Yamaha NS-F350 + P350 5.0 Home Theatre Speaker Package
Yamaha NS-F350 + P350 5.0 Home Theatre Speaker Package Brand New. Now Selling At RM4,299. Free Shipping Within West Malaysia.
完整呈現聲音細節,這款落地式喇叭設計搭配NS-P350,已提供流暢悅耳的環繞音場。搭載全新高音及PMD錐形低音喇叭。透過五聲道輸出,享受完整的細節呈現。
If the sound quality is not good enough in 2-channel playback, there is no chance of properly reproducing the source in surround sound. This is the idea that led to the development of this floorstanding speaker for a 5-channel system. Every channel has an all-new tweeter and PMD cone woofer combination. Able to handle audio-rich data, it ensures that expansive and seamless theatre sound will fill your room.
如果雙聲道的音質表現不夠好,就沒有辦法好好呈現環繞音效。從這個概念發展出了五聲道的落地式喇叭系統。每個聲道都具備新的揚聲器及PMD (高分子射出雲母光圈) 錐形低音喇叭的組合,能夠勝任豐富細節的音炫,確保廣闊的劇院音效充滿空間。
As a next-generation unit, the NS-F350 employs a new structure that puts an aluminium dome inside the voice coil. The aluminium’s Black Anodised processing suppresses the aluminium-specific character of the sound, providing expansive and accurate reproduction of the texture and nuance of the high frequencies. With a new diffuser shape and a new voice coil using CCAW (copper-coated aluminium wire) it achieves 45 kHz (–10 dB) reproduction with extended high frequency range while maintaining the amount of information and energy in the audible band.
作為次世代產品,NS-F350採用將呂至圓頂放進音圈的新架構。鋁金屬的鍍黑處理抑制了鋁對聲音的特殊影響,提供廣闊且精準的質感與高音呈現。新的擴散板和銅鍍鋁線的音圈,達到45kHz(-10dB)重現能力以及廣闊的高音範圍,同時能維持聲音細節和能量。
Based on the idea of controlling spatial representation from the speaker, the waveguide horn directs the sound to reflect from walls and other surfaces. Thanks to the directivity of a left-right directional range of 135 degrees and a vertical range of 120 degrees optimised for home theatre use, it precisely recreates the sound field while minimising the impact of the room.
基於控制喇叭的空間表現概念,波導角可以主導從牆壁或其他表面的聲音反射。水平135度和垂直120度控制範圍強化了家庭劇院的表現,降低空間環境的影響,精準的再現音場。
The NS-F350’s 3-way, 4-speaker configuration utilises a PMD (Polymer-Injected Mica Diaphragm) cone, midrange and woofer, already proven to achieve ideal internal loss and high elasticity characteristics through light weight and high rigidity. Its SN ratio excels in the range of the human voice and vocals, and its low frequency range is supple and transparent in tone.
NS-F350的3路4揚聲器系統搭載一個PMD (Polymer-Injected Mica Diaphragm)錐形低音喇叭、中音喇叭及低音喇叭,達到理想的內部耗損率以及從輕柔至剛強的高彈性表現。兼具優異的人聲訊噪比,以及滑順清澈的低音。
喇叭機身兩側具備圓滑的曲線設計。減少平面的設計降低駐波以及多餘的聲波反射。前置反射板具有雙層設計以及鋼琴鏡面處理。強化的設計,使音調更自然更清澈。
As a next-generation unit, the NS-PC350 and NS-PB350 employ a new structure that puts an aluminium dome inside the voice coil. The aluminium’s Black Anodised processing suppresses the aluminium-specific character of the sound, providing expansive and accurate reproduction of the texture and nuance of the high frequencies. With a new diffuser shape and a new voice coil using CCAW (copper-coated aluminium wire) it achieves 45 kHz (–10 dB) reproduction with extended high frequency range while maintaining the amount of information and energy in the audible band.
Incorporating 30% high quality white mica, the 13 cm (5”) woofer utilises a lightweight, high rigidity PMD (Polymer-injected Mica Diaphragm) cone that achieves ideal internal loss and high elasticity characteristics. The new design put both the voice coil and spider under the knife, achieving massive, expansive low tones.
NS-F350
Type: 3-way bass-reflex floorstander
Woofers: Dual 16cm (6-1/2”) cone
Midrange Driver: 13cm (5") cone
Tweeter: 3cm (1”) aluminium dome
Frequency Response: 35Hz–45kHz
Nominal Input Power: 100 W
Maximum Input Power: 200 W
Sensitivity: 88dB /2.83V /1m
Crossover Freq: 1.4kHz, 3.8kHz
Impedance: 6 ohms
Dimensions (WHD): 220 x 1157 x 339mm
Weight: 25.9 kg
NS-P350
Type: 2-way acoustic suspension (NS-PC350) / 2-way bass-reflex (NS-PB350)
Tweeter: 3cm (1”) aluminium dome,
Midrange: 13cm (5") cone
Woofer: 13cm (5”) cone ( surround ) 13cm (5”) cone Dual (center)
Power: Nominal Input Power 50W(surround) 100 W(center) , Maximum Input Power 150W (surround) 200 W (center)
Resistance: 6 Ω
Frequency Response: 58 Hz -45 Hz (Center ), 57 Hz–45 kHz ( Surround )
Sensitivity: 88 dB/2.83 V/1 m (Center), 88 dB/2.83 V/1 m ( Surround )
Crossover Frequencies: 2.8 kHz (Center) 1.4 kHz, 3.8 kHz (Surround)
Dimensions (W x H x D): 500 x 174 x 202 mm ( Center ), 186 x 320 x 208 mm ( Woofer )
Weight: 6.3 kg (Center), 4.8 kg (Surround)
NS-F350
Producing finely detailed sound, this floorstanding speaker is designed to team with the NS-P350 for a smooth, seamless surround sound field. It features an all-new tweeter and PMD cone woofer. Enjoy every bit of audio data in the AV source with 5-channel output.- New 3 cm (1”) aluminium dome tweeter generates 45 kHz (-10 dB) high frequency reproduction that is truly outstanding
- The 13 cm (5”) midrange and pair of 16 cm (6-1/2”) woofers, featuring PMD cones that produce massive, clear low frequencies
- Unique waveguide horn that enhances the sound field sensation of theatre sound
- Rounded shape suppresses standing waves, and its double structure finish strengthens the front baffle
- Large, gold-plated screw terminals with bi-wiring connectivity
- Front baffle features a black or white mirror piano finish
- Beautiful black side panels with an elegant round shape
- 全新3cm鋁製圓頂高音揚聲器帶來優異45kHz(-10 dB)高頻再現能力
- 13cm中頻揚聲器及一對16cm(6-1/2”)低音揚聲器,搭配PMD (高分子射出雲母光圈) 錐形低音喇叭傳送渾厚清晰的低頻音
- 獨特波導角強化劇院般的音場
- 圓弧型設計抑制駐波,雙重結構強化前反射板
- 大型鍍金螺絲端子具備雙線圈連接性
- 黑色或白色鋼琴鏡面烤漆前反射板
- 優美的黑色圓滑側板
Yamaha’s Sound Concept: The Ability to Fully Play All the Latest AV Sources
Expansive, Glistening Sound. A New 3 cm (1”) Aluminium Dome Tweeter that Reproduces 45 kHz (–10 dB) High Frequencies
Featuring a Unique Waveguide Horn that Controls Directivity
Featuring a PMD Cone. A 13 cm (5”) Midrange and 16 cm (6-1/2”) Dual Woofers, Supple and Transparent in Tone
Rounded Front Baffle with Double Structure
The cabinet features a rounded shape that curves smoothly to both sides. By reducing the number of parallel surfaces it minimises standing waves and unwanted resonance. The front baffle has a double structure with a mirror-like piano finish. With reinforced strength, it produces more natural, extremely transparent tones.喇叭機身兩側具備圓滑的曲線設計。減少平面的設計降低駐波以及多餘的聲波反射。前置反射板具有雙層設計以及鋼琴鏡面處理。強化的設計,使音調更自然更清澈。
Massive Power for Optimum Sound Performance
NS-P350
Producing finely detailed sound, this speaker package including a centre and two surround speakers is designed to team with the NS-F350 for a smooth, seamless surround sound field. Every channel features an all-new tweeter and PMD cone woofer. Enjoy every bit of audio data in the AV source with 5-channel output.- New 3 cm (1”) aluminium dome tweeter generates 45 kHz (–10 dB) high frequency reproduction that is truly outstanding
- The 13 cm (5”) woofer features PMD cones that have a proven track record, produce massive, clear low frequencies
- Wall mountable
If the sound quality is not good enough in 2-channel playback, there is no chance of properly reproducing the source in surround sound. This is the idea that led to the development of these surround back and centre speakers for a 5-channel system. Both speakers use an all-new tweeter and PMD cone woofer combination. They have large cabinets to handle audio-rich data, ensuring that expansive and seamless theatre sound will fill your room.Expansive, Glistening Sound. A New 3 cm (1”) Aluminium Dome Tweeter that Reproduces 45 kHz (–10 dB) High Frequencies
Supple and Strong. 13 cm (5”) Woofer Utilises a PMD Cone with a Proven Track Record in Europe and Japan
Wall Mountable
The NS-PC350 and NS-PB350 have keyholes on the back so they can be quickly and securely wall mounted.流畅清澈的中高音和广阔的低音环绕着您。呈现双声道音源的微妙细节。
主音箱NS-F330作为配备全新设计装置的新一代落地式音箱,该音箱系统在开发中以音乐为重点。采用全新兼容高分辨率的球顶高音单元,与兼容高分辨率的普通音箱相比(40 kHz),踏入了另一个更高的〜别。配备双低音单元,浑厚广阔的低频音色与高频声音完美搭配,准确呈现各种音源(从高分辨率音源到CD 流媒体)的细微差异。环绕音箱和中置音箱采用大容量箱体处理声音丰富的数据, 确保您的房间内呈现广阔、流畅的影院效果。全新的3 cm 铝制球顶高音单元再现广阔空灵的45 khz(-10 db)高频
采用全新的结构设计,将铝制球顶置于音圈内,确保新一代音箱系统应有的特征与音质。铝材料黑色阳化加工可抑制声音中铝独有的质感,达到自然、空灵的声音质量。扩散器采用新的形状,而音圈由在材料和直线性方面经过重新设计的CCAW(包铜铝线)组成。在保持可听频带中信息量和表现力的同时,再现45 kHz(–10 dB)的高频,使高频范围更广。该系统还配备中置和环绕音箱,打造平滑自然的环绕声效果。高音单元采用独特的波导喇叭进行指向控制
独特的波导喇叭和高音单元采用录音室监听音箱指向控制中使用的相同波导技术,以控制间接声音的入射情况。垂直和水平指向性控制实现能量平衡,不受空间环境的影响。醇厚、饱满、柔和的低频音质。13 cm 低音单元采用在欧洲和日本久经考验且性能可靠的PMD 圆锥形结构
NS-F330 的两分频三扬声器配置采用轻量〜、高刚性的PMD 圆锥形低音单元,其在现代樱桃木系列中以可靠的性能风靡欧洲和日本,实现理想的内损和高弹性特征。全新的结构设计对音圈和音圈骨架进行了改进,展现强劲但圆润深厚的声质。作为双低音单元落地式音箱,其低频段非常厚重而广阔。圆滑的双层结构前障板
箱体采用圆滑的形状,平滑流畅地延伸到两侧。通过减少平行面的数量,很大程度上减少了驻波和共振。前障板采用双层结构,镜面钢琴烤漆。由于强度增加,高音更为自然且为纯净。中置和环绕音箱可安装在墙壁上
中置音箱(NS-PC350)和环绕音箱(NS-PB350)背面有锁眼,因此可以快速牢固地安装到墙面上。Interested please feel free to contact:
NS-F350
Impedance: 6 ohms
Weight: 25.9 kg
NS-P350
Resistance: 6 Ω
- Number of posts : 1334
» Yamaha NS-F/P160 Home Theatre 5.0 Speaker Package (Sold)
» Yamaha RX-A2A+Wharfedale D330 5.0 Home Theatre Package
» Yamaha RX-V6A+Taga Harmony TAV-806 5.0 Home Theatre Package
» Onkyo & Jamo 5Ch Home Theatre Package
» B&W 684 + HTM62 Home Theatre package (sold)
