DTS Compatibility DTS-HD Master Audio, DTS:X
Dolby Compatibility Dolby Atmos, Dolby Digital Plus, Dolby TrueHD
Auro 3D Support No
Supported File Formats 11.2 MHz DSD, AAC, AIFF, ALAC, FLAC, MP3, WMA
DAC 384 kHz / 32-Bit (BB PCM5102A)
Video
HDR Compatibility HDR10
Pass-Through Support 4K60p
Upscaling 4K UHD
GUI Yes
Connectivity
Rear A/V Inputs 7 x HDMI
1 x Optical TOSLINK
1 x Digital Coaxial
3 x Stereo RCA
1 x Stereo RCA (Phono) with Ground Screw
Rear A/V Outputs 1 x HDMI
2 x RCA Subwoofer Pre-Out
1 x Stereo RCA Zone 2 Pre-Out
1 x Stereo RCA Pre-Out
Front I/O 1 x 1/4" / 6.35 mm Headphone Output
1 x USB Type-A
1 x 1/8" / 3.5 mm Setup Mic Input
Other Rear I/O 1 x RJ45 (Ethernet)
2 x Bluetooth/Wi-Fi Antenna Terminal Input
1 x FM Antenna Terminal Input
1 x 1/8" / 3.5 mm (12 V Trigger) Output
Speaker Connectors 9 x Binding Post Pairs
HDCP Support Version 2.3
Audio Return Channel (ARC) Yes, eARC
HDMI CEC Yes
Media Card Slot None
A/B Speaker Selection None
Bi-Amp Capability Yes
Wireless Connectivity
Supported Audio Codecs AAC, SBC
Wireless Audio Protocols AirPlay 2, MusicCast
Control
Virtual Assistant Support Amazon Alexa, Google Assistant
Tuner Section
Tuner Type AM, FM
Power
Power Consumption Standby: 0.1 W
Physical
Dimensions (W x H x D) 17.1 x 9.6 x 14.9" / 43.4 x 24.4 x 37.8 cm (Antenna Up)
17.1 x 6.8 x 14.9" / 43.4 x 17.3 x 37.8 cm (Antenna Down)
Weight 21.6 lb / 9.8 kg
Taga Harmony TAV-806F
Construction: 3-way, 4 loudspeakers, floor standing, Bi-wiring, front bass reflex, 600Hz 4kHz crossover cut-off, TLIE housing
Tweeter: 25mm (1 "), silk dome, TWG panel
Mid-Woofer: 133mm (5.25 "), paper cone
Woofer: 2 x 203mm (8 "), paper cone
Recommended Amplifier Power: 20-180W
Frequency response: 30Hz-25000Hz
Mean Impedance: 6 ohms
Efficiency: 89dB
Size in cm (HxWxD): 108 x 24.5 x 31.2 cm (without pins)
Weight: 36.8 kg per pair without packaging
Taga Harmony TAV-806S
Construction: 2-way, 2 speakers, surround speaker, rear bass reflex, 5kHz crossover cut-off, TLIE enclosure
Recommended Amplifier Power: 20-120 W
Frequency response: 53Hz-25KHz
Efficiency: 87 dB
Size in cm (HxWxD): 30 x 18 x 18 cm
Weight: 6.3 kg per pair without packaging
Taga Harmony TAV-806C
Construction: 2-way, 3 speakers, center speaker, dual rear bass reflex, 5.6kHz crossover cut-off, TLIE enclosure
Mid-Woofer: 2 x 133mm (5.25 "), paper cone
Recommended Amplifier Power: 20-100 W
Efficiency: 88 dB
Size in cm (HxWxD): 18 x 50 x 18 cm
Weight: 5.1 kg pcs without packaging
Color: black
Yamaha RX-V6A
7.2-Channel AV Receiver with 8K HDMI and MusicCastThis 7.2-channel, 100 Watt AV receiver boldly explores entertainment possibilities for an advanced home theater with the latest in video and audio, including Dolby Atmos Height Virtualization, DTS:X, wireless streaming and more.
- 7.2-channel 100 Watt surround sound with Zone 2
- 4K120AB and 8K60B HDMI and HDR10+ (with future update) with HDCP 2.3 and eARC (7 in/1 out)
- Dolby Vision, Hybrid Log-Gamma and BT.2020
- Supports enhanced media and gaming - ALLM, VRR, QFT, QMS (with future update)
- Dolby Atmos with Dolby Atmos Height Virtualization (with future update) and DTS:X
- Wi-Fi, AirPlay 2, Spotify Connect and Voice Control
- MusicCast multi-room audio app control
- Pandora, Spotify, Amazon Music, SiriusXM, TIDAL, Deezer, Napster and more
- YPAO automatic room calibration with R.S.C. and multipoint
- Phono input
- MusicCast Surround-capable: add optional MusicCast speakers to provide wireless surrounds for a 5.1-channel setup
Taga Harmony TAV-806 5.0 Loudspeakers
The most important features:
- high quality
- large enclosures with increased volume
- similar in structure and quality to professional loudspeaker stage systems
- the perfect choice for dynamic and concert music recordings
- high level of articulation and spatial presentation
- great value for money
A powerful set of high quality
Perfect for live music recordings
This model is the perfect choice for dynamic and concert music recordings as well as main channels for 5.1 music or home theater.The TAV-806C Center Column offers a high level of articulation and spatial presentation for a comprehensive mix of dialogue, music, and movie track effects.
Yamaha RX-V6A Specs
Amplifier
Channels 7.2
Audio Processing
Auro 3D Support No
Video
Upscaling 4K UHD
GUI Yes
Connectivity
1 x Optical TOSLINK
1 x Digital Coaxial
3 x Stereo RCA
1 x USB Type-A
HDMI CEC Yes
Control
Tuner Section
Tuner Type AM, FM
Power
Physical
Efficiency: 89dB
Efficiency: 87 dB
Efficiency: 88 dB
Color: black
- Number of posts : 1318
» Denon AVR-S960H + Taga Harmony TAV-606 V.3 5.0 Home Theatre Package
» Yamaha RX-A2A+Wharfedale D330 5.0 Home Theatre Package
» Taga Harmony TAV-406 v.2 Set + Taga TSW-90 v.3 Active Subwoofer (5.1 Set)
» Yamaha NS-F350 + P350 5.0 Home Theatre Speaker Package
» Taga Harmony TAV-606 V.3 5.0 Speaker Package
